My system
- asus z390 pro
- i5 9600k
- msi duke 1070 ti
- coolermaster masterliquid lc240e rgb
I had issues with the computer shutting down, repeatedly.
I’ve replaced
- the power supply with a new corsair tm650x
- the lc240e with a new lc240e
Tom’s hardware tells me that my cpu shouldn’t get above (or near) 100c.
OpenHardwareMonitor tells me that i’ve got cores at 100C hitting 110C at times. It also tells me that the max has been 115C.
The in/out pipes to the AIO are very warm to the touch. To me, this suggests that I’ve pasted properly otherwise it wouldn’t be getting the heat.
In my bios, I’ve set the case fans to max.
Just for added support, I had MSI afterburner set it’s fan to max.
- What am I doing wrong?
- What do I need to do to fix?
Please advise,
brian
After looking through my previous posts, I managed to locate my first request-for-overheating-help page. Machine turns itself off intermittently
I probably should have updated that post instead as I think the shutdowns were overheat related.
Advice given included
- run memtest which I did but which didn’t yield issues
- replace the power supply which I did, upping from 550 to 650
- refeed/reseat all cables which I did when replacing the psu
Since my original post, about 15 min ago, the temps have increased but the in/out tubes are cooler…
2021/08/19 14:27
tom’s hardware[Its Urgent My AUXTIN 1,2 Temp Very High | Tom's Hardware Forum] and overclock.net suggests that high auxtin values may not be an issue
[AUXTIN temperature??? What the heck! | Overclock.net]
because so many mentions of hwinfo64, here is the log of sensors:
HWiNFO64 Version 7.06-4500
DESKTOP-Q022PTG -----------------------------------------------------------
[Current Computer]
Computer Name: DESKTOP-Q022PTG
[Operating System]
Central Processor(s) ------------------------------------------------------
[CPU Unit Count]
Number Of Processor Packages (Physical): 1
Number Of Processor Cores: 6
Number Of Logical Processors: 6
Intel Core i5-9600K -------------------------------------------------------
[General Information]
Processor Name: Intel Core i5-9600K
Original Processor Frequency: 3700.0 MHz
Original Processor Frequency [MHz]: 3700
CPU ID: 000906EC
CPU Brand Name: Intel® Core™ i5-9600K CPU @ 3.70GHz
CPU Vendor: GenuineIntel
CPU Stepping: P0
CPU Code Name: Coffee Lake-S
CPU Technology: 14 nm
CPU S-Spec: SR3WZ, SRELU
CPU Thermal Design Power (TDP): 95.0 W
CPU Power Limits (Max): Power = Unlimited, Time = Unlimited
CPU Power Limit 1 - Long Duration: Power = Unlimited, Time = 28.00 sec [Unlocked]
CPU Power Limit 2 - Short Duration: Power = Unlimited, Time = 2.44 ms [Unlocked]
CPU Max. Junction Temperature (Tj,max): 115 °C
CPU Type: Production Unit
CPU Platform: Socket H4 (LGA1151)
Microcode Update Revision: DE
Number of CPU Cores: 6
Number of Logical CPUs: 6
[Operating Points]
CPU LFM (Minimum): 800.0 MHz = 8 x 100.0 MHz
CPU HFM (Base): 3700.0 MHz = 37 x 100.0 MHz
CPU Turbo Max: 4600.0 MHz = 46 x 100.0 MHz [Unlocked]
Turbo Ratio Limits - IA/SSE: 46x (1c), 45x (2-3c), 44x (4-5c), 43x (6c)
Turbo Ratio Limits - AVX2, Resolved: 46x (1c), 45x (2-3c), 44x (4-5c), 43x (6c)
CPU Current: 4389.3 MHz = 44 x 99.8 MHz @ 1.1121 V
LLC/Ring Maximum: 4300.0 MHz = 43.00 x 100.0 MHz
LLC/Ring Current: 4090.0 MHz = 41.00 x 99.8 MHz
System Agent Current: 798.0 MHz = 8.00 x 99.8 MHz
CPU Bus Type: Intel Direct Media Interface (DMI) v3.0
Maximum DMI Link Speed: 8.0 GT/s
Current DMI Link Speed: 8.0 GT/s
Number of Overclocking Bins: Unlimited
Ring to Core Offset: Enabled
[IA Overclocking]
Voltage Offset: Supported
Voltage Override: Supported
Ratio Overclocking: Supported
Fused Ratio Limit: 120x
OC Ratio Limit: N/A
Voltage Mode: Interpolative
Voltage Offset: 0 mV
IccMax: Unlimited
[GT (Slice) Overclocking]
Fused Ratio Limit: 60x
OC Ratio Limit: 23x
IccMax: 45.00 A
[CLR (CBo/LLC/Ring) Overclocking]
Fused Ratio Limit: 85x
OC Ratio Limit: N/A
IccMax: Unlimited
[GT (Unslice) Overclocking]
OC Ratio Limit: N/A
IccMax: 45.00 A
[Uncore/SA Overclocking]
Voltage Override: Not Supported
Ratio Overclocking: Not Supported
Fused Ratio Limit: N/A
OC Ratio Limit: N/A
IccMax: 20.00 A
IA Domain Loadline (AC/DC): 0.600 / 1.850 mOhm
GT Domain Loadline (AC/DC): 3.100 / 3.100 mOhm
[Cache and TLB]
L1 Cache: Instruction: 6 x 32 KBytes, Data: 6 x 32 KBytes
L2 Cache: Integrated: 6 x 256 KBytes
L3 Cache: 9 MBytes
Instruction TLB: 2MB/4MB Pages, Fully associative, 8 entries
Data TLB: 4 KB Pages, 4-way set associative, 64 entries
[Standard Feature Flags]
FPU on Chip Present
Enhanced Virtual-86 Mode Present
I/O Breakpoints Present
Page Size Extensions Present
Time Stamp Counter Present
Pentium-style Model Specific Registers Present
Physical Address Extension Present
Machine Check Exception Present
CMPXCHG8B Instruction Present
APIC On Chip / PGE (AMD) Present
Fast System Call Present
Memory Type Range Registers Present
Page Global Feature Present
Machine Check Architecture Present
CMOV Instruction Present
Page Attribute Table Present
36-bit Page Size Extensions Present
Processor Number Not Present
CLFLUSH Instruction Present
Debug Trace and EMON Store Present
Internal ACPI Support Present
MMX Technology Present
Fast FP Save/Restore (IA MMX-2) Present
Streaming SIMD Extensions Present
Streaming SIMD Extensions 2 Present
Self-Snoop Present
Multi-Threading Capable Present
Automatic Clock Control Present
IA-64 Processor Not Present
Signal Break on FERR Present
Virtual Machine Extensions (VMX) Present
Safer Mode Extensions (Intel TXT) Present
Streaming SIMD Extensions 3 Present
Supplemental Streaming SIMD Extensions 3 Present
Streaming SIMD Extensions 4.1 Present
