[Resolved] White noise when not playing audio
Hello,
I having this weird issue in Fedora 31 (and 30) where my headphones get a hissing sound when there is no audio playing. I am using an external DAC connected using SPDIF.
If I unplug the DAC cable, the same hissing sound appears, which seems to indicate that the DAC isn’t receiving a signal. However, I never have this issue in Windows.
Also, if I open pavucontrol, the hissing also stops, which is a temporary but annoying workaround.
Is there a way to fix this? Is this some sort of power management thing?
Thanks for any help.
EDIT: doing sudo echo 0 > /sys/module/snd_hda_intel/parameters/power_save fixed the issue!
this is usually due to pulseaudio module that suspends audio playback to save power
to check further use:
pactl unload-module module-suspend-on-idle
and should be able to close pavucontrol without problem returning
permanent fix requires edit to /etc/pulse/default.pa
add ‘#’ to comment out line to load module
#load-module module-suspend-on-idle
And there I was thinking I was the only one with that issue.
Funny enough, even when playing a video on mute the noise stops. It’s inaudible on my headphones, but annoying on the 10$ speakers.
Definitely going to try that later.
it is only time i have heard of constant hissing noise mentioned
but some users had issues with USB interfaces making horrible noises when powering up
mention of leaving pavucontrol open was the clue that it was likely suspend-on-idle module - only module that affects power
never seen the change to snd_intel_hda parameter used before. noted as another option if pulseuadio solution ever fails
Can confirm the fix works for me (onboard sound on the X470 Gaming 7).
Thanks for that!
Really wonder how that works on an electronics level though… as I mentioned even when playing videos on mute silenced it…
This thread is quite a few years old now, but I’m gonna put it here anyway because it’s the same issue.
On PipeWire with Wireplumber the fix looks something like this:
❯ cat ~/.config/wireplumber/wireplumber.conf.d/50-disable-suspend.conf
monitor.alsa.rules = [
    matches = [
      # This matches the value of the 'node.name' property of the node.
        node.name = "~alsa_output.*"
    actions = {
      # Apply all the desired node specific settings here.
      update-props = {
        session.suspend-timeout-seconds = 0
Obviously the node.name needs to be adjusted to whatever your device is. This is straight from the Wireplumber documentation.
Restarting the Wireplumber service should be enough, but I had to reboot for it to actually work, no idea why.
If you’re on a multi-user system and want to do this systemwide it can be done via /etc instead.
