KVM Model:
1.4 Display Port KVM Switch - Single Monitor - Two Computer
10-gigabit
Problem:
Recently purchased a the DP 1.4, 2 computer KVM switch and my experience so far has been positive with the basics (Keyboard, Video, and Mouse only)! I’ve been slowly adding components to the switch and have run into an issue with my USB mic that I’m hoping someone has seen before…
My Yeti Blue when plugged directly into either of my computers is both a speaker and a mic (audio input and audio output). It interfaces via USB 2.0.
Moving it to the KVM, the behavior is different with each computer.
- Computer 1: HP ‘4K’ Docking station w/ laptop
- Computer 2: ASRock B650M PG RIPTIDE WIFI based system
When Computer 1 is selected, the Yeti shows up as an audio input and output (as expected) with the mic plugged into the USB 3.0 port on the front of the KVM.
When Computer 1 is selected, if I move the Yeti to a USB 2.0 HID port, it shows up only as a mic (audio input) but not a speaker (audio output).
When Computer 2 is selected, the Yeti doesn’t show up at all (as audio input or output) with the mic plugged into the USB 3.0 port on the front of the KVM.
When Computer 2 is selected, if I move the Yeti to a USB 2.0 HID port, it shows up only as a mic (audio input) but not a speaker (audio output).
I’ve tried every USB port on Computer 2 and there’s no change in behavior no matter what port on the computer I’m using. I’m using " Cable Matters 20Gbps USB C to USB C Monitor Cable 3 ft / 0.9m with 4K 120Hz & 8K 30Hz, 240W Power Delivery" USB cables on both systems.
There’s no driver for the mic that I can find, so it’s not a situation where I can uninstall/reinstall drivers, and the fact that it works properly in the USB 3.0 port with Computer 1 makes me think that’s the proper port for it. I’m just confused as to why it doesn’t show up at all when switching to Computer 2.
I’ve tried to do some power cycles of the KVM in between switching computers, but nothing I can do seems to change the behavior.
Any thoughts on what might be the issue or have some things to try to troubleshoot?
Other Notes:
Using DisplayPort cables from Level1Techs
Using Cable Matters 20Gbps USB C to USB C Monitor Cable 3 ft / 0.9m with 4K 120Hz & 8K 30Hz, 240W Power Delivery