Streaming SIMD Extensions 4.2 Present
AVX Support Present
Fused Multiply Add (FMA) Present
Carryless Multiplication (PCLMULQDQ)/GFMUL Present
CMPXCHG16B Support Present
MOVBE Instruction Present
POPCNT Instruction Present
XSAVE/XRSTOR/XSETBV/XGETBV Instructions Present
XGETBV/XSETBV OS Enabled Present
Float16 Instructions Present
AES Cryptography Support Present
Random Number Read Instruction (RDRAND) Present
Extended xAPIC Present
MONITOR/MWAIT Support Present
Thermal Monitor 2 Present
Enhanced SpeedStep Technology Present
L1 Context ID Not Present
Send Task Priority Messages Disabling Present
Processor Context ID Present
Direct Cache Access Not Present
TSC-deadline Timer Present
Performance/Debug Capability MSR Present
IA32 Debug Interface Support Present
64-Bit Debug Store Present
CPL Qualified Debug Store Present
[Extended Feature Flags]
64-bit Extensions Present
RDTSCP and TSC_AUX Support Present
1 GB large page support Present
No Execute Present
SYSCALL/SYSRET Support Present
Bit Manipulation Instructions Set 1 Present
Bit Manipulation Instructions Set 2 Present
Advanced Vector Extensions 2 (AVX2) Present
Advanced Vector Extensions 512 (AVX-512) Not Present
AVX-512 Prefetch Instructions Not Present
AVX-512 Exponential and Reciprocal Instructions Not Present
AVX-512 Conflict Detection Instructions Not Present
AVX-512 Doubleword and Quadword Instructions Not Present
AVX-512 Byte and Word Instructions Not Present
AVX-512 Vector Length Extensions Not Present
AVX-512 52-bit Integer FMA Instructions Not Present
Secure Hash Algorithm (SHA) Extensions Not Present
Software Guard Extensions (SGX) Support Present
Supervisor Mode Execution Protection (SMEP) Present
Supervisor Mode Access Prevention (SMAP) Present
Hardware Lock Elision (HLE) Present
Restricted Transactional Memory (RTM) Present
Memory Protection Extensions (MPX) Present
Read/Write FS/GS Base Instructions Present
Enhanced Performance String Instruction Present
INVPCID Instruction Present
RDSEED Instruction Present
Multi-precision Add Carry Instructions (ADX) Present
PCOMMIT Instructions Not Present
CLFLUSHOPT Instructions Present
CLWB Instructions Not Present
TSC_THREAD_OFFSET Present
Platform Quality of Service Monitoring (PQM) Not Present
Platform Quality of Service Enforcement (PQE) Not Present
FPU Data Pointer updated only on x87 Exceptions Not Present
Deprecated FPU CS and FPU DS Present
Intel Processor Trace Present
PREFETCHWT1 Instruction Not Present
AVX-512 Vector Bit Manipulation Instructions Not Present
AVX-512 Vector Bit Manipulation Instructions 2 Not Present
AVX-512 Galois Fields New Instructions Not Present
AVX-512 Vector AES Not Present
AVX-512 Vector Neural Network Instructions Not Present
AVX-512 Bit Algorithms Not Present
AVX-512 Carry-Less Multiplication Quadword (VPCLMULQDQ) Not Present
AVX-512 Vector POPCNT (VPOPCNTD/VPOPCNTQ) Not Present
User-Mode Instruction Prevention Not Present
Protection Keys for User-mode Pages Not Present
OS Enabled Protection Keys Not Present
Wait and Pause Enhancements (WAITPKG) Not Present
Total Memory Encryption Not Present
Key Locker Not Present
57-bit Linear Addresses, 5-level Paging Not Present
Read Processor ID Not Present
Cache Line Demote Not Present
MOVDIRI: Direct Stores Not Present
MOVDIR64B: Direct Stores Not Present
ENQCMD: Enqueue Stores Not Present
SGX Launch Configuration Present
Protection Keys for Supervisor-Mode Pages Not Present
Control-Flow Enforcement Technology (CET) Shadow Stack Not Present
AVX-512 4 x Vector Neural Network Instructions Word Variable Precision Not Present
AVX-512 4 x Fused Multiply Accumulation Packed Single Precision Not Present
Fast Short REP MOV Not Present
User Interrupts Not Present
AVX-512 VP2INTERSECT Support Not Present
AVX-512 FP16 Not Present
MD_CLEAR Support Present
SERIALIZE Not Present
Hybrid Processor Not Present
TSX Suspend Load Address Tracking Not Present
Platform Configuration (PCONFIG) Not Present
Indirect Branch Restricted Speculation (IBRS), Indirect Branch Predictor Barrier (IBPB) Present
Single Thread Indirect Branch Predictors (STIBP) Present
L1D_FLUSH Support Present
IA32_ARCH_CAPABILITIES MSR Present
IA32_CORE_CAPABILITIES MSR Not Present
Speculative Store Bypass Disable (SSBD) Present
Control-Flow Enforcement Technology (CET) Indirect Branch Tracking Not Present
Advanced Matrix Extensions (AMX) Tile Architecture Not Present
Advanced Matrix Extensions (AMX) bfloat16 Support Not Present
Advanced Matrix Extensions (AMX) 8-bit Integer Operations Not Present
AVX (VEX-encoded) Vector Neural Network Instructions Not Present
AVX-512 BFLOAT16 Instructions Not Present
Fast Zero-Length MOVSB Not Present
Fast Short STOSB Not Present
Fast Short CMPSB, SCASB Not Present
History Reset Not Present
Linear Address Masking Not Present
[Vulnerability Mitigation Mechanisms]
Rogue Data Cache Load (RDCL) Not Susceptible
Speculative Store Bypass (SSB) Susceptible
Microarchitectural Data Sampling (MDS) Susceptible
MCE on modifying code page size without TLB invalidation Susceptible
Transactional Asynchronous Abort (TAA) Affected
Indirect Branch Restriction Speculation (IBRS) Not Supported
RSB Alternate Not Supported
L1D Flush on VM Entry Not Needed Supported
[Enhanced Features]
Thermal Monitor 1: Supported, Enabled
Thermal Monitor 2: Supported, Enabled
Enhanced Intel SpeedStep (GV3): Supported, Enabled
Bi-directional PROCHOT#: Enabled
Extended Auto-HALT State C1E: Enabled
MLC Streamer Prefetcher Supported, Enabled
MLC Spatial Prefetcher Supported, Enabled
DCU Streamer Prefetcher Supported, Enabled
DCU IP Prefetcher Supported, Enabled
