Hey folks,
This is my current PCPP list. Any feedback is welcome and appreciated.
New: https://pcpartpicker.com/list/FRK9zN
Old: https://pcpartpicker.com/list/dWwqV6
I feel like I’ve drained the last little bit of usefulness out of my 5930k, and the itch has become unbearable. I’m probably gonna hand a lot of my old rig down to my kid so she has her own PC, but there will be some part scavenging occuring.
My only real price concern is, I’m trying to stay under $1500 for the Mobo and CPU (I already upgraded my RAM with 64GB of wide QVL supported sticks, but still have the old 32gb kit).
My primary OS is windows, mainly because I’m too lazy to dual boot/setup my games with proton. I generally only have a single CentOS VM (4 core 16gb) running on a normal day, but can have up to 5 (open shift cluster), or an additional windows pro vm with IIS and SQL Express.
My day to day is usually a lot of docker builds, with python, angular and java. Occasionally it’ll be a kernel or some other OSS project. I also fill in as a dev a few times a week, and that usually means I’m running mongo or MySQL, + flask/Django/webkit/springboot. JMeter tests on the host OS while the app is running on the VMs is is also a pretty common workload.
If it were you, would you rather have the all core frequency potential for the majority of your workload, or the core count for mass VMs and Host OS stability?
Right now 6/12 core/threads definitely ain’t cutting it, and I feel the blockage every couple days with all cores pegged. I do still play games on this machine pretty regularly, so single core frequency is important, as is rock solid stability, so any overclocking is usually very mild.
P.S. I am pretty write heavy on my current SATA SSDs for VM disks, and haven’t really noticed anything being slow. The NVMe in the build will likely do a lot of lifting, for Steam and VMs (docker volumes), and I’ve heard mixed feelings on it. I think as long as I’m not expecting performance any better than my 850 pros I shouldn’t have a problem, but feel free to correct me if I’m wrong.
