No display output after installing updates
After installing the latest manjaro updates and rebooting the system there is no output on the notebooks display anymore, it just remains black.
Any ideas on what’s wrong and how to troubleshoot this issue?
I queried journalctl and discovered the following:
journalctl --boot=-1 --priority=3 --no-pager
Dez 07 16:24:35 cptLegendary kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_PR.CPU0._CPC], AE_NOT_FOUND (20210730/psargs-330)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU1._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU2._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU3._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU4._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU5._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU6._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:35 cptLegendary kernel: ACPI Error: Aborting method \_PR.CPU7._CPC due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Dez 07 16:24:37 cptLegendary kernel:
Dez 07 16:24:38 cptLegendary kernel: Bluetooth: hci0: Reading supported features failed (-16)
Dez 07 16:24:38 cptLegendary bluetoothd[652]: src/plugin.c:plugin_init() Failed to init vcp plugin
Dez 07 16:24:38 cptLegendary bluetoothd[652]: src/plugin.c:plugin_init() Failed to init mcp plugin
Dez 07 16:24:38 cptLegendary bluetoothd[652]: src/plugin.c:plugin_init() Failed to init bap plugin
Dez 07 16:24:39 cptLegendary gdm-autologin][807]: gkr-pam: couldn't unlock the login keyring.
Dez 07 16:24:46 cptLegendary smbd[851]: [2022/12/07 16:24:46.182136,  0] ../../source3/smbd/server.c:1741(main)
Dez 07 16:24:46 cptLegendary smbd[851]:   smbd version 4.17.3 started.
Dez 07 16:24:46 cptLegendary smbd[851]:   Copyright Andrew Tridgell and the Samba Team 1992-2022
Dez 07 16:25:00 cptLegendary systemd-backlight[1026]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
Dez 07 16:25:00 cptLegendary systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
Dez 07 16:25:06 cptLegendary kernel: nvidia-modeset: ERROR: GPU:0: Idling display engine timed out: 0x0000947d:0:0:407
Dez 07 16:37:13 cptLegendary gdm[719]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
Dez 07 16:37:13 cptLegendary systemd-coredump[9644]: Failed to connect to coredump service: Connection refused
Is your laptop effected by the recent backlight problem? Are you running a release candidate for kernel 6.1?
Thanks for the reply but I’m still on 5.15.81-1-MANJARO.
However, in order to make any assistance easier please consider this additional information:
System Information
sudo mhwd-kernel -li
Currently running: 5.15.81-1-MANJARO (linux515)
The following kernels are installed in your system:
   * linux515
sudo mhwd -li
> Installed PCI configs:
                  NAME               VERSION          FREEDRIVER           TYPE
          video-nvidia            2021.11.04               false            PCI
Warning: No installed USB configs!
inxi -Fza
System:
  Kernel: 5.15.81-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a1ce8d41-cdba-4fac-ad01-f6af1a14c873
    rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
  Console: pty pts/0 DM: GDM v: 43.0 Distro: Manjaro Linux base: Arch Linux
Machine:
  Type: Laptop System: LENOVO product: 20HH001QGE v: ThinkPad P51 serial: <superuser required>
    Chassis: type: 10 serial: <superuser required>
  Mobo: LENOVO model: 20HH001QGE v: SDK0J40697 WIN serial: <superuser required> UEFI: LENOVO
    v: N1UET72W (1.46 ) date: 10/04/2018
Battery:
  ID-1: BAT0 charge: 89.1 Wh (100.0%) condition: 89.1/90.0 Wh (99.0%) volts: 11.8 min: 11.2
    model: SMP 00NY493 type: Li-poly serial: <filter> status: full cycles: 188
CPU:
  Info: model: Intel Core i7-7700HQ bits: 64 type: MT MCP arch: Kaby Lake gen: core 7 level: v3
    note: check built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 9
    microcode: 0xF0
  Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 256 KiB
    desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB desc: 4x256 KiB L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 3526 high: 3799 min/max: 800/3800 scaling: driver: intel_pstate
    governor: powersave cores: 1: 3526 2: 3442 3: 3445 4: 3541 5: 3502 6: 3500 7: 3453 8: 3799
    bogomips: 44817
  Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  Vulnerabilities:
  Type: itlb_multihit status: KVM: VMX disabled
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  Type: mds mitigation: Clear CPU buffers; SMT vulnerable
  Type: meltdown mitigation: PTI
  Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
  Type: retbleed mitigation: IBRS
  Type: spec_store_bypass mitigation: Speculative Store Bypass disabled via prctl and seccomp
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
  Type: spectre_v2 mitigation: IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: Not affected
  Type: srbds mitigation: Microcode
  Type: tsx_async_abort status: Not affected
Graphics:
  Device-1: NVIDIA GM107GLM [Quadro M1200 Mobile] vendor: Lenovo driver: nvidia v: 525.60.11
    alternate: nouveau,nvidia_drm non-free: 520.xx+ status: current (as of 2022-10) arch: Maxwell
    code: GMxxx process: TSMC 28nm built: 2014-19 pcie: gen: 3 speed: 8 GT/s lanes: 16
    bus-ID: 01:00.0 chip-ID: 10de:13b6 class-ID: 0300
  Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-8:2 chip-ID: 5986:111c
    class-ID: 0e02 serial: <filter>
  Display: server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.5 driver: N/A tty: 180x55
  API: OpenGL Message: GL data unavailable in console and glxinfo missing.