Intel Dynamic Acceleration (IDA) Technology: Not Supported
Intel Dynamic FSB Switching: Not Supported
Intel Turbo Boost Technology: Supported, Enabled
Programmable Ratio Limits: Supported, Disabled
Programmable TDC/TDP Limits: Supported, Disabled
Hardware Duty Cycling: Supported, Enabled
[CPU SKU Features]
Display HD Audio: Supported
DMI x4 Width: Supported
DRAM ECC: Not Supported
VT-d: Supported
DMI in Gen2 Mode: Supported
PEG in Gen2 Mode: Supported
1N Mode DDR Timings: Supported
Camarillo (DTT) Device: Supported
2 DIMMs per Channel: Supported
X2APIC: Supported
Dual Memory Channel: Supported
Integrated GPU (IGD): Enabled
DDR Overclocking: Enabled
Overclocking by DSKU: Enabled
DDR3L: Supported
Maximum Memory Size per Channel: 64 GB (unlimited)
DDR Frequency 100 MHz RefClk Support: Supported
Hyper-Threading (SMT): Not Supported
Additive Graphics: Supported
Additive Graphics: Enabled
PCIe Gen 3: Supported
DMI Gen 3: Supported
HDCP: Supported
DDR4: Supported
LPDDR3: Not Supported
BCLK OC Limit: 100 MHz
Maximum Supported LPDDR3 Frequency: 1067 MHz
Maximum Supported DDR4 Frequency: 1333 MHz
SVID Status: Enabled
[Voltage Regulator (SVID)]
VCC VR: UPI Semiconductor uP9521P, IMVP8
VR Thermal Sensor: Not Supported
[Memory Ranges]
Maximum Physical Address Size: 39-bit (512 GBytes)
Maximum Virtual Address Size: 48-bit (256 TBytes)
[MTRRs]
Range C0000000-100000000 (3072MB-4096MB) Type: Uncacheable (UC)
Range A0000000-C0000000 (2560MB-3072MB) Type: Uncacheable (UC)
Range 90000000-A0000000 (2304MB-2560MB) Type: Uncacheable (UC)
Range 2000000000-4000000000 (131072MB-262144MB) Type: Uncacheable (UC)
Range 1000000000-2000000000 (65536MB-131072MB) Type: Uncacheable (UC)
Range 800000000-1000000000 (32768MB-65536MB) Type: Uncacheable (UC)
Range 4000000000-8000000000 (262144MB-524288MB) Type: Uncacheable (UC)
Motherboard ---------------------------------------------------------------
[Computer]
Computer Brand Name: Unknown on Noname
[Motherboard]
Motherboard Model: ASRock Z390 Pro4
Motherboard Chipset: Intel Z390 (Cannon Lake-H)
Motherboard Slots: 4xPCI Express x1, 3xPCI Express x4, 1xPCI Express x16
PCI Express Version Supported: v3.0
USB Version Supported: v3.1
[BIOS]
BIOS Manufacturer: American Megatrends
BIOS Date: 03/13/2019
BIOS Version: P4.00
UEFI BIOS: Capable
Super-IO/LPC Chip: Winbond/Nuvoton NCT6791D
Trusted Platform Module (TPM) Chip: Not Found
ACPI Devices --------------------------------------------------------------
Motherboard resources -----------------------------------------------------
Device Name: Motherboard resources
[Assigned Resources]
I/O Port: 1854 - 1857
[Alternative 1]
Programmable interrupt controller -----------------------------------------
Device Name: Programmable interrupt controller
I/O Port: 0020 - 0021
I/O Port: 0030 - 0031
I/O Port: 00A0 - 00A1
I/O Port: 00B0 - 00B1
IRQ: 1114369
IRQ: 1114369
IRQ: 1114369
IRQ: 1114369
[Alternative 1]
I/O Port: 0024 - 0025
I/O Port: 0028 - 0029
I/O Port: 002C - 002D
I/O Port: 0034 - 0035
I/O Port: 0038 - 0039
I/O Port: 003C - 003D
I/O Port: 00A4 - 00A5
I/O Port: 00A8 - 00A9
I/O Port: 00AC - 00AD
I/O Port: 00B4 - 00B5
I/O Port: 00B8 - 00B9
I/O Port: 00BC - 00BD
I/O Port: 04D0 - 04D1
System timer --------------------------------------------------------------
Device Name: System timer
I/O Port: 0040 - 0043
DMA: 0
[Alternative 1]
I/O Port: 0050 - 0053
IRQ: 0
High precision event timer ------------------------------------------------
Device Name: High precision event timer
Memory Location: FED00000 - FED003FF
[Alternative 1]
Communications Port -------------------------------------------------------
Device Name: Communications Port
I/O Port: 03F8 - 03FF
[Alternative 1]
IRQ: 4
[Alternative 2]
IRQ: 4
[Alternative 3]
I/O Port: 02F8 - 02FF
IRQ: 3
[Alternative 4]
I/O Port: 03E8 - 03EF
IRQ: 4
[Alternative 5]
I/O Port: 02E8 - 02EF
IRQ: 3
PCI Express Root Complex --------------------------------------------------
Device Name: PCI Express Root Complex
I/O Port: 0000 - FFFFFFFF
Memory Location: 000A0000 - 000BFFFF
[Alternative 1]
I/O Port: 0000 - 0CF7
I/O Port: 0D00 - FFFF
Memory Location: 90000000 - DFFFFFFF
Memory Location: FC800000 - FE7FFFFF
I/O Port: 0280 - 028F
[Alternative 1]
I/O Port: 0290 - 029F
I/O Port: 02A0 - 02AF
I/O Port: 02B0 - 02BF
Memory Location: FED10000 - FED17FFF
Memory Location: FED20000 - FED3FFFF
[Alternative 1]
Memory Location: FED18000 - FED18FFF
Memory Location: FED19000 - FED19FFF
Memory Location: E0000000 - EFFFFFFF
Memory Location: FED90000 - FED93FFF
Memory Location: FED45000 - FED8FFFF
Memory Location: FEE00000 - FEEFFFFF
I/O Port: 002E - 002F
I/O Port: 0065
I/O Port: 0000 - 006F
I/O Port: 0092
IRQ: 1114369
[Alternative 1]
I/O Port: 004E - 004F
I/O Port: 0061
I/O Port: 0063
I/O Port: 0065
I/O Port: 0067
I/O Port: 0070
I/O Port: 0080
I/O Port: 0092
I/O Port: 00B2 - 00B3
I/O Port: 0680 - 069F
I/O Port: 164E - 164F
Memory Location: FD6E0000 - FD6EFFFF
[Alternative 1]
Memory Location: FD6D0000 - FD6DFFFF
Memory Location: FD6B0000
Memory Location: FD6A0000
IRQ: 14
I/O Port: 2000 - 20FE
[Alternative 1]
Memory Location: FD000000 - FD69FFFF
Memory Location: FE200000 - FE7FFFFF
[Alternative 1]
I/O Port: 1800 - 18FE
Memory Location: FD6C0000 - FD6CFFFF
Memory Location: FD6F0000
Memory Location: FE000000
Memory Location: FF000000
Numeric data processor ----------------------------------------------------
Device Name: Numeric data processor
I/O Port: 00F0
[Alternative 1]
I/O Port: 00F0
IRQ: 13
SMBIOS DMI ----------------------------------------------------------------
BIOS ----------------------------------------------------------------------
BIOS Vendor: American Megatrends Inc.
