What motherboard for Ryzen 5900x workstation/homeserver
Hi Guys,
what motherboard would you recommend for workstation/homeserver with ryzen 5900x?
It will run few websites (so 24/7 operation, but nothing enterprise level obviously:) and I will use it as development “workstation” - programming C# mostly, sometimes compiling larger projects or running more intesive computations for hours/days. It will run Hyper-V with few VMs.
My requirements:
  1. good VRM and component quality - for stability and longevity, not going to overclock
  2. would like to have 3x nvme PCIe 4.0 disks, so PICe 4 is a must, 3x m.2 ports would be nice to have but I can use expansion card for that
  3. ability to boot without monitor (and ideally also without GPU but that is optional) I plan to connect remotely
  4. fast memory support, minimum 3600
Don’t want/need
  • RGB - box is in another room, I want computer, not christmas tree
  • Wifi - I will only use ethernet
  • Good audio - this will never play anything
  • I also dont need too many usb ports etc.
Basically I am looking for solid base functionallity without all the bells and whistles that gamers like but I dont need.
Hmm I wonder if Asrock will come out with a “RACK” series motherboard with x570 chipset. Right now they have the x470 but no pci 4.
Take a look at SuperMicro and Tyan, they have some workstation focused offerings.
Are you going to do anything in regards to pci-e passtrough?
And of course what is your budget?
Do you mean like these
https://www.asrockrack.com/general/productdetail.asp?Model=X570D4U-2L2T#Specifications
https://www.asrockrack.com/general/productdetail.asp?Model=X570D4U#Specifications
https://www.asrockrack.com/general/productdetail.asp?Model=X570D4I-2T#Specifications
Only availability I found when I looked a few weeks back was in the US so no good for me but maybe will work for you.
pie-e passthrough - possibly… it’s not main requirement, but certainly would be nice since I plan to use this for VMs as well…
budget ideally not much over 300 usd…
Hm Asrock Rack X570D4U looks nice… any word about Ryzen 5000 support?
But don’t know if I can get this in Europe…
So my candidates so far after watching some Youtube reviews and your recommendations are:
Asrock Taichi X570 - http://www.asrock.com/mb/AMD/X570%20Taichi/
Asus WS X570 ACE - https://www.asus.com/Motherboards-Components/Motherboards/All-series/Pro-WS-X570-ACE/
Asrock Rack X570D4U - https://www.asrockrack.com/general/productdetail.asp?Model=X570D4U#Specifications
I am also wondering if I could get away with some cheaper B550 board that has reasonably good VRM… haven’t looked into entry level boards much yet…
Heads up: If you are considering this board while hoping for IPMI-like remote interface then you should know it is not the real thing:
beta bios already supports them. (separate ‘beta zone’ download section)
edit: report from someone already running it with 5900x: Asrock X570d4u, x570d4u-2L2T discussion thread - #124 by tmp
Nice. Do we know something about fast memory support? I will need 64GB and was thinking about 3600 MHz…
EDIT: G.SKILL 32GB KIT DDR4 3600MHz CL16 Trident Z looks like a good candidate
AFAIK X570D4U has no XMP profiles - You will have to dial in the OC by hand so don’t expect much - this is not a gaming/OC board.
There isn’t much info about 5000 series CPUs on this boards so things may be better or worse, you could try PM-ing people who report to have this combo (https://forum.level1techs.com/t/asrock-x570d4u-x570d4u-2l2t-discussion-thread/)
B550 boards are not really ideal for pci-e passtrough in that regards.
Because if the current situation on the iommu groupings on most B550 boards.
  • Asus WS pro X570 Ace: has a very good vrm.
    Only downside of this board is that it is a bit down on sata ports.
    And the second m.2 slot only runs at 2x instead of 4x speeds i believe.
    But other then that it basically would be a good option.
    vrm details: ASP1405i (IR35201) in 6+2 phase mode with double the components per phase.
    Which means a 12+2 power stage design featuring IR3555 60A power stages.
  • Asrock X570 Taichi: Good board with a decent vrm.
    vrm details: pwm: ISL69147 6+1 phase mode doubled to 12+2 using ISL6617 doublers.
    Powerstages Vishay 50A Sic634 DRmos.
  • Gigabyte X570 Aorus Master: good board with a great vrm as well.
    But that is probably not really a board that you would be looking for.
    Because of the additional gaming related features it comes with.
    vrm details: pwm: Infineon XDPE132G5G in 12+2 phase mode.
    powerstages 50A IR3556.
Those Asrock Rack boards might be interesting as well.
But i have not really looked much into those yet.
So i can’t really help with providing much info on those atm.
The Asrock x570 Taichi is running t topology for RAM. However the Aorus is Daisy chain. I am contemplating myself which is better for my use case.
PS: I am awaiting a 5900x myself and super confused with the motherboard to get. Since in my country I can get almost the same price.
Yeah I wouldn’t mind if someone did ryzen 5000 + mobo + ram testing /benchmarking :slight_smile: with the boards we are considering here…
I am still waiting for 5900x to becaome available, I am afraid it will not happen before christmas…
I’d say a B550 motherboard should work for your plans, availability and what - I haven’t checked myself yet so I could not give a recommendation…
As far as i´m aware, all x570 mainstream boards are Daisy chain topology.
Looks like my 5900x is on the way, hurray :slight_smile:
I also reconsidered that I might have this computer sittin in my room, so I started looking into B550 boards, because X570 have active cooling on chipsets and I dont trust small fans to stay quiet.
So my new candidate is: Gigabyte B550 Aorus Master
  • It has good VRM,
  • 3x nvme PCIe 4.0 directly to CPU,
  • probably better support for fast memory compared to those Asrack boards,
  • similar price range as Taichi and Asus WS board I considered initially.
There are passive x570 boards on the market. If you choose an active one and set the max rpm of the fan to 40% it will be not audible at all.
I was talking about this specific one. :slight_smile:
I also went for Aorus from Taichi.
PS: Still waiting for the 5900X.
