Booting the USB installer will result in an unhelpful black screen and/or possibly some video corruption (at least, as of the time of this writing).
Your best bet is to hit ‘e’ on the “Install Ubuntu / Try Ubuntu” screen and add a space and nomodeset to the end of the line that starts with linux.
(scr)
ctrl-e or F10 will continue the bootup process. From there you should get to a graphical installer that we all know and love.
Install as normal. NOTE: I recommend unplugging or removing any drives on which you don’t intend to install Linux. Dual booting? Remove that drive. Duel Booting for VFIO stuff? Remove the windows drive. It’s just easier, especially if you’re unsure of yourself. The Ubuntu installer can detect windows, too, which can make things overly complicated for newbies. So, please, remove any drives that have anything important and make backups before you get started.
Booting into Ubuntu won’t work either. On my install I got kernel 4.15 – you will have to hit ‘e’ again early in the bootup process and add nomodeset to get the system to boot.
What’s going on here is that the Linux Kernel is too out of date to work with the new RX590 silicon. There were some changes to power management, apparently to enable higher boost clocks, on the RX590 which will crash the card when the software driver uses.
We can use the Ubuntu Kernel Update Utility (ukuu) to make the update process easier. However, we will also need updated firmware for Polaris.
First, install UKUU
Then install Kernel 4.20, 4.20.1 or newer.
Finally, we will need some firmware from here:
https://people.freedesktop.org/~agd5f/radeon_ucode/
The polaris* files dated for december go in /lib/firmware/amdgpu on your local system. I like to do it from the terminal, but there is no reason you can’t use Firefox to just save those files then use the ‘Files’ program to move them over.
sudo wget https://people.freedesktop.org/~agd5f/radeon_ucode/polaris10_k_mc.bin
It isn’t necessary to do this for all the files. If you want to be sure, you can run dmesg in a terminal to find out what firmware files you need:
# dmesg |grep firmware
[ 0.942424] amdgpu 0000:09:00.0: Direct firmware load for amdgpu/polaris10_k_mc.bin failed with error -2
[ 0.942424] mc: Failed to load firmware "amdgpu/polaris10_k_mc.bin"
[ 0.942469] [drm:gmc_v8_0_sw_init [amdgpu]] *ERROR* Failed to load mc firmware!
[ 4.109598] r8822be: Using firmware rtlwifi/rtl8822befw.bin
You will also need to update the initial ram FS once all these are downloaded. I do this from the terminal:
You should see something like:
sudo update-initramfs -k all -u
update-initramfs: Generating /boot/initrd.img-4.20.0-042000-generic
Which tells us it is making the initial ram disk for kernel 4.20 which was setup with the Ukuu GUI earlier.
Note that you may also get a bunch of warnings:
W: Possible missing firmware /lib/firmware/amdgpu/raven2_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_gpu_info.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_k_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_k_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/mullins_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/mullins_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/mullins_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/mullins_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/mullins_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kabini_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kabini_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kabini_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kabini_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kabini_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/mullins_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/mullins_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kabini_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kabini_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/si58_mc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hainan_mc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/oland_mc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/verde_mc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/pitcairn_mc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/tahiti_mc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hainan_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hainan_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hainan_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hainan_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/oland_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/oland_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/oland_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/oland_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/verde_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/verde_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/verde_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/verde_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/pitcairn_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/pitcairn_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/pitcairn_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/pitcairn_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/tahiti_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/tahiti_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/tahiti_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/tahiti_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/banks_k_2_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hainan_k_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hainan_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/oland_k_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/oland_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/verde_k_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/verde_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/pitcairn_k_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/pitcairn_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/tahiti_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_mc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_mc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/polaris11_k_mc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_asd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_sos.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven2_asd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_asd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_sos.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven2_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven2_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven2_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven2_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven2_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven2_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_rlc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_mec2.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_mec.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_me.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_pfp.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_ce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven2_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_sdma1.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_sdma.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_uvd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_uvd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_uvd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/mullins_uvd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_uvd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_uvd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kabini_uvd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_uvd.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_vce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_vce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_vce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/mullins_vce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/hawaii_vce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kaveri_vce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/kabini_vce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/bonaire_vce.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven2_vcn.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/picasso_vcn.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega20_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vega12_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/vegam_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/polaris11_k2_smc.bin for module amdgpu
W: Possible missing firmware /lib/firmware/amdgpu/raven_dmcu.bin for module amdgpu
That is OK. These firmware files aren’t there yet because Ubuntu hasn’t caught up. You can download them from the same website – but they only apply to specific video cards. You can see the codenames in there – polaris, vega, kaveri, hawaii, etc – in general you only need the firmware file(s) that apply to your specific gpu.
Once that’s done reboot, run the dmesg command again and verify it found & loaded the firmware.
Without this, advanced features of the graphics card (like 3d acceleration) doesn’t seem possible.
For some reason on my system mesa was not functioning properly.
I used this to correct the issue:
sudo add-apt-repository ppa:paulo-miguel-dias/pkppa
sudo apt update
sudo apt upgrade
sudo apt install mesa-utils mesa-vulkan-drivers
From there I could install Steam:
sudo apt install steam
And the steam icon was in my shortcut list.
Begin Quality of Life Detour.
This, being a new system, needs some quality-of-life fixes. One of my favorite utilities is cpufreq which lets me see what speed the CPU is at and to set the performance profile of the system easily. Let’s set that up.
first
apt install chrome-gnome-shell
then visit
https://extensions.gnome.org/extension/1082/cpufreq/
with Firefox. Install the Gnome Firefox extension, and reload the page in Firefox.
Once you do that you will have a toggle in the upper right. Toggle “On” the CPUFreq extension. Once that is on, you will get the CPU speed in the top right.
On my system I found it necessary to uninstall irqbalance – an older utility for balancing interrupts across processors. It usually causes more trouble than it saves.
sudo apt remove irqbalance
I also hit the "Install…’ option on CPUFreq to give me some more fine-grained control of the CPU performance.
End Detour.
At this point, you really should reboot. You should not have to enter nomodeset to get to a graphical desktop in Ubuntu (since you should be running a newer kernel). Verify the firmware situation is fine with the dmesg command and we can move on to making sure that Steam, and mesa, are suitable for playing games.
$ dmesg |grep firmware
[ 0.945582] [drm] Found UVD firmware Version: 1.130 Family ID: 16
[ 0.946056] [drm] Found VCE firmware Version: 52.4 Binary ID: 3
[ 4.047513] r8822be: Using firmware rtlwifi/rtl8822befw.bin
This is good to see. Firmware was loaded for the RX590 successfully. [The last line is the WiFi firmware. Your system might have other firmware files you need, so beware of that. Not having the WiFi firmware, for me, would not be fatal to having a working system.]
but now I want to buy a M.2 for just linux goddamit