BIOS Version: P4.00
BIOS Release Date: 03/13/2019
BIOS Start Segment: F000
BIOS Size: 16 MBytes
System BIOS Version: 5.13
ISA Support: Not Present
MCA Support: Not Present
EISA Support: Not Present
PCI Support: Present
PC Card (PCMCIA) Support: Not Present
Plug-and-Play Support: Not Present
APM Support: Not Present
Flash BIOS: Present
BIOS Shadow: Present
VL-VESA Support: Not Present
ESCD Support: Not Present
Boot from CD: Present
Selectable Boot: Present
BIOS ROM Socketed: Present
Boot from PC Card: Not Present
EDD Support: Present
NEC PC-98 Support: Not Present
ACPI Support: Present
USB Legacy Support: Present
AGP Support: Not Present
I2O Boot Support: Not Present
LS-120 Boot Support: Not Present
ATAPI ZIP Drive Boot Support: Not Present
IEE1394 Boot Support: Not Present
Smart Battery Support: Not Present
BIOS Boot Specification Support: Present
Function key-initiated Network Service Boot Support: Not Present
Targeted Content Distribution Support: Present
UEFI Specification Support: Present
Virtual Machine: Not Present
System --------------------------------------------------------------------
System Manufacturer: To Be Filled By O.E.M.
Product Name: To Be Filled By O.E.M.
Product Version: To Be Filled By O.E.M.
Product Serial Number: To Be Filled By O.E.M.
UUID: {ACC28570-F8B8-0000-0000-000000000000}
SKU Number: To Be Filled By O.E.M.
Family: To Be Filled By O.E.M.
Mainboard -----------------------------------------------------------------
Mainboard Manufacturer: ASRock
Mainboard Name: Z390 Pro4
Mainboard Version:
Mainboard Serial Number: M80-BA015800423
Asset Tag:
Location in chassis:
System Enclosure ----------------------------------------------------------
Case Type: Desktop
Asset Tag Number: To Be Filled By O.E.M.
OEM Strings ---------------------------------------------------------------
System Boot Information ---------------------------------------------------
Boot Status: No error occured
Additional Information ----------------------------------------------------
L1 Cache ------------------------------------------------------------------
Socket Designation: L1 Cache
Cache State: Enabled
Cache Location: Internal
Cache Type: L1 Unified
Cache Scheme: Write-Back
Supported SRAM Type: Synchronous
Current SRAM Type: Synchronous
Cache Speed: Unknown
Error Correction Type: Parity
Maximum Cache Size: 384 KBytes
Installed Cache Size: 384 KBytes
Cache Associativity: 8-way Set-Associative
L2 Cache ------------------------------------------------------------------
Socket Designation: L2 Cache
Cache Type: L2 Unified
Error Correction Type: Single-bit ECC
Maximum Cache Size: 1536 KBytes
Installed Cache Size: 1536 KBytes
Cache Associativity: 4-way Set-Associative
L3 Cache ------------------------------------------------------------------
Socket Designation: L3 Cache
Cache Type: L3 Unified
Error Correction Type: Multi-bit ECC
Maximum Cache Size: 9216 KBytes
Installed Cache Size: 9216 KBytes
Cache Associativity: 12-way Set-Associative
Processor -----------------------------------------------------------------
Processor Manufacturer: Intel® Corporation
Processor Version: Intel® Core™ i5-9600K CPU @ 3.70GHz
External Clock: 100 MHz
Maximum Clock Supported: 8300 MHz
Current Clock: 3690 MHz
CPU Socket: Populated
CPU Status: Enabled
Processor Type: Central Processor
Processor Voltage: 0.9 V
Processor Upgrade: Socket LGA1151
Socket Designation: CPUSocket
Intel AMT -----------------------------------------------------------------
Intel AMT Support: Not Supported
Intel vPro ----------------------------------------------------------------
CPU VT-x Support: Supported
CPU VT-x Status: Enabled
CPU VT-x2 Support: Not Supported
CPU VT-x2 Status: Disabled
CPU TXT Support: Supported
CPU TXT Status: Disabled
CPU VMX Status: Enabled
CPU SMX Status: Disabled
Intel ME Status: Enabled
Intel OST Firmware Support: Not Supported
Intel ASF Firmware Support: Not Supported
Intel AMT Pro Firmware Support: Not Supported
Intel AMT Basic Firmware Support: Not Supported
Intel TPM Firmware Support: Not Supported
Intel Castle Peak Support: Not Supported
Intel WoX Support: Not Supported
Intel Virtualization Engine Support: Not Supported
Intel Anti-Theft Technology Support: Not Supported
TPM On-board: Not Supported
Intel Anti-Theft Technology Enrolled: Not Supported
Intel ME Version: v12.0, Build 1123, Hotfix 8
BIOS VT-x Support: Not Supported
BIOS VT-d Support: Supported
BIOS TXT Support: Supported
BIOS TPM Support: Not Supported
BIOS ME Support: Not Supported
BIOS VA Extensions Support: Supported
Intel AT PBA For Recovery Support: Not Supported
Intel AT WWAN Support: Not Supported
On Board Device -----------------------------------------------------------
Device Description: Onboard - Other
Device Type: Unknown
Device Status: Enabled
Device Description: Onboard - SATA
Device Type: SATA Controller
Device Description: Onboard - Sound
Device Type: Audio Device
Device Description: Onboard - Ethernet
Device Type: Ethernet Adapter
Group Associations --------------------------------------------------------
Memory Devices ------------------------------------------------------------
Physical Memory Array -----------------------------------------------------
Array Location: System board
Array Use: System memory
Error Detecting Method: None
Memory Capacity: 64 GBytes
Memory Devices: 4