Audio:
  Device-1: Intel CM238 HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
    chip-ID: 8086:a171 class-ID: 0403
  Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX] driver: snd_hda_intel v: kernel
    pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
  Sound API: ALSA v: k5.15.81-1-MANJARO running: yes
  Sound Server-1: JACK v: 1.9.21 running: no
  Sound Server-2: PulseAudio v: 16.1 running: no
  Sound Server-3: PipeWire v: 0.3.61 running: no
Network:
  Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: N/A
    bus-ID: 00:1f.6 chip-ID: 8086:15d6 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:24fd class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
Bluetooth:
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-14:6
    chip-ID: 8087:0a2b class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: up address: see --recommends
Drives:
  Local Storage: total: 6.83 TiB used: 332.21 GiB (4.7%)
  SMART Message: Required tool smartctl not installed. Check --recommends
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: MZVLB512HAJQ-000L7 size: 476.94 GiB
    block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter>
    rev: 3L2QEXA7 temp: 30.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 type: USB vendor: Crucial model: Micron X8 SSD size: 1.82 TiB
    block-size: physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Seagate model: Portable size: 4.55 TiB
    block-size: physical: 4096 B logical: 512 B type: N/A serial: <filter> rev: 9300 scheme: GPT
Partition:
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%) used: 332.21 GiB (71.0%) fs: ext4
    dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 288 KiB (0.1%) fs: vfat
    dev: /dev/nvme0n1p1 maj-min: 259:1
Swap:
  Alert: No swap data was found.
Xorg.0.log
cat /var/log/Xorg.0.log
[     5.564] (--) Log file renamed from "/var/log/Xorg.pid-844.log" to "/var/log/Xorg.0.log"
[     5.566]
X.Org X Server 1.21.1.4
X Protocol Version 11, Revision 0
[     5.566] Current Operating System: Linux cptLegendary 5.15.81-1-MANJARO #1 SMP PREEMPT Fri Dec 2 21:02:26 UTC 2022 x86_64
[     5.566] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=a1ce8d41-cdba-4fac-ad01-f6af1a14c873 rw quiet splash apparmor=1 security=apparmor udev.log_priority=3
[     5.566]
[     5.566] Current version of pixman: 0.42.2
[     5.566] 	Before reporting problems, check http://wiki.x.org
	to make sure that you have the latest version.
[     5.566] Markers: (--) probed, (**) from config file, (==) default setting,
	(++) from command line, (!!) notice, (II) informational,
	(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[     5.566] (==) Log file: "/var/log/Xorg.0.log", Time: Wed Dec  7 16:38:38 2022
[     5.568] (==) Using config directory: "/etc/X11/xorg.conf.d"
[     5.568] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[     5.569] (==) ServerLayout "layout"
[     5.569] (**) |-->Screen "Screen0" (0)
[     5.569] (**) |   |-->Monitor "Monitor0"
[     5.570] (**) |   |-->Device "Device0"
[     5.570] (==) Automatically adding devices
[     5.570] (==) Automatically enabling devices
[     5.570] (==) Automatically adding GPU devices
[     5.570] (==) Automatically binding GPU devices
[     5.570] (==) Max clients allowed: 256, resource mask: 0x1fffff
[     5.570] (WW) The directory "/usr/share/fonts/misc" does not exist.
[     5.570] 	Entry deleted from font path.
[     5.570] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[     5.570] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[     5.570] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[     5.570] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[     5.570] (==) FontPath set to:
	/usr/share/fonts/TTF
[     5.570] (==) ModulePath set to "/usr/lib/xorg/modules"
[     5.570] (**) Extension "COMPOSITE" is enabled
[     5.570] (II) The server relies on udev to provide the list of input devices.
	If no devices become available, reconfigure udev or disable AutoAddDevices.
