Hey Folks,
I have another thread that has since been solved: WRX90e won’t boot with 6 GPUs but now I’m having another problem with my SSDs.
I notice that in CrystalDiskMark I get great scores with my T700 SSDs, 11-12GB/s Read and 11GB/s write, but when I transfer files in windows, things write at 70MB/s - this is totally abysmal, as I’m working with giant 6-30GB files. I have been trying to investigate this in my free time over the past few days. Here’s what I’ve done:
- Assuming this was a driver issue and that this wasn’t happening originally, I reinstalled windows 11 completely. Sure enough, on fresh install, no drivers, file transfer speeds are about 1.4-1.5GB/s.
- While still disconnected from the internet, I installed the LAN drivers, Chipset drivers, and Video card drivers. In between each of those, I made sure the drive speed was still good. It actually improved slightly after installing the chipset drivers, and will peak around 2GB/s isntead of 1.5GB/s. Great.
- With all those drivers installed, I started to enable my other monitors in Nvidia Control Panel (there are 8 monitors in total, and up until this point I was only using 1 monitor). Lo and behold - WHEN I CONNECT TO MORE THAN ONE DISPLAY, THE WINDOWS FILE TRANSFER SPEED GOES TO 70MB/s! Disabling the monitors and restarting the machine will put me back in the previous state where the file speed is hitting that 1.5-2GB/s peak speed.
So something is happening when I turn on all 8 monitors, and it’s only happening to windows - CrystalDiskMark is still showing great scores. It’s just windows file transfer that is bogging down. There has got to be something going on at the software or driver level. If anybody has any tips or ideas please let me know.
In the meantime, I’ll be trying out a bunch of things:
- Change the GPUs that are being used for monitors.
- Decrease the number of monitors being used.
- Try different drivers, older drivers, etc.
- Remove a couple GPUs (the 4090s) so that there are only one type of GPU, or if it’s just fewer GPUs that solves it.
Will report back with what I find.
Edit:
System Specs:
CPU: 7985wx
RAM: 512 GB, 8 x 64GB Samsung M321r8ga0bb0-cqkmg
GPUs: 4 x 6000 ada, 2 x 4090
PSUs: 3 x 1600W Seasonic Titanium ATX 3.0
SSD: 8 x T700 (4 in slot 7 via a Hyper M.2 card)
8 monitors of various sizes.