Memory Device -------------------------------------------------------------
Total Width: 64 bits
Data Width: 64 bits
Device Size: 8192 MBytes
Device Form Factor: DIMM
Device Locator: ChannelA-DIMM0
Bank Locator: BANK 0
Device Type: DDR4
Device Type Detail: Synchronous
Memory Speed: 2133 MHz
Manufacturer: 04CD
Serial Number: 00000000
Part Number: F4-3000C16-8GVRB
Asset Tag: 9876543210
Total Width: 0 bits
Data Width: 0 bits
Device Size: 0 MBytes
Device Locator: ChannelA-DIMM1
Bank Locator: BANK 1
Device Type Detail:
Manufacturer:
Serial Number:
Part Number:
Asset Tag:
Data Width: 64 bits
Device Locator: ChannelB-DIMM0
Bank Locator: BANK 2
Device Type: DDR4
Manufacturer: 04CD
Total Width: 0 bits
Data Width: 0 bits
Device Locator: ChannelB-DIMM1
Bank Locator: BANK 3
Device Type Detail:
Manufacturer:
Serial Number:
Part Number:
Asset Tag:
Memory Array Mapped Address -----------------------------------------------
Starting Address: 00000000
Ending Address: 00FFFFFF
Partition Width: 2
Memory Device Mapped Address ----------------------------------------------
Ending Address: 007FFFFF
Partition Row Position: 1
Interleave Position: 1
Interleave Data Depth: 2
Starting Address: 00800000
Interleave Position: 2
System Slots --------------------------------------------------------------
Slot1 ---------------------------------------------------------------------
Slot Designation: Slot1
Slot Type: PCI Express
Slot Usage: Empty
Slot Data Bus Width: 1x / x1
Slot Length: Short
Base Bus:Device:Function Number: 1:0:2
Slot2 ---------------------------------------------------------------------
Slot Designation: Slot2
Slot Usage: Empty
Slot Data Bus Width: 16x / x16
Slot Length: Long
Base Bus:Device:Function Number: 1:0:0
Slot3 ---------------------------------------------------------------------
Slot Designation: Slot3
Slot Usage: Empty
Slot Length: Short
Base Bus:Device:Function Number: 22:0:2
Slot4 ---------------------------------------------------------------------
Slot Designation: Slot4
Slot Usage: In use
Slot Data Bus Width: 4x / x4
Slot Length: Short
Slot5 ---------------------------------------------------------------------
Slot Designation: Slot5
Slot Usage: Empty
Slot Length: Short
Base Bus:Device:Function Number: 22:0:3
M2_1 ----------------------------------------------------------------------
Slot Designation: M2_1
Slot Usage: Empty
Slot Length: Short
Base Bus:Device:Function Number: 1:0:4
M2_2 ----------------------------------------------------------------------
Slot Designation: M2_2
Slot Usage: Empty
Slot Length: Short
M2_3 ----------------------------------------------------------------------
Slot Designation: M2_3
Slot Usage: Empty
Slot Length: Short
Base Bus:Device:Function Number: 1:0:3
Intel ME ------------------------------------------------------------------
[ME Host Status]
ME Current Working State: Normal
Manufacturing Mode: Not Active
ME Current Operation Mode: Normal
Boot Guard Status: Enabled
Boot Guard Verified Boot Policy: Disabled
Boot Guard Measured Boot Policy: Disabled
[Intel Manageability Engine Features]
Intel ME Version: 12.0, Build 1123, Hot Fix 8
Intel ME Recovery Image Version: 12.0, Build 1123, Hot Fix 8
Intel ME FITC Version: 12.0, Build 1123, Hot Fix 8
[ME Firmware Capabilities]
Full Network Manageability: Not Capable
Standard Network Manageability: Not Capable
Manageability (AMT): Not Capable
Small Business Advantage: Not Capable
Intel Integrated Touch: Not Capable
Intel Anti-Theft: Not Capable
Capability Licensing Service: Capable
Virtualization Engine: Not Capable
Intel Sensor Hub (ISH): Not Capable
ICC Over Clocking: Not Capable
Protected Audio Video Path (PAVP): Capable
Network Frame Forwarder (NFF): Not Capable
Remote PC Assist (RPAT): Capable
IPV6: Not Capable
KVM Remote Control: Not Capable
Outbreak Containment Heuristic (OCH): Not Capable
Dynamic Application Loader (DAL): Capable
Cipher Transport Layer (TLS): Not Capable
Wireless LAN (WLAN): Not Capable
Platform Trust Technology (PTT): Capable
Near Field Communication (NFC): Not Capable
[ME Firmware Feature State]
Full Network Manageability: Disabled
Standard Network Manageability: Disabled
Manageability (AMT): Disabled
MEI3: Not Capable
Intel Anti-Theft: Disabled
Capability Licensing Service: Enabled
Virtualization Engine: Disabled
Intel Sensor Hub (ISH): Disabled
ICC Over Clocking: Disabled
Protected Audio Video Path (PAVP): Enabled
Remote PC Assist (RPAT): Enabled
IPV6: Disabled
KVM Remote Control: Disabled
Outbreak Containment Heuristic (OCH): Disabled
Cipher Transport Layer (TLS): Disabled
Wireless LAN (WLAN): Disabled
Platform Trust Technology (PTT): Disabled
Near Field Communication (NFC): Disabled
[ME Firmware Platform Type]
Platform Target Usage Type: Desktop
SKU: Regular SKU
ME Firmware Image Type: Consumer SKU Firmware
Platform Brand: None
Host ME Region Flash Protection Override (HMRFPO) Status: Disabled
Memory --------------------------------------------------------------------
[General information]
Total Memory Size: 16 GBytes
Total Memory Size [MB]: 16384
[Current Performance Settings]
Maximum Supported Memory Clock: 1333.3 MHz
Current Memory Clock: 1064.1 MHz
Current Timing (tCAS-tRCD-tRP-tRAS): 15-15-15-36
Memory Channels Supported: 2
Memory Channels Active: 2
Command Rate: 2T
Read to Read Delay (tRDRD_SG/TrdrdScL) Same Bank Group: 6T
Read to Read Delay (tRDRD_DG/TrdrdScDlr) Different Bank Group: 4T