[     5.570] (II) Module ABI versions:
[     5.570] 	X.Org ANSI C Emulation: 0.4
[     5.570] 	X.Org Video Driver: 25.2
[     5.570] 	X.Org XInput driver : 24.4
[     5.570] 	X.Org Server Extension : 10.0
[     5.571] (++) using VT number 2
[     5.574] (II) systemd-logind: took control of session /org/freedesktop/login1/session/_31
[     5.574] (II) xfree86: Adding drm device (/dev/dri/card0)
[     5.574] (II) Platform probe for /sys/devices/pci0000:00/0000:00:01.0/0000:01:00.0/drm/card0
[     5.575] (II) systemd-logind: got fd for /dev/dri/card0 226:0 fd 14 paused 0
[     5.577] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     5.577] (**) OutputClass "nvidia" ModulePath extended to "/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules"
[     5.579] (--) PCI:*(1@0:0:0) 10de:13b6:17aa:2251 rev 162, Mem @ 0xeb000000/16777216, 0xc0000000/268435456, 0xd0000000/33554432, I/O @ 0x0000d000/128, BIOS @ 0x????????/131072
[     5.579] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[     5.580] (II) LoadModule: "glx"
[     5.580] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[     5.585] (II) Module glx: vendor="X.Org Foundation"
[     5.585] 	compiled for 1.21.1.4, module version = 1.0.0
[     5.585] 	ABI class: X.Org Server Extension, version 10.0
[     5.585] (II) LoadModule: "nvidia"
[     5.586] (II) Loading /usr/lib/xorg/modules/drivers/nvidia_drv.so
[     5.589] (II) Module nvidia: vendor="NVIDIA Corporation"
[     5.589] 	compiled for 1.6.99.901, module version = 1.0.0
[     5.589] 	Module class: X.Org Video Driver
[     5.590] (II) NVIDIA dlloader X Driver  525.60.11  Wed Nov 23 22:56:57 UTC 2022
[     5.590] (II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
[     5.590] (II) systemd-logind: releasing fd for 226:0
[     5.591] (II) Loading sub module "fb"
[     5.591] (II) LoadModule: "fb"
[     5.592] (II) Module "fb" already built-in
[     5.592] (II) Loading sub module "wfb"
[     5.592] (II) LoadModule: "wfb"
[     5.592] (II) Loading /usr/lib/xorg/modules/libwfb.so
[     5.592] (II) Module wfb: vendor="X.Org Foundation"
[     5.592] 	compiled for 1.21.1.4, module version = 1.0.0
[     5.593] 	ABI class: X.Org ANSI C Emulation, version 0.4
[     5.593] (II) Loading sub module "ramdac"
[     5.593] (II) LoadModule: "ramdac"
[     5.593] (II) Module "ramdac" already built-in
[     5.593] (**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
[     5.594] (==) NVIDIA(0): RGB weight 888
[     5.594] (==) NVIDIA(0): Default visual is TrueColor
[     5.594] (==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
[     5.594] (**) Option "AllowNVIDIAGpuScreens"
[     5.594] (II) Applying OutputClass "nvidia" options to /dev/dri/card0
[     5.594] (**) NVIDIA(0): Option "AllowEmptyInitialConfiguration"
[     5.594] (**) NVIDIA(0): Enabling 2D acceleration
[     5.594] (II) Loading sub module "glxserver_nvidia"
[     5.594] (II) LoadModule: "glxserver_nvidia"
[     5.594] (II) Loading /usr/lib/nvidia/xorg/libglxserver_nvidia.so
[     5.628] (II) Module glxserver_nvidia: vendor="NVIDIA Corporation"
[     5.628] 	compiled for 1.6.99.901, module version = 1.0.0
[     5.628] 	Module class: X.Org Server Extension
[     5.628] (II) NVIDIA GLX Module  525.60.11  Wed Nov 23 22:51:25 UTC 2022
[     5.629] (II) NVIDIA: The X server supports PRIME Render Offload.
