You need 2 HDD? You'd only save £15. Not worth it imho, especially if you plan on overclocking later down the line. The Antec One gaming case although cheap is actually quite solidly built and for £41 is a bargain.
Are you wanting an SSD as your main drive and a HDD as a storage drive? If so, you'll have to make some real sacrifices to quality and future upgradeability to keep the i5 3570K as the main part of your system. What is your absolute max? Can you go over £600?
Apparently, Fraps records better to another HDD. I can't really go over £600 cause as of now, I'm merely setting myself a target as I have no money. I could get £600 in 3/4 months, so I know all of this is a bit premature, but as I said, I just want to be able to aim towards something rather than just making money. Thank you for your help btw :)
RAM - http://www.dabs.com/products/kingston-8gb--2-x-4gb--hyperx-ddr3-1600mhz-dimm-240-pin-cl9-xmp-7N58.html - Should be compatible with the Gigabyte board
Case - http://www.amazon.co.uk/gp/product/B005JRICNG/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE - Although Cheap, it's one of the best budget buys. No USB 3.0
PSU - http://www.dabs.com/products/xfx-450-watt-core-edition-single-rail-psu-w--full-wired-cables-7NSV.html - More than enough power for the system. It's still a rebadged Seasonic. I wouldn't go past anything above a 7870XT though if you're thinking about upgrading to a beefier GPU in the future.
I think I will go with the first build... but is it good enough to record with? :3 also I live in Northern Ireland, so the postage is a lot more I'm pretty sure.
Yeah its good enough for recording games with, especially if it's just a hobby. If you do it a very regular basis though, you'll need to increase your budget,
Hang on you live in Northern Ireland?! That changes everything then. Did your £600 budget include delivery or have you budgeted for delivery separately?
Actually not that much. For Dabs delivery is as little as £1.50 and they don't do a surcharge either. Orders have to be over £300. That means it will be cheaper to order everything from Dabs and Amazon
ebuyer is £10 more I think... But would I be better buying this case http://www.scan.co.uk/products/sharkoon-vs3-v-black-green-atx-mid-tower-case-w-o-psu-usb-30-120mm-fan as it's cheaper and my friend says it's actually very good...
Scan charge a huge amount for delivery. It's upto you. I'm only recommending the Bitfenix Merc Alpha based on professional reviews. They all agree it's a very good case for the price and it works out cheaper than the one you've linked from Scan.
The Dirty Build 2
CPU - http://www.amazon.co.uk/gp/product/B007RUZKK6/ref=ox_sc_act_title_3?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE - Same
Mobo - http://www.dabs.com/products/asus-p8z77-v-lx2-s1155-intel-z77-ddr3-atx-8BYD.html - This is version 2 of your original choice. It lacks a DVI port, pointless if you're using the 7850 or any other discrete graphics
HDD - http://www.amazon.co.uk/gp/product/B008ZBNURG/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A2GZT5WO4CNKKS - 32MB Cache instead of 64. Doesn't matter since this is a storage drive.
SSD - http://www.dabs.com/products/sandisk-128gb-ssd-sata-6gb-s-2-5--solid-state-drive-870X.html - Arguably not as good as the Samsung, but...Sandisk are known to make very reliable drives. They produce alot of OEMs for companies like Apple etc. Sandisk SSD's are everywhere! Very cheap. If you've never used an SSD before the speed of this drive will blow you away. Load your OS and programs onto this...sparingly ofcourse :)
Case - http://www.amazon.co.uk/gp/product/B005JRICNG/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A3P5ROKL5A1OLE - same
RAM - http://www.dabs.com/products/kingston-8gb--2-x-4gb--hyperx-ddr3-1600mhz-dimm-240-pin-cl9-xmp-7N58.html - Same
PSU - http://www.dabs.com/products/xfx-450-watt-core-edition-single-rail-psu-w--full-wired-cables-7NSV.html - Same
Do you require an SSD in that Build? BTW the case really can't get any cheaper, unless you're willing to rock with a mATX board and they're actually more expensive than the motherboard i've linked above.
Plus a 7870 is going to cost you an extra £40, there is no way I can shave off that much.
I don't need an SSD tbh, http://www.scan.co.uk/products/sharkoon-vs3-v-black-green-atx-mid-tower-case-w-o-psu-usb-30-120mm-fan this is the case I was thinking of getting as my friend said it was good and it's cheap
Will you be happy to pay £37 for that case? Because that's how much shipping will cost if you get it from Scan. The Bitfenix Alpha case a stronger case in terms of cooling and housing your components.
Oh crap. It's stronger but it doesn't look as nice, maybe one with a window and that price if possible? I like things that look nice aswell as perform well if you know what I mean :/
If you're forgoing the SSD then I can get you a more expensive case. This is a nice case as well btw, it's similar in terms of looks to the one you've linked, it has better build quality, has USB 3.0 front panels and it's free delivery from Amazon. I actually have the older version in my home atm and it's pretty sweet. This is the last build.
GPU - http://www.ebuyer.com/product/388867 - 7870
HDD- http://www.amazon.co.uk/gp/product/B008ZBNURG/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A2GZT5WO4CNKKS - or you can get - http://www.ebuyer.com/319639-seagate-1tb-barracuda-internal-hard-drive-st1000dm003 - for £2 more. No real difference in speed though
RAM - http://www.dabs.com/products/crucial-8gb--2-x-4gb--ballistix-sport-ddr3-1333mhz-cl9-1-5v-240pin-7Y8R.html - Slower. Will only impace around 2-3 fps
Mobo - http://www.dabs.com/products/asus-p8z77-v-lx2-s1155-intel-z77-ddr3-atx-8BYD.html - Same as yours except it's version 2. No DVI port.
CASE - http://www.amazon.co.uk/gp/product/B007C10AKA/ref=ox_sc_act_title_2?ie=UTF8&psc=1&smid=A17AS5ETPMZ9A1 - Black and green. You can get the red version or even a white one if you want. Just type in Bitfenix Shinobi into Amazon.
Total including shipping
£598.98
If you opt for more expensive RAM and the 64MB cache version of the Seagate harddrive then add an extra £8 onto that.