Read to Read Delay (tRDRD_SD) Same DIMM: 6T
Read to Read Delay (tRDRD_DD) Different DIMM: 7T
Write to Write Delay (tWRWR_SG/TwrwrScL) Same Bank Group: 6T
Write to Write Delay (tWRWR_DG/TwrwrScDlr) Different Bank Group: 4T
Write to Write Delay (tWRWR_SD) Same DIMM: 7T
Write to Write Delay (tWRWR_DD) Different DIMM: 7T
Read to Write Delay (tRDWR_SG/TrdwrScL) Same Bank Group: 10T
Read to Write Delay (tRDWR_DG/TrdwrScDlr) Different Bank Group: 10T
Read to Write Delay (tRDWR_SD) Same DIMM: 10T
Read to Write Delay (tRDWR_DD) Different DIMM: 11T
Write to Read Delay (tWRRD_SG/TwrrdScL) Same Bank Group: 28T
Write to Read Delay (tWRRD_DG/TwrrdScDlr) Different Bank Group: 23T
Write to Read Delay (tWRRD_SD) Same DIMM: 6T
Write to Read Delay (tWRRD_DD) Different DIMM: 6T
RAS# to RAS# Delay (tRRD): 6T
Row Cycle Time (tRC): 51T
Refresh Cycle Time (tRFC): 373T
Four Activate Window (tFAW): 23T
Row: 0 [BANK 0/ChannelA-DIMM0] - 8 GB PC4-24000 DDR4 SDRAM G Skill F4-3000C16-8GVRB
[General Module Information]
Module Number: 0
Module Size: 8 GBytes
Memory Type: DDR4 SDRAM
Module Type: Unbuffered DIMM (UDIMM)
Memory Speed: 1501.5 MHz (DDR4-3003 / PC4-24000)
Module Manufacturer: G Skill
Module Part Number: F4-3000C16-8GVRB
Module Revision: 0.0
Module Serial Number: N/A
Module Manufacturing Date: N/A
Module Manufacturing Location: 0
SDRAM Manufacturer: SK Hynix
DRAM Steppping: 0.0
Error Check/Correction: None
[Module Characteristics]
Row Address Bits: 16
Column Address Bits: 10
Module Density: 8192 Mb
Number Of Ranks: 1
Number Of Bank Groups: 4
Device Width: 8 bits
Bus Width: 64 bits
Die Count: 1
Module Nominal Voltage (VDD): 1.2 V
Minimum SDRAM Cycle Time (tCKAVGmin): 0.93800 ns (1066 MHz)
Maximum SDRAM Cycle Time (tCKAVGmax): 1.60000 ns
CAS# Latencies Supported: 10, 11, 12, 13, 14, 15, 16
Minimum CAS# Latency Time (tAAmin): 13.750 ns
Minimum RAS# to CAS# Delay (tRCDmin): 13.750 ns
Minimum Row Precharge Time (tRPmin): 13.750 ns
Minimum Active to Precharge Time (tRASmin): 33.000 ns
Supported Module Timing at 1066.7 MHz: 15-15-15-36
Supported Module Timing at 933.3 MHz: 13-13-13-31
Supported Module Timing at 800.0 MHz: 11-11-11-27
Supported Module Timing at 666.7 MHz: 10-10-10-22
Minimum Active to Active/Refresh Time (tRCmin): 46.750 ns
Minimum Refresh Recovery Time Delay (tRFC1min): 350.000 ns
Minimum Refresh Recovery Time Delay (tRFC2min): 260.000 ns
Minimum Refresh Recovery Time Delay (tRFC4min): 160.000 ns
Minimum Four Activate Window Delay Time (tFAWmin): 21.000 ns
Minimum Active to Active Delay Time - Different Bank Group (tRRD_Smin): 3.700 ns
Minimum Active to Active Delay Time - Same Bank Group (tRRD_Lmin): 5.300 ns
Minimum CAS to CAS Delay Time - Same Bank Group (tCCD_Lmin): 5.625 ns
[Features]
Module Temperature Sensor (TSOD): Not Supported
Module Nominal Height: 31 - 32 mm
Module Maximum Thickness (Front): 1 - 2 mm
Module Maximum Thickness (Back): 1 - 2 mm
Address Mapping from Edge Connector to DRAM: Standard
[Intel Extreme Memory Profile (XMP)]
XMP Revision: 2.0
[Certified Profile [Enabled]]
Module VDD Voltage Level: 1.35 V
Minimum SDRAM Cycle Time (tCKAVGmin): 0.66600 ns (1500 MHz)
CAS# Latencies Supported: 16
Minimum CAS# Latency Time (tAAmin): 10.593 ns
Minimum RAS# to CAS# Delay (tRCDmin): 11.761 ns
Minimum Row Precharge Time (tRPmin): 11.761 ns
Minimum Active to Precharge Time (tRASmin): 25.250 ns
Supported Module Timing at 1500.0 MHz: 16-18-18-38
Supported Module Timing at 1466.7 MHz: 16-18-18-38
Minimum Active to Active/Refresh Time (tRCmin): 37.250 ns
Minimum Active to Active Delay Time - Different Bank Group (tRRD_Smin): 3.500 ns
Minimum Active to Active Delay Time - Same Bank Group (tRRD_Lmin): 5.000 ns
Row: 2 [BANK 2/ChannelB-DIMM0] - 8 GB PC4-24000 DDR4 SDRAM G Skill F4-3000C16-8GVRB
Module Number: 2
DRAM Steppping: 0.0
Number Of Ranks: 1
Bus Width: 64 bits
Die Count: 1
[Features]
XMP Revision: 2.0
Bus -----------------------------------------------------------------------
PCI Bus #0 ----------------------------------------------------------------
Intel Coffee Lake-S 6 - Host Bridge/DRAM Controller -----------------------
Device Name: Intel Coffee Lake-S 6 - Host Bridge/DRAM Controller
Original Device Name: Intel Coffee Lake-S 6 - Host Bridge/DRAM Controller
Device Class: Host-to-PCI Bridge
Revision ID: A
PCI Address (Bus:Device:Function) Number: 0:0:0
PCI Latency Timer: 0
Hardware ID: PCI\VEN_8086&DEV_3EC2&SUBSYS_3EC21849&REV_0A
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Bus Mastering: Enabled
Running At 66 MHz: Not Capable
Fast Back-to-Back Transactions: Capable
[Driver Information]
Driver Manufacturer: INTEL
Driver Description: Intel® Host Bridge/DRAM Registers - 3EC2
Driver Provider: INTEL
Driver Version: 10.1.14.7
DeviceInstanceId PCI\VEN_8086&DEV_3EC2&SUBSYS_3EC21849&REV_0A\3&11583659&0&00
Location Paths PCIROOT(0)#PCI(0000)
Intel Cannon Lake-H/S - Thermal Subsystem [B0] ----------------------------
Device Name: Intel Cannon Lake-H/S - Thermal Subsystem [B0]
Original Device Name: Intel Cannon Lake-H/S - Thermal Subsystem [B0]
Device Class: Other Data Acquisition/Signal Processing Controller
Revision ID: 10 [B0]
PCI Address (Bus:Device:Function) Number: 0:18:0
Hardware ID: PCI\VEN_8086&DEV_A379&SUBSYS_A3791849&REV_10
[System Resources]
Interrupt Line: N/A
Interrupt Pin: INTA#
Memory Base Address 0 0
[Features]