[    18.285] (--) NVIDIA(0): Valid display device(s) on GPU-0 at PCI:1:0:0
[    18.285] (--) NVIDIA(0):     DFP-0
[    18.285] (--) NVIDIA(0):     DFP-1
[    18.285] (--) NVIDIA(0):     DFP-2
[    18.285] (--) NVIDIA(0):     DFP-3
[    18.285] (--) NVIDIA(0):     DFP-4 (boot)
[    18.285] (--) NVIDIA(0):     DFP-5
[    18.285] (--) NVIDIA(0):     DFP-6
[    18.286] (II) NVIDIA(0): NVIDIA GPU Quadro M1200 (GM107GL-A) at PCI:1:0:0 (GPU-0)
[    18.286] (--) NVIDIA(0): Memory: 4194304 kBytes
[    18.286] (--) NVIDIA(0): VideoBIOS: 82.07.bb.00.14
[    18.286] (II) NVIDIA(0): Detected PCI Express Link width: 16X
[    18.286] (--) NVIDIA(GPU-0): DFP-0: disconnected
[    18.286] (--) NVIDIA(GPU-0): DFP-0: Internal TMDS
[    18.286] (--) NVIDIA(GPU-0): DFP-0: 165.0 MHz maximum pixel clock
[    18.286] (--) NVIDIA(GPU-0): DFP-1: disconnected
[    18.286] (--) NVIDIA(GPU-0): DFP-1: Internal TMDS
[    18.286] (--) NVIDIA(GPU-0): DFP-1: 165.0 MHz maximum pixel clock
[    18.286] (--) NVIDIA(GPU-0): DFP-2: disconnected
[    18.286] (--) NVIDIA(GPU-0): DFP-2: Internal TMDS
[    18.286] (--) NVIDIA(GPU-0): DFP-2: 165.0 MHz maximum pixel clock
[    18.287] (--) NVIDIA(GPU-0): DFP-3: disconnected
[    18.287] (--) NVIDIA(GPU-0): DFP-3: Internal DisplayPort
[    18.287] (--) NVIDIA(GPU-0): DFP-3: 960.0 MHz maximum pixel clock
[    18.287] (--) NVIDIA(GPU-0): AU Optronics Corporation (DFP-4): connected
[    18.287] (--) NVIDIA(GPU-0): AU Optronics Corporation (DFP-4): Internal DisplayPort
[    18.287] (--) NVIDIA(GPU-0): AU Optronics Corporation (DFP-4): 960.0 MHz maximum pixel clock
[    18.287] (--) NVIDIA(GPU-0): DFP-5: disconnected
[    18.287] (--) NVIDIA(GPU-0): DFP-5: Internal DisplayPort
[    18.287] (--) NVIDIA(GPU-0): DFP-5: 960.0 MHz maximum pixel clock
[    18.287] (--) NVIDIA(GPU-0): DFP-6: disconnected
[    18.287] (--) NVIDIA(GPU-0): DFP-6: Internal DisplayPort
[    18.287] (--) NVIDIA(GPU-0): DFP-6: 960.0 MHz maximum pixel clock
[    18.288] (==) NVIDIA(0):
[    18.288] (==) NVIDIA(0): No modes were requested; the default mode "nvidia-auto-select"
[    18.288] (==) NVIDIA(0):     will be used as the requested mode.
[    18.288] (II) NVIDIA(0): Validated MetaModes:
[    18.288] (II) NVIDIA(0):     "DFP-4:nvidia-auto-select"
[    18.288] (II) NVIDIA(0): Virtual screen size determined to be 1920 x 1080
[    18.290] (--) NVIDIA(0): DPI set to (143, 144); computed from "UseEdidDpi" X config
[    18.290] (--) NVIDIA(0):     option
[    18.290] (II) NVIDIA: Reserving 6144.00 MB of virtual memory for indirect memory
[    18.290] (II) NVIDIA:     access.
[    22.295] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[    22.295] (II) NVIDIA(0):     may not be running or the "AcpidSocketPath" X
[    22.295] (II) NVIDIA(0):     configuration option may not be set correctly.  When the
[    22.295] (II) NVIDIA(0):     ACPI event daemon is available, the NVIDIA X driver will
[    22.295] (II) NVIDIA(0):     try to use it to receive ACPI event notifications.  For
[    22.295] (II) NVIDIA(0):     details, please see the "ConnectToAcpid" and
[    22.295] (II) NVIDIA(0):     "AcpidSocketPath" X configuration options in Appendix B: X
[    22.295] (II) NVIDIA(0):     Config Options in the README.
[    26.621] (II) NVIDIA(0): Setting mode "DFP-4:nvidia-auto-select"
/etc/X11
ls -alsh *
mhwd.d:
total 12K
4,0K drwxr-xr-x 2 root root 4,0K  7. Dez 16:36 .
4,0K drwxr-xr-x 6 root root 4,0K 12. Feb 2022  ..
4,0K -rw-r--r-- 1 root root 1,5K  7. Dez 16:36 nvidia.conf
   0 -rw-r--r-- 1 root root    0  7. Dez 16:36 nvidia.conf.nvidia-xconfig-original
tigervnc:
total 12K
4,0K drwxr-xr-x 2 root root 4,0K 19. Apr 2022  .
