Been thinking about replacing my router minitx system with an Intel NUC…
This would make it possible.
Wouldnt say its a replacement for ZFS/btrfs/etc … but this is worth more research…
Just downloaded RHEL 8 dev edition. Going to put it on my server since it hates freenas.
Manually dealing with thin provisioning looks like a pita, and dedupe after copy seems dumb. I wish RHEL had better native filesystem options…
Well ZFS on RHEL 8 is a no go.
Think I’ll do a write up on this later.
fedora 30 tho? is ok right?
Haven’t tried that yet tbh. Ran out of time this weekend to work on it.
I have some more sas drives coming in on Wednesday that I need to add to my pool. So I was going to blow it all away anyway and see what works.
IIRC you were using FreeNAS at one point and then switched to Fedora for ‘performance reasons’ for the L1 storage server.
Confirmed Ok
Just got it installed.
neofetch
htop
For my reference later:
in fact still on fedora, and with f30, I gotta upgrade but I wanted to skip f29 for other reasons. F30 w/newer kernel should work out pretty good but storage server must not be down
Yeah lol, right in the middle of Computex remote troubleshooting the storage server would not be fun.
Are you guys uploading to it directly or did you just bring a bunch of hard drives?
upload direct, the editing has to happen elsewhere
Ouch. Hotel wifi must be brutal.
I’m running my zfs server on f29.
Upgraded a few months ago from f27.
At the time I upgraded… Kernel 5.0.x was out but zfs was only up to 0.7.12 so I had to manually patch ZFS to run on the kernel.
Still beating my head over squid trying to get a it it work transparently on my network.
Basic setup
I have tried several different configs on the squid system but i keep getting the squid access denied page. (so I dont believe anything is wrong on my router (centos/iptables) since squid pages are returned.
