Xnd's blog: home-server/lab • selfhosting • power efficiency • fanless • automation • solar ☀️
Here, I’ll share my adventures with my home server(s)…
As you may have noticed from the title, I plan to write about the following topics:
  • Home server/lab (more about servers and hardware, less about networking)
  • Self-hosting
  • Power efficiency (less heat; I don’t need powerful hardware)
  • Fanless setups (less noise, less dust, fewer decibels)
  • Automation (not just home automation; I plan to cover RS-485)
  • Solar :sun: (battery systems, charging, management, automation, etc.)
About
NOTE:
This will be primarily for myself, but maybe someone else will find it helpful.
:warning: <IN PROGRESS…>
Placeholder.
  • Here will be summary of my past “projects”. //TODO: finish it.
Please, give me some time to finish it, I need to search all my relevant posts on many places (like other forums, reddit, my private self-hosted notes, between my thousands files in ~/Downloads : D and so on)
Looking forward to your work on that. I like the low-power and solar addition to the average homelab stuff. I also use efficient components wherever I can, although I personally replace fan-less with more performance, but otherwise I like the addition of solar power and the hardware associated with it.Self-sustaining system, I like. And low-power and silent/fan-less go hand in hand, less power, less heat, less noise.
I’m always interested in how others get a lot within a very narrow power envelope.
Doesn’t matter. Thread and what you’re up to matters :slight_smile:
placeholder