Bus Mastering: Disabled
Fast Back-to-Back Transactions: Not Capable
Driver Description: Intel® Thermal Subsystem - A379
Driver Version: 10.1.16.7
DeviceInstanceId PCI\VEN_8086&DEV_A379&SUBSYS_A3791849&REV_10\3&11583659&0&90
Location Paths PCIROOT(0)#PCI(1200)
Intel Cannon Lake-H/S - USB 3.1 xHCI Host Controller [B0] -----------------
Device Name: Intel Cannon Lake-H/S - USB 3.1 xHCI Host Controller [B0]
Original Device Name: Intel Cannon Lake-H/S - USB 3.1 xHCI Host Controller [B0]
Device Class: USB xHCI Controller
PCI Address (Bus:Device:Function) Number: 0:20:0
Hardware ID: PCI\VEN_8086&DEV_A36D&SUBSYS_A36D1849&REV_10
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 A3220000
[Features]
Driver Manufacturer: Generic USB xHCI Host Controller
Driver Description: USB xHCI Compliant Host Controller
Driver Provider: Microsoft
Driver Version: 10.0.19041.1081
Driver Date: 06-Jun-2021
DeviceInstanceId PCI\VEN_8086&DEV_A36D&SUBSYS_A36D1849&REV_10\3&11583659&0&A0
Location Paths PCIROOT(0)#PCI(1400)
Intel Cannon Lake-H/S - Shared SRAM [B0] ----------------------------------
Device Name: Intel Cannon Lake-H/S - Shared SRAM [B0]
Original Device Name: Intel Cannon Lake-H/S - Shared SRAM [B0]
Device Class: RAM/Memory Controller
PCI Address (Bus:Device:Function) Number: 0:20:2
Hardware ID: PCI\VEN_8086&DEV_A36F&SUBSYS_A36F1849&REV_10
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
Memory Base Address 2 0
[Features]
Driver Manufacturer: (Standard system devices)
Driver Description: PCI standard RAM Controller
Driver Date: 20-Jun-2006
DeviceInstanceId PCI\VEN_8086&DEV_A36F&SUBSYS_A36F1849&REV_10\3&11583659&0&A2
Location Paths PCIROOT(0)#PCI(1402)
Intel Cannon Lake-H/S - HECI #1 [B0] --------------------------------------
Device Name: Intel Cannon Lake-H/S - HECI #1 [B0]
Original Device Name: Intel Cannon Lake-H/S - HECI #1 [B0]
Device Class: Other Communication Device
PCI Address (Bus:Device:Function) Number: 0:22:0
Hardware ID: PCI\VEN_8086&DEV_A360&SUBSYS_A3601849&REV_10
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 FE1FF000
[Features]
Driver Manufacturer: Intel
Driver Description: Intel® Management Engine Interface
Driver Provider: Intel
Driver Version: 1914.12.0.1256
Driver Date: 03-Apr-2019
DeviceInstanceId PCI\VEN_8086&DEV_A360&SUBSYS_A3601849&REV_10\3&11583659&0&B0
Location Paths PCIROOT(0)#PCI(1600)
Intel Cannon Lake-H/S - SATA AHCI Controller (DT/SRV) [B0] ----------------
Device Name: Intel Cannon Lake-H/S - SATA AHCI Controller (DT/SRV) [B0]
Original Device Name: Intel Cannon Lake-H/S - SATA AHCI Controller (DT/SRV) [B0]
Device Class: SATA AHCI Controller
PCI Address (Bus:Device:Function) Number: 0:23:0
Hardware ID: PCI\VEN_8086&DEV_A352&SUBSYS_A3521849&REV_10
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 A3234000
Memory Base Address 1 A323A000
I/O Base Address 2 4050
I/O Base Address 3 4040
I/O Base Address 4 4020
Memory Base Address 5 A3239000
[Features]
Running At 66 MHz: Capable
[SATA Host Controller]
[SATA Port#0]
[SATA Port#1]
[SATA Port#2]
[SATA Port#3]
[SATA Port#4]
[SATA Port#5]
Driver Manufacturer: Intel Corporation
Driver Description: Intel® 300 Series Chipset Family SATA AHCI Controller
Driver Provider: Intel Corporation
Driver Version: 17.5.0.1017
Driver Date: 08-May-2019
DeviceInstanceId PCI\VEN_8086&DEV_A352&SUBSYS_A3521849&REV_10\3&11583659&0&B8
Location Paths PCIROOT(0)#PCI(1700)
Intel Cannon Lake-H/S - PCI Express Root Port #5 [B0] ---------------------
Device Name: Intel Cannon Lake-H/S - PCI Express Root Port #5 [B0]
Original Device Name: Intel Cannon Lake-H/S - PCI Express Root Port #5 [B0]
Device Class: PCI-to-PCI Bridge
Revision ID: F0 [B0]
PCI Address (Bus:Device:Function) Number: 0:28:0
Hardware ID: PCI\VEN_8086&DEV_A33C&SUBSYS_00000000&REV_F0
[PCI Express]
Version: 3.0
Maximum Link Width: 4x
Current Link Width: 4x
Maximum Link Speed: 8.0 GT/s
Current Link Speed: 8.0 GT/s
Device/Port Type: Root Port of PCI Express Root Complex
Slot Implemented: Yes
Hot-Plug: Not Capable
Hot-Plug Surprise: Not Capable
Slot Power Limit: 25.000 W
Emergency Power Reduction: Not Supported
Active State Power Management (ASPM) Support: None
Active State Power Management (ASPM) Status: Disabled
L0s Exit Latency: 512 ns - 1 us
L1 Exit Latency: 8 - 16 us
Maximum Payload Size Supported: 256 bytes
Maximum Payload Size: 256 bytes
Resizable BAR Support: Not Supported
[System Resources]
Interrupt Line: IRQ11
[Features]
Driver Description: Intel® PCI Express Root Port #5 - A33C
DeviceInstanceId PCI\VEN_8086&DEV_A33C&SUBSYS_A33C1849&REV_F0\3&11583659&0&E0
Location Paths PCIROOT(0)#PCI(1C00)
PCI Express x4 Bus #1 -----------------------------------------------------
MSI GTX 1070 Ti -----------------------------------------------------------
Device Name: MSI GTX 1070 Ti
Original Device Name: NVIDIA GeForce GTX 1070 Ti (GP104-300)
Device Class: VGA Compatible Adapter
Revision ID: A1
PCI Address (Bus:Device:Function) Number: 1:0:0
Hardware ID: PCI\VEN_10DE&DEV_1B82&SUBSYS_C3041462&REV_A1
[PCI Express]
Version: 3.0
Maximum Link Width: 16x
Device/Port Type: Legacy PCI Express Endpoint
Slot Implemented: No
Active State Power Management (ASPM) Support: L0s and L1
L1 Exit Latency: 2 - 4 us
[System Resources]
Interrupt Line: IRQ16
Memory Base Address 0 A2000000
Memory Base Address 1 90000000
Memory Base Address 3 A0000000
I/O Base Address 5 3000
[Features]
