Please see the product page and the thread here on L1T if you want more details on what the Pinebook Pro is and what it represents. And special thanks to @Luke_PINE64 and the rest of Pine64 and the community for conceiving this! (Not an ad BTW, I paid for my Pinebook Pro with my own money and am writing this review on my own volition.)
Physical
The laptop feels outstanding for its $200 price tag, it honestly feels as good or better than my HP Envy x360. The body is made of a magnesium alloy and is quite rigid. The screen, which is normally the most flexible part of the body, feels rigid and strong. The underside of the chassis is also held in with just some small phillips head screws, so servicability should be pretty easy.
Speaking of screen, I canāt fault the 1080p IPS screen either. Mine has no dead or stuck pixels, nor is the IPS glow too bad. The whites seem to be a bit cool, and the colors slightly muted, but thatās comparing it to IPS displays that cost well more than the entire device. As best I can tell it is connected via eDP, so in theory a user could swap it out with another screen if desired.
The keyboard is fine, itās not the worst feeling keyboard Iāve ever felt, nor is it the greatest. Overall it gets the job done. Mine did come with an ISO layout physically, but ANSI logically which messed me up at first, but even as Iām typing this review up Iām getting used to the layout. ANSI is coming down the pipeline from what I hear. I honestly could have picked ISO by accident, it wouldnāt surprise me.
It is mostly personal, but I find the trackpad to be my first real complaint. I loathe textured trackpads to get that out of the way. I am also running into an issue where sometimes when I go to click the cursor shoots down and left. It may be because I move the pointer with my middle finger and click with my index finger and the trackpad misreading it. Luke at Pine64 says there is a firmware fix coming for the trackpad soonā¢.
Speakers are meh, but so are just about all laptop speakers. They are mounted on the bottom which I find kind of odd, but if somebody cares about audio quality they shouldnāt really be looking at integrated laptop speakers anyways. The audio from the headphone jack seems normal for lack of better words.
Ports are pretty normal. On the left side of the chassis is the power jack, a USB A, and USB C (with video!). The right is another USB A, headphone/mic/UART jack, and a microSD slot.
Software
I feel pretty dumb because almost all issues I had with software was solved by logging into the ārockā account and not the ārootā account.
People will be glad to know that Debian on the Pinebook Pro is, well, Debian. It looks like Debian, feels like Debian, it might even smell and taste like Debian. I was honestly expecting a dumpster fire because of Arm still being as niche as it is, but honestly I havenāt noticed a difference for the most part. From my limited testing it appears that some programs wonāt work because it is Arm, but others work just fine. My one gripe right now is that the Chromium settings crashes every time without fail. The rest of Chromium doesnāt have a problem, and even Chrome extensions work.
Other distros are available too, like Chromium OS and Android. Rumor is Manjaro is coming soon too. The default is Debian Mate. Iāve already swapped to XFCE because I like it better. Iām currently waiting on a microSD card to test other distros.
Performance
You get plenty good performance without being charged an Arm and a leg. Get it? Arm and a leg? Iāll show myself out.
But for real though, the Pinebook Pro is plenty adequate for ānormalā usage. I can browse the internet, play some videos, write a word document, and edit basic spreadsheets without issue. If you are a power user you will most likely run out of the 4 GB of RAM, but the 2+4 big.LITTLE architecture can handle a surprising amount. The architecture is also great on power, I havenāt tested the battery life extensively but I got a good 6 hours when I was first testing it out and still had plenty of juice left.
Storage might seem a little bizarre to some people at first. To start it comes with eMMC that is upgradeable, a microSD slot, and can use NVMe drives with an adapter. Out of the box it boots from its eMMC, but it can also boot from the microSD slot. As best I can tell it canāt boot from USB or NVMe without some tweaking.
Conclusion
For $200 this thing is a steal. Build quality is good, specs are fine, and software is like 90% of the way there. Iāll be honest that I was a bit nervous going into this because 1. Arm, 2. Cost, and 3. Timeframe, but Rock64 has delivered a pretty solid product. With a couple kinks worked out (and Windows lol) I think even my parents would be pleased with it.
and yes, the trackpad fw fix is incoming - I hope that by mid-next-week weāll have it out there and tested by ~10-20 people. If they OK it, then weāll just push it.