# Recommended minimum configuration:
# Example rule allowing access from your local networks.
# Adapt to list your (internal) IP networks from where browsing
# should be allowed
#acl localnet src 192.168.0.88
acl localnet src 127.0.0.1 # RFC1918 possible internal network
acl localnet src ::1 # RFC1918 possible internal network
#acl localnet src 10.0.0.0/8 # RFC1918 possible internal network
#acl localnet src 172.16.0.0/12 # RFC1918 possible internal network
acl ilocalnet src 172.16.0.0/12 # RFC1918 possible internal network
#acl localnet src 172.20.0.0/16 # RFC1918 possible internal network
#acl localnet src 172.24.0.0/16 # RFC1918 possible internal network
#acl localnet src 172.28.0.0/16 # RFC1918 possible internal network
#acl localnet src 192.168.0.0/24 # RFC1918 possible internal network
#acl localnet src fc00::/7 # RFC 4193 local private network range
#acl localnet src fe80::/10 # RFC 4291 link-local (directly plugged) machines
acl SSL_ports port 80
acl SSL_ports port 443
acl Safe_ports port 80 # http
acl Safe_ports port 21 # ftp
acl Safe_ports port 210 # wais
acl Safe_ports port 1025-65535 # unregistered ports
acl Safe_ports port 280 # http-mgmt
acl Safe_ports port 488 # gss-http
acl Safe_ports port 591 # filemaker
acl Safe_ports port 777 # multiling http
acl CONNECT method CONNECT
# Recommended minimum Access Permission configuration:
# Deny requests to certain unsafe ports
http_access deny !Safe_ports
#http_access allow !Safe_ports
# Deny CONNECT to other than secure SSL ports
http_access deny CONNECT !SSL_ports
#http_access allow CONNECT !SSL_ports
# Only allow cachemgr access from localhost
http_access allow localhost manager
http_access deny manager
# We strongly recommend the following be uncommented to protect innocent
# web applications running on the proxy server who think the only
# one who can access services on "localhost" is a local user
#http_access deny to_localhost
# INSERT YOUR OWN RULE(S) HERE TO ALLOW ACCESS FROM YOUR CLIENTS
# Adapt localnet in the ACL section to list your (internal) IP networks
# from where browsing should be allowed
http_access allow localnet
http_access allow ilocalnet
# And finally deny all other access to this proxy
#http_access allow all
http_access deny all
# Squid normally listens to port 3128
http_port 3128 intercept
http_port 3130
http_port 3130
# Uncomment and adjust the following to add a disk cache directory.
cache_dir ufs /var/spool/squid 50000 16 256
# Leave coredumps in the first cache dir
coredump_dir /var/spool/squid
# Add any of your own refresh_pattern entries above these.
refresh_pattern ^ftp: 1440 20% 10080
refresh_pattern ^gopher: 1440 0% 1440
refresh_pattern -i (/cgi-bin/|\?) 0 0% 0
refresh_pattern . 0 20% 4320
sample from access.log file
1559482000.892 0 172.28.3.9 TCP_HIT/200 13081 GET http://spacewalk.jab.us:3129/squid-internal-static/icons/SN.png - HIER_NONE/- image/png
1559482001.007 0 192.168.0.89 TCP_MISS/403 4322 GET http://192.168.0.1/ - HIER_NONE/- text/html
1559482001.007 0 172.28.3.9 TCP_MISS/403 4442 GET http://192.168.0.1/ - ORIGINAL_DST/192.168.0.89 text/html
1559482001.038 0 192.168.0.89 TCP_MISS/403 4256 GET http://192.168.0.1/favicon.ico - HIER_NONE/- text/html
1559482001.038 0 172.28.3.9 TCP_MISS/403 4376 GET http://192.168.0.1/favicon.ico - ORIGINAL_DST/192.168.0.89 text/html
1559482001.041 0 172.28.3.9 TCP_HIT/200 13081 GET http://spacewalk.jab.us:3129/squid-internal-static/icons/SN.png - HIER_NONE/- image/png
1559482003.503 0 172.28.3.9 NONE/000 0 NONE error:transaction-end-before-headers - HIER_NONE/- -
1559482003.599 0 192.168.0.89 TCP_MISS/403 4385 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - HIER_NONE/- text/html
1559482003.599 1 172.28.3.9 TCP_MISS/403 4505 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - ORIGINAL_DST/192.168.0.89 text/html
1559482003.625 0 192.168.0.89 TCP_MISS/403 4199 GET http://www.tldp.org/favicon.ico - HIER_NONE/- text/html
1559482003.625 0 172.28.3.9 TCP_MISS/403 4319 GET http://www.tldp.org/favicon.ico - ORIGINAL_DST/192.168.0.89 text/html
1559482003.628 0 172.28.3.9 TCP_HIT/200 13081 GET http://spacewalk.jab.us:3129/squid-internal-static/icons/SN.png - HIER_NONE/- image/png
1559482004.071 0 192.168.0.89 TCP_MISS/403 4385 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - HIER_NONE/- text/html
