Got frustrated with awesome, nord theme and nerd fonts.
Made good progress on dwm with Dracula theme on Arch. Almost done with dwm. Need to work on dmenu and putting things in dwmblocks status.
Anyone who wants to try dwm, this will make your experimentation an order of magnitude faster:
I started by applying the patches manually, and it quickly becomes merge hell once you’ve applied a few, and a lot of the ones on the suckless site weren’t updated for 6.2. Zero headaches with flexipatch.
Subjective, but for me the structure of the Lua config is considerably more confusing than editing/compiling the dwm C code. That said, while I don’t actively write C, it was the first language I was ever exposed to (around age 11), so maybe it’s inherently easier for me to understand.
Because “awesome” is a ubiquitous, contextless adjective, it is very difficult to search for solutions online. You almost always have to use awesomewm which usually yields few results.
Seems like the user base is relatively small or doesn’t customize much or maybe they are obscured by reason 2?
To elaborate on reason 1, I figured Awesome would bring dwm (remember awesome is a fork of dwm) closer to like a TOML config file, but you really need to study the awesome documentation to see how all the parts are related and the resulting syntax isn’t at all intuitive at a glance. Even the top-level objects seem intentionally confusing… awful, beautiful, gears… why do I need to decode this abstract symbolism in order to move an element or change a color?
If you are like me and keep that htop open at all times I suppose you could get rid of the information already provided by htop, like the memory/swap usage?
I don’t, was just for the screenshot. I usually have a browser and lots of documents open in vim. Info in the status bar is better for me since it persists across tags (aka workspaces… sort of).
I wonder if there’s an easy way to replace the layouts in the status bar with the awesome icons. That’s really what I miss from awesome. The dwm ascii illustrations aren’t easily deciphered at a glance. I’ll learn them over time but would prefer an intuitive icon.
For me personally it depends how much I have to use something like that Google app collection you posted. I I’m using that several time in a day I will eventually build muscle memory for each necessary app, and then design like that won’t affect me. But if I need those apps only once in a week I fully agree with you how that is not the best design for humans.
I sort of feel desktop can be similar, And on unixporn there’s probably lots of users who are watching their desktops hours and hours every day.
I am impressed with how they automagically bootstrap the controller appliance (ovirt engine) onto the initial host and then equally automagically make it highly available when you add the second host.
oVirt high availability is surprisingly good. HA VMs and the management engine failed over after I suddenly pulled the power on a hypervisor. It’s not full blown fault tolerance (have to wait for it to realize something is wrong and then boot the VMs on the new hv), but since I configured power management, it actually powered the hypervisor back on via ipmi with no intervention from me. The HA VMs did come up on another hv before the down one was restored.
