I would prefer exactly 5 m.2 slots, if possible on a new standard that puts it at 90 degrees on the motherboard, kinda like the asus RAM module (dimm.2?) adapter, or preferably just a soldered 90 degree connector with a plastic board underneath it that holds the m.2 in there. I don’t like the pci-e x1 to m.2, or worse, the splitters from x4 pci-e to m.2 x2 or m.2 x4, because those use bridges, I want them as close to the CPU as possible.
If I were to choose between m.2 and PCI-E slots though, I’d choose PCI-E and use adapters.
Because it might either require PCI-E bifurcation, which not all boards support, so I’d rather not take my risks, or it has a PCI-E switch, which introduces latency.
Back in June I started working on a VR flight sim rig and after some research I went for Honeycomb and Thrustmaster peripherals, but since June RTX3080Ti dropped a bit in price and RTX4080 is coming shortly and promising to do a lot for MS Flight Sim.
5800X3D is really bitch slapping anything else right now, yes even the Ryzen 9 7950X and Core i9 12900KS are ~27% behind in this one game.
The thing is I’ve been waiting for years now, first for MS Flight Sim to get the VR update, then for GPU prices to go down, then for Zen 4, and since UPS managed to lose my peripherals I have some time to build the PC and maybe gimp along with RTX3050 until the next gen nVidia comes along.
I have the opportunity to acquire an MSI Tomahawk B550 for my system, which is currently running an ASRock X370 Fatal1ty Professional, which at the moment is making me miss out on a few features such as PCI-E 4.0 (seeing as i have a PCI-E 4.0 compatible GPU and NVMEs are getting cheaper by the minute), but i also don’t intend to change my 3800x so soon, seeing as i believe it is quite sufficient for my needs.
So, should i:
What is the specific games you are playing with your PCIe Gen4? I also, I dont think we can hit the bandwidth limit of Gen3 yet? Not sure about next gen 4000 series Nvidia or 7000 series Radeon but IIRC we cant reach sustained limits of the Gen3, unless you are doing encoding or rendering.
At the moment I’m playing Judgement.
But you’re right, after I posted the poll I went to look after some benchmarks on 4.0 and 3.0 and they seem to be pretty matched.
Only thing would be the speed bandwidth for the SSDs, but then again for my usage it would be more luxury than need.
I took my test with another female student the school had. I was going to ask her out but she failed her test. I failed my first CDL test. Did not swing wide enough on a left turn.
Same. I like muh wires.
I bought this unreviewed for 30 out the door.
Well specd for the price at the time.
It fit the bill, wasnt obnoxious w rgb, doesnt need software to cycle through colors (I leave on red as a night light and the only visable rgb). Its been a good enough fit for me.
In that case just buy any name-brand brick with a wire.
My vote goes towards the mouse with a G502-esque shape, that is currently on sale in your region.
