I’m using x11vnc
in order to manage certain functionalities of my notebook remotely and after installing the latest manjaro updates it has stopped working. There are no errors shown in the terminal, I am just unable to connect to the machine:
x11vnc -xkb -display :0 -v
#@ ** WARNING ** WARNING ** WARNING ** WARNING ** @#
#@ YOU ARE RUNNING X11VNC WITHOUT A PASSWORD!! @#
#@ This means anyone with network access to this computer @#
#@ may be able to view and control your desktop. @#
#@ >>> If you did not mean to do this Press CTRL-C now!! <<< @#
#@ You can create an x11vnc password file by running: @#
#@ x11vnc -storepasswd password /path/to/passfile @#
#@ or x11vnc -storepasswd /path/to/passfile @#
#@ or x11vnc -storepasswd @#
#@ (the last one will use ~/.vnc/passwd) @#
#@ and then starting x11vnc via: @#
#@ x11vnc -rfbauth /path/to/passfile @#
#@ an existing ~/.vnc/passwd file from another VNC @#
#@ application will work fine too. @#
#@ You can also use the -passwdfile or -passwd options. @#
#@ (note -passwd is unsafe if local users are not trusted) @#
#@ Make sure any -rfbauth and -passwdfile password files @#
#@ cannot be read by untrusted users. @#
#@ Use x11vnc -usepw to automatically use your @#
#@ ~/.vnc/passwd or ~/.vnc/passwdfile password files. @#
#@ (and prompt you to create ~/.vnc/passwd if neither @#
#@ file exists.) Under -usepw, x11vnc will exit if it @#
#@ cannot find a password to use. @#
#@ Even with a password, the subsequent VNC traffic is @#
#@ sent in the clear. Consider tunnelling via ssh(1): @#
#@ http://www.karlrunge.com/x11vnc/#tunnelling @#
#@ Or using the x11vnc SSL options: -ssl and -stunnel @#
#@ Please Read the documention for more info about @#
#@ passwords, security, and encryption. @#
#@ http://www.karlrunge.com/x11vnc/faq.html#faq-passwd @#
#@ To disable this warning use the -nopw option, or put @#
#@ 'nopw' on a line in your ~/.x11vncrc file. @#
Settings:
display: :0
authfile: null
subwin: 0x0
-sid mode: 0
clip: null
flashcmap: 0
shiftcmap: 0
force_idx: 0
cmap8to24: 0
8to24_opts: null
24to32: 0
visual: null
overlay: 0
ovl_cursor: 1
scaling: 0 1.0000 1.0000
viewonly: 0
shared: 0
conn_once: 1
timeout: 0
ping: 0
inetd: 0
tightfilexfer: 0
http: 0
connect: null
connectfile null
vnc_conn: 1
allow: null
input: null
passfile: null
unixpw: 0
unixpw_lst: null
ssl: null
ssldir: null
ssltimeout -1
sslverify: null
stunnel: 0
accept: null
accept: null
gone: null
users: null
using_shm: 1
flipbytes: 0
onetile: 0
solid: null
blackout: null
xinerama: 1
xtrap: 0
xrandr: 0
xrandrmode: null
padgeom: null
logfile: null
logappend: 0
flag: null
rm_flag: null
rc_file: ""
norc: 0
dbg: 0
bg: 0
mod_tweak: 1
isolevel3: 0
xkb: 1
skipkeys: null
sloppykeys: 0
skip_dups: 0
addkeysyms: 1
xkbcompat: 0
clearmods: 0
remap: null
norepeat: 1
norepeatcnt:2
nofb: 0
watchbell: 1
watchsel: 1
watchprim: 1
seldir: null
cursor: 1
multicurs: 0
curs_mode: null
arrow: 1
xfixes: 1
alphacut: 240
alphafrac: 0.33
alpharemove:0
alphablend: 1
cursorshape:1
cursorpos: 1
xwarpptr: 0
alwaysinj: 0
buttonmap: null
dragging: 1
ncache: 0
wireframe: 0xff,2,0,32+8+8+8,all,0.15+0.30+5.0+0.125
wirecopy: always
scrollcopy: always
scr_area: 60000
scr_skip: ##Soffice.bin,##StarOffice,##OpenOffice
scr_inc: ##Nomatch
scr_keys: null
scr_term: null
scr_keyrep: null
scr_parms: 0+64+32+32,0.02+0.10+0.9,0.03+0.06+0.5+0.1+5.0
fixscreen: null
noxrecord: 0
grabbuster: 0
ptr_mode: 2
inputskip: 10
speeds: null
wmdt: null
debug_ptr: 0
debug_key: 0
defer: 20
waitms: 20
wait_ui: 2.00
nowait_bog: 0
slow_fb: 0.00
xrefresh: 0.00
readtimeout: 20
take_naps: 1
sb: 60
fbpm: 1
dpms: 1
xdamage: 1
xd_area: 20000
xd_mem: 1.000
xcomposite: 1
multiptr: 0
sigpipe: null
threads: 0
fs_frac: 0.75
gaps_fill: 4
grow_fill: 3
tile_fuzz: 2
snapfb: 0
rawfb: null
pipeinput: null
gui: 0
gui_mode: null
noremote: 0
unsafe: 0
privremote: 0
safer: 0
nocmds: 0
deny_all: 0
pid: 1970
07/12/2022 15:56:25 x11vnc version: 0.9.16 lastmod: 2019-01-05 pid: 1970
