Noticed this on my setup when I was adjusting some settings
Anyone else now get a integrated option in the Nvidia control panel? after setting this here I no longer have to rely on the windows control panel, everything goes straight to the tesla for D3D while all other desktop processes go to my GTX980. (See image blow, ID 0 being the 980, ID 1 being the Tesla)
Works a treat, normally furmark would default to the 980 but here it is launched through the context menu. Im quite happy with this setup its exactly what I wanted.
Thanks man. I guess I was needing a system reboot or did something out of order because it works great now. I got the 1100 config with 3125 memory working. Just rigged up some temporary cooling to do game tests.
I just played PUBG Training mode for 15 min or so on this thing at 1100 Core 3125 Mem. Added a delta fan on the i/o side running 100%. Pulls between 85 and 99% power at 1100. 1440p “esports” settings I was getting 90-100fps. Pretty close to what I get on my Fury X. 1080p was right around 130fps. I might power mod this but as it stands now I am going to install my Morpheus cooler on it and daily drive this thing for a while.
(Offtopic)
Been using it like that in my desktop for a few years now, bought it from a customer who just showed up with it at my work one day.
(Ontopic)
So with my setup I’m able to disable/enable the tesla card in the event that I encounter an issue with a game or piece of software (None so far!).
Just a heads up if you disable and then reenable the card you need to reapply your afterburner overclock and then run the command to set the clock speed. I have my machine setup to apply the afterburner overclock at boot and then have a batch file sitting in my startup folder that applies the specified clock. For some reasons nvidia-smi wasn’t on path so I went and corrected that.
I’ve had mine exceed 220watts in 1440p 144hz gaming loads, does a great job. Waiting for a 120mm 32mm thick 12 volt blower fan to arrive from amazon. I dug out my delta style 3D printer and gave it a tune up so I can have a proper thermal solution.
After I sort it out I’ll post a link to amazon for other UK folk along with a link to the 3D model for you to slice.
HW Info with afterburner providing info for RTSS, I’ll double check tomorrow when I have a better cooling solution ready but this is what I see in HWInfo