4,0K -rwxr-xr-x 1 root root 1,5K 14. Mär 2022  Xsession
xinit:
total 20K
4,0K drwxr-xr-x 3 root root 4,0K 23. Jän 2022  .
4,0K -rw-r--r-- 1 root root  739 10. Okt 2020  xinitrc
4,0K drwxr-xr-x 2 root root 4,0K  7. Dez 13:32 xinitrc.d
4,0K -rw-r--r-- 1 root root   45 10. Okt 2020  xserverrc
xorg.conf.d:
total 12K
4,0K -rw-r--r-- 1 root root  273 11. Feb 2022  00-keyboard.conf
   0 lrwxrwxrwx 1 root root   27  7. Dez 16:36 90-mhwd.conf -> /etc/X11/mhwd.d/nvidia.conf
nvdia.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 525.60.11
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
    InputDevice    "Keyboard0" "CoreKeyboard"
    InputDevice    "Mouse0" "CorePointer"
EndSection
Section "Files"
EndSection
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Option         "Protocol" "auto"
    Option         "Device" "/dev/psaux"
    Option         "Emulate3Buttons" "no"
    Option         "ZAxisMapping" "4 5"
EndSection
    Identifier     "Keyboard0"
    Driver         "kbd"
EndSection
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    Option         "DPMS"
EndSection
Section "Device"
    Identifier     "Device0"
    Driver         "nvidia"
    VendorName     "NVIDIA Corporation"
	Option "NoLogo" "1"
EndSection
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
EndSection
Section "Extensions"
    Option         "COMPOSITE" "Enable"
EndSection
Section "InputClass"
    Identifier          "Keyboard Defaults"
    MatchIsKeyboard        "yes"
    Option              "XkbOptions" "terminate:ctrl_alt_bksp"
EndSection
Any help would be greatly appreciated.
Given the journal messages, might help to boot in a more verbose mode.
Looking at the actual msg, search engine hints me into looking at disable acpi in grub, and see where it goes from there:
https://wiki.ubuntu.com/DebuggingACPI
related might help (and has an archive.org link on the bottom to the source of ubunut’s help guide)
https://wiki.archlinux.org/title/General_troubleshooting
With acpi=off I can see that it hangs on the Manjaro screen like so:
Interestingly enough, when I remove the quiet entry and also remove acpi=off again the output becomes more unreadable when it starts to hang:
I’m wondering if the culprit isn’t the following line:
Dez 08 10:58:21 cptLegendary gdm[700]: Gdm: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: Refusing activation, D-Bus is shutting down.
There is another thing I have noiced and this is the following process running at 100% utilisation all the time:
/usr/lib/Xorg vt2 -displayfd 3 -auth /run/user/1000/gdm/Xauthority -nolisten tcp -background none -noreset -keeptty -novtswitch -verbose 3
I have now tried both kernel 5.18 and 6 and the problem persists. The more time passes the more I think I should just re-install Manjaro (again)…
I think kernel (5.18) was a typo and thus far I have tried those kernels:
  • 5.10.157-1-MANJARO
  • 5.15.81-1-MANJARO
  • 6.0.11-1-MANJARO
I have also deactivated Bluetooth, WiFi and the fingerprint reader, just to be on the safe side. Furthermore, I stumbled over a thread with a similar issue:
So, I went ahead and added ibt=off but it did not solve it on my end :cry:
did you do:
sudo mhwd -li
they just pushed a new nvidia driver so I would just reinstall the driver.
sudo mhwd -r *insert installed driver here*
sudo mhwd -i *probably intel-nvidia-prime driver here*
Thank you very much, you and another user in the Manjaro forum pointed me in the right direction:
sudo mhwd -li
This only lists the nividia driver and it I discovered (thx to the other user) that I had the onboard GPU deactivated. So, I activated it in the BIOS, removed the video-nvidia driver and installed video-hybrid-intel-nvidia-prime.
What I’m wondering now though are those two things:
  1. Given that the driver has just been pushed shouldn’t the version say something different than 2021.11.04?
  2. Is there an easy way to test if the discrete GPU is working as expected?
it depends on the Kernel you run, since your on 5.15 its probably the most recent driver version that Nvidia provides (or the most stable one).
prime-run glxinfo | grep OpenGL
should run on the nvidia, and
Should run on the iGPU
No, I’m on 6.0.11-1-MANJARO.
glxinfo is in Essential Mesa Utilities, is this the right one?
Yes that is the right glxinfo. idk about 6.0 kernel since I am still rocking 5.19