Driver Manufacturer: NVIDIA
Driver Description: NVIDIA GeForce GTX 1070 Ti
Driver Provider: NVIDIA
Driver Version: 30.0.14.7141 (GeForce 471.41)
Driver Date: 11-Jul-2021
DCH/UWD Driver: Capable
DeviceInstanceId PCI\VEN_10DE&DEV_1B82&SUBSYS_C3041462&REV_A1\4&3174068&0&00E0
Location Paths PCIROOT(0)#PCI(1C00)#PCI(0000)
NVIDIA GP104 - High Definition Audio Controller ---------------------------
Device Name: NVIDIA GP104 - High Definition Audio Controller
Original Device Name: NVIDIA GP104 - High Definition Audio Controller
Device Class: High Definition Audio
Revision ID: A1
PCI Address (Bus:Device:Function) Number: 1:0:1
Hardware ID: PCI\VEN_10DE&DEV_10F0&SUBSYS_C3041462&REV_A1
[PCI Express]
Version: 3.0
Device/Port Type: PCI Express Endpoint
Active State Power Management (ASPM) Status: L0s and L1 Entry
[System Resources]
Interrupt Line: IRQ17
Interrupt Pin: INTB#
Memory Base Address 0 A3080000
[Features]
Driver Manufacturer: Microsoft
Driver Description: High Definition Audio Controller
Driver Date: 07-Jun-2021
DeviceInstanceId PCI\VEN_10DE&DEV_10F0&SUBSYS_C3041462&REV_A1\4&3174068&0&01E0
Location Paths PCIROOT(0)#PCI(1C00)#PCI(0001)
Intel Z390 PCH (Cannon Lake-H) - LPC Controller/eSPI Controller [B0] ------
Device Name: Intel Z390 PCH (Cannon Lake-H) - LPC Controller/eSPI Controller [B0]
Original Device Name: Intel Z390 PCH (Cannon Lake-H) - LPC Controller/eSPI Controller [B0]
Device Class: PCI-to-ISA Bridge
PCI Address (Bus:Device:Function) Number: 0:31:0
Hardware ID: PCI\VEN_8086&DEV_A305&SUBSYS_A3051849&REV_10
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
[Features]
Driver Description: Intel® 300 Series Chipset Family LPC Controller (Z390) - A305
DeviceInstanceId PCI\VEN_8086&DEV_A305&SUBSYS_A3051849&REV_10\3&11583659&0&F8
Location Paths PCIROOT(0)#PCI(1F00)
Intel Cannon Lake-H/S - cAVS (Audio, Voice, Speech) [B0] ------------------
Device Name: Intel Cannon Lake-H/S - cAVS (Audio, Voice, Speech) [B0]
Original Device Name: Intel Cannon Lake-H/S - cAVS (Audio, Voice, Speech) [B0]
PCI Address (Bus:Device:Function) Number: 0:31:3
PCI Latency Timer: 32
Hardware ID: PCI\VEN_8086&DEV_A348&SUBSYS_58921849&REV_10
[System Resources]
Memory Base Address 0 A3230000
Memory Base Address 4 A3100000
[Features]
DeviceInstanceId PCI\VEN_8086&DEV_A348&SUBSYS_58921849&REV_10\3&11583659&0&FB
Location Paths PCIROOT(0)#PCI(1F03)
Intel Cannon Lake-H/S - SMBus Controller [B0] -----------------------------
Device Name: Intel Cannon Lake-H/S - SMBus Controller [B0]
Original Device Name: Intel Cannon Lake-H/S - SMBus Controller [B0]
Device Class: SMBus (System Management Bus)
PCI Address (Bus:Device:Function) Number: 0:31:4
Hardware ID: PCI\VEN_8086&DEV_A323&SUBSYS_A3231849&REV_10
[System Resources]
Memory Base Address 0 A3238000
I/O Base Address 4 EFA0
[Features]
Driver Description: Intel® SMBus - A323
DeviceInstanceId PCI\VEN_8086&DEV_A323&SUBSYS_A3231849&REV_10\3&11583659&0&FC
Location Paths PCIROOT(0)#PCI(1F04)
Intel Cannon Lake-H/S - SPI (flash) Controller [B0] -----------------------
Device Name: Intel Cannon Lake-H/S - SPI (flash) Controller [B0]
Original Device Name: Intel Cannon Lake-H/S - SPI (flash) Controller [B0]
Device Class: Other Serial Bus Controller
PCI Address (Bus:Device:Function) Number: 0:31:5
Hardware ID: PCI\VEN_8086&DEV_A324&SUBSYS_A3241849&REV_10
[System Resources]
Interrupt Line: N/A
Interrupt Pin: N/A
Memory Base Address 0 FE010000
[Features]
Driver Description: Intel® SPI (flash) Controller - A324
DeviceInstanceId PCI\VEN_8086&DEV_A324&SUBSYS_A3241849&REV_10\3&11583659&0&FD
Location Paths PCIROOT(0)#PCI(1F05)
Intel Ethernet Connection I219-V ------------------------------------------
Device Name: Intel Ethernet Connection I219-V
Original Device Name: Intel Ethernet Connection I219-V
Device Class: Ethernet Adapter
Revision ID: 10
PCI Address (Bus:Device:Function) Number: 0:31:6
Hardware ID: PCI\VEN_8086&DEV_15BC&SUBSYS_15BC1849&REV_10
[System Resources]
Interrupt Line: N/A
Memory Base Address 0 A3200000
[Features]
Driver Description: Intel® Ethernet Connection (7) I219-V
Driver Version: 12.18.9.7
Driver Date: 06-May-2019
DeviceInstanceId PCI\VEN_8086&DEV_15BC&SUBSYS_15BC1849&REV_10\3&11583659&0&FE
Location Paths PCIROOT(0)#PCI(1F06)
Video Adapter -------------------------------------------------------------
NVIDIA GeForce GTX 1070 Ti ------------------------------------------------
[Video chipset]
Video Chipset: NVIDIA GeForce GTX 1070 Ti
Video Chipset Codename: GP104-300
Video Memory: 8192 MBytes of GDDR5 SDRAM [Micron]
[Video Card]
Video Card: MSI GTX 1070 Ti
Video Bus: PCIe v3.0 x16 (8.0 GT/s) @ x4 (8.0 GT/s)
Video RAMDAC: Integrated RAMDAC
Video BIOS Version: 86.04.85.00.98
Video Chipset Revision: A1
[Performance]
Graphics Processor Clock: 1607.0 MHz
Video Unit Clock: 1442.5 MHz
Graphics Memory Clock: 2003.4 MHz (Effective 8013.6 MHz)
Graphics Memory Bus Width: 256-bit
Number Of ROPs: 64
Number Of Unified Shaders: 2432
Number Of TMUs (Texture Mapping Units): 152
ASIC Serial Number: 300236671377
NVIDIA SLI Status: Not Present
PCI Location (Bus:Dev:Fnc): 1:00:0
2021/08/09 15:13
Case panel was removed per someone’s suggestion. Got shutdown while watching YouTube for about 10 minutes. Went to bios and was told CPU was at 107C.
Cooler attached to cpu was warm. Tubes barely warm.
At boot.
A few minutes later.
Is the problem with my CPU or my MB?