1559482004.071 0 172.28.3.9 TCP_MISS/403 4505 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - ORIGINAL_DST/192.168.0.89 text/html
1559482004.099 0 192.168.0.89 TCP_MISS/403 4199 GET http://www.tldp.org/favicon.ico - HIER_NONE/- text/html
1559482004.099 0 172.28.3.9 TCP_MISS/403 4319 GET http://www.tldp.org/favicon.ico - ORIGINAL_DST/192.168.0.89 text/html
1559482004.103 0 172.28.3.9 TCP_HIT/200 13081 GET http://spacewalk.jab.us:3129/squid-internal-static/icons/SN.png - HIER_NONE/- image/png
1559482004.405 0 192.168.0.89 TCP_MISS/403 4385 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - HIER_NONE/- text/html
1559482004.405 0 172.28.3.9 TCP_MISS/403 4505 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - ORIGINAL_DST/192.168.0.89 text/html
1559482004.416 0 172.28.3.9 TCP_HIT/200 13081 GET http://spacewalk.jab.us:3129/squid-internal-static/icons/SN.png - HIER_NONE/- image/png
1559482004.423 0 192.168.0.89 TCP_MISS/403 4199 GET http://www.tldp.org/favicon.ico - HIER_NONE/- text/html
1559482004.423 0 172.28.3.9 TCP_MISS/403 4319 GET http://www.tldp.org/favicon.ico - ORIGINAL_DST/192.168.0.89 text/html
1559482004.577 0 192.168.0.89 TCP_MISS/403 4385 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - HIER_NONE/- text/html
1559482004.577 0 172.28.3.9 TCP_MISS/403 4505 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - ORIGINAL_DST/192.168.0.89 text/html
1559482004.607 0 192.168.0.89 TCP_MISS/403 4199 GET http://www.tldp.org/favicon.ico - HIER_NONE/- text/html
1559482004.607 0 172.28.3.9 TCP_MISS/403 4319 GET http://www.tldp.org/favicon.ico - ORIGINAL_DST/192.168.0.89 text/html
1559482004.613 0 172.28.3.9 TCP_HIT/200 13081 GET http://spacewalk.jab.us:3129/squid-internal-static/icons/SN.png - HIER_NONE/- image/png
1559482005.023 0 192.168.0.89 TCP_MISS/403 4385 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - HIER_NONE/- text/html
1559482005.023 0 172.28.3.9 TCP_MISS/403 4505 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - ORIGINAL_DST/192.168.0.89 text/html
1559482005.054 0 192.168.0.89 TCP_MISS/403 4199 GET http://www.tldp.org/favicon.ico - HIER_NONE/- text/html
1559482005.054 0 172.28.3.9 TCP_MISS/403 4319 GET http://www.tldp.org/favicon.ico - ORIGINAL_DST/192.168.0.89 text/html
1559482005.057 0 172.28.3.9 TCP_HIT/200 13081 GET http://spacewalk.jab.us:3129/squid-internal-static/icons/SN.png - HIER_NONE/- image/png
1559482015.430 0 192.168.0.89 TCP_MISS/403 4362 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - HIER_NONE/- text/html
1559482015.430 0 172.28.3.9 TCP_MISS/403 4482 GET http://www.tldp.org/LDP/Bash-Beginners-Guide/html/f32.html - ORIGINAL_DST/192.168.0.89 text/html
1559482015.454 0 172.28.3.9 TCP_IMS_HIT/304 323 GET http://spacewalk.jab.us:3129/squid-internal-static/icons/SN.png - HIER_NONE/- image/png
Your fan/drives config made me chuckle.
as soon as I figure out zfs send/receive … I can kick off the cloning and see how the drive temps look.
After playing around…
I just kicked off an rync… when done it should finish in about 12(?) hours… (this is good reason to get 10Gb huh?)
But then I’d need a 10Gb switch… lol
Update…
I still havent fixed up the cabling on my “rack” yet… but I dont need that corner of the room (yet)
If you havent seen my new proxmox hardware “build”
I did get the ball rolling on doing some 10Gb stuff…
https://forum.level1techs.com/t/post-what-new-thing-you-acquired-recently/88085/17251?u=nx2l
Ive been looking around to see what makes sense with my current setup for adding a couple 10Gb ports to my router/firewall, but options are low since the motherboard is ITX.
(A way around this would be getting a M.2 to pcie X4 adapter so I could add another pcie slot… vs going to mATX motherboard)
Since the aquntia 10GbE nics are quite affordable… (and I already bought one) I guess staying with copper is my plan.
Most dual/quad port options I have found so far X520, X550, X710… etc are mostly $200-$400
I may just figure going mATX or doing the adapter to get another x4 pcie slot is easier to get an Aquantia 10Gb nic added to my router.
Still figuring it out…
Been spending on time on upgrading my proxmox to Ryzen.
U.2 to PCIE adapter will be here soon.
Just updated the BIOS and BMC firmware last night.
Expecting time this weekend to install it
