I currently have two of these systems, see configuration below.
M.2 drive on the motherboard OS drive
Two 980 pros on the pcie card
1 Adaptec Asr-71605e connected to 12 HDDS on a raid one.
Currently I have an issue where the motherboard seems to loose all the m.2 drives or not know which one to boot to.
Recently I had the system up & loaded into windows then out of nowhere reboots & back on the bios menu
Boss is ready to beat me silly over this, any assistance would be appreciated.
Try Re seating the CPU, could be making bad contact
before seeing your last post I moved the (OS) M.2 that was on the motherboard to the PCI express card.
It booted up fine & on multiple reboots as well.
left the machine up for the night & lost all video had to reboot.
On the other workstation windows freezes then BSOD -WHEA_UNCORRECTIBLE ERROR
So both of your systems have issues?
Correct both systems are having issues
Wondering if the systems are under powered. specs listed below are for two workstations
AMD threadripper pro 3955wx
Crucial 64GB 32x2 D43200 CL 16 B
WS WRX80E-SAGE SE WF
NOCTUA NH-U9 TR4-SP3
2x samsung 980 pro nvme
Crucial 250GB NVME
Adaptec 71605e
12x 12 TB WD purple
7 lianli uni fan SL140
corsair RM850
Whats the gpu?
Why did you go two sticks and leave all that bandwidth on the table?
$$ not my choice
As far as the GPU itâs the MSI GeForce GT 710 Low Profile Passive Cooled 1GB DDR3 PCIe 2.0 Graphics Card
for now. what ever he ordered is on backorder for the next few weeks.
so I think youâre having pcie errors like me!
GOOD NEWS
there is a firmware update for the 980 pro NVME
BAD NEWS
do not do the firmware update in this system!
Do it in another system.
PCIe4 is really really specific on this system. And verymuch âthread the needleâ
That might resolve your issue.
Wendell
The 980 pro is the culprit?
Weird the drive with my OS is the crucial NVME 250GB
For a moment I was thinking the issue might be a backwards compatibility issue with the older gen crucial.
Also I only have these two systems, haha.
So were stuck without a system?
Do it on any other system with nvme slot you can upgrade the firmware on.
dont use the wrx80 if possible, dont you have something else you could update the nvme in? if not then please use the on-motherboard m.2 slot closest to the cpu to do the firmware upgrade
also, and this will probably sound weird, but the aic card that carries 4x m.1, just put it in the first slot of that in the top slot of the wrx
that location and the closest m.2 to the cpu are probably the âsafestâ slots to do the firmware upgrade
Just picked up an external m.2 enclosure to upgrade the 980s. I pulled out the aic card earlier but the system still wonât recognize the onboard crucial itâs located in the M.2_1 slot.
Also wanted to say thanks @wendell & @mutation666 for assisting!
you ddi get the april bios update too? it really helped me a ton
Did it earlier in the week
Now seeing this
after the fw update you may have to reinstall/fresh format/etc.
once you do that you can run dmesg to see if you see anything from the kernel about pcie bus errors.
Still canât get the bios to read the onboard M.2.
so damn weird.
