the worst part is, it’s not even something to study, just do shitty tasks that aren’t worth jack shit IRL.
I hate uni with a passion.
/offtopic
/offtopic
The swap partition is important because that is where core dumps are written if there is a kernel panic. Then when the system reboots the core is saved to a file on the filesystem before using the space for swap again. The core dump is extremely valuable for debugging.
https://leaf.dragonflybsd.org/cgi/web-man?command=efisetup§ion=8
https://leaf.dragonflybsd.org/cgi/web-man?command=uefi§ion=8
UEFI support is there, but I’m not sure if the installer does it for you. I will try going through a UEFI install tomorrow and see what I find.
I’ll be so mad at Dell if they implemented the BIOS like that. I’ll have to find my stick.
With redgek gone I can still be unique!
You can do it! Don’t be like me. No one should want to be like @Goalkeeper
I forgot at what point during the install, but it asks if you want to do a UEFI install or a legacy install. I chose UEFI.
I don’t care about uni, I care about not wasting 1.5 years.
Not to mention the money
So with the 2320, Dell doesn’t give you the option to do a legacy boot. So I’m stuck. Lol. Interestingly tho, th model above this one, the 2330, does have an option to do that.
I’m really starting to hate this computer. . I’m going to come back to this project with another PC in a few months.
Seems like we both need to get “new” thinkpads.
Just don’t tell MFZuul
To make him extra mad, we should get the 7 row thinkpads
AYYYYYY! I’m in!
What the fooking fuck. When the screen that displays, after installing, that shows “F1”
, you’re supposed to push the enter key.
Do you need to get the drivers from a port or something? Or is that just for applications?
That is a good question. Just thru some quick googling, it looks like the drivers are there and I just have to manually add some stuff to a few files and I should be alright.
Currently trying to get Xorg dowbmladed thru pkg via Ethernet. So I can install a GUI and do it that way. But it appears that I have to update the repository before I can download stuff.
That error was the result of pkg not being able to connect to the server as a result of the computer not being able to connect to the internet . As i assumed dhcp was running, but it wasn’t running by default out of the box.
I had to run
dhclient << Ethernet name >>
to get dhcp going. Xorg is now being downloaded.
Downloaded htop, and the system is using 1.7 gigs of ram. Like BRO!
Currently downloading a network manager to get WiFi going.
Got openbox running.
Things are
