I recently got my hands on some Xeon Max 9480s (the ones with the crazy fast integrated HBM memory); They run incredibly hot but once I figure out the cooling on the system and I know it’s not thermal throttling I’ll give this model a run.
Sadly I haven’t been able to play with creating the self-contained app version yet.
We have used them to try and narrow in on the new workstations!
But are considering if it is actually doable for us, in the current way of simulating, to run 2 or 3 simulations simultaneously
Geez, I’ve been slacking on this. I ran into some trouble in constructing the watercooling system for the HBM machine and I haven’t gotten around to solving it yet.
The new 6900 series Xeons look very impressive, they are producing memory bandwidth numbers over twice as high as the brand-new top of the line Turin CPUs just released on the STREAM benchmark, I think these Xeon 6’s are going to be the the winner hands down in the HPC segment.
I can’t wait to see some more math heavy benchmarks with these CPUs rather than just the raw memory bandwidth.
Right now we have budgeted around 2000$ for the CPU, do you have any idea when the 6900-series will be available, and what price-range they will be in?
The cheapest 6900P processor MSRPs for ~11400; the series of processors are available right now.
The issue would be finding the MRDIMMs the system would need to get the best performance, I haven’t seen these for sale anywhere outside of system vendor’s complete systems yet.
It is interesting, there is no benefit form Vache here, most likely 9950X would be fast as it would clock 10% higher and has 10% higher IPC, also this does not appear memory bound its more compute bound for sure. HT can increase throughput but better to have more cores or reduce np to match physical cores, like 7970X would be a good choice, where you put 2x4 or 8 threads on each CCD.
This also shows the poor scaling when crossing CCD boundary, small gain form np 8 with 2 parallel jobs to np 16 with one job.
I also have 7960X at work, I can run it as well on Monday.
TR 7960X is a bit disappointing, my only explanation is that memory latency is key, both system run at about 5G clocks +/- 100mhz on this load, TR has more bandwidth, difference is lower memory latency.
For mix of smaller DOF optimization or sweep and larger DOF problems, so this is interesting to me that for smaller DOF it may be best to run that on low latency consumer CPU.
The nice thing about TR is that with PBO, the clocks are very stable basically locked at 5.0G form 8-24 cores loaded where the multicore clock limiter kicks in, wish we could disable that.
L3 hit rate could also be a factor. In these configs the 7960X runs at 5.3 MB/core and the 7950X3D at 4 or 12. Benching the 7960X with four and five utilized cores per CCD and the 7950X3D’s CCDs individually might offer some insight, though the latter may be IFOP limited.
My OCD wanted to know so I ran it on a standard 7950X, however this machine had lower latency 55ns 48G SR CL26 DDR6200 memory, it will also run about 5.3-5.4G clocks vs the X3D that only runs 5.0 G clocks. Looks like latency and clocks wins over vcache here…
I am gonna jump here and put myself in the fire because I have used comsol and matlab decades ago.
However I ve been writing FEM simulations of my own (mat nonlin - geo-nonlin) on gpu (both cuda and rocm) for 6 months trying to utilise neural networks and using cloud heavily I am gonna throw some things here , I hope you don’t hate it.
Since monte carlo simulations are random in its nature even if you simulate Texas holdem hands using monte carlo you will see that times vary widely when benchmarking , etiher you should run simulations far tooo long than needed or multiple times … !!! to achieve benchmark for correct results !!!
However since monte carlo simulations in their nature are samples of cylce(x:data) → y:data you can also benchmark with smaller number of operations it should - would scale linearly.
Do not forget both AMD and Intel have their own optimized libraries other than PETS and BLAS or openBLAS so it changes the game per cpu Model a lot I think. And the fact whether Comsol utilizes these libraries or not matters . Most of them related to optimal cache usage (L1<->L2<->L3) and instruction set usage such as using AVXn for matrix operations etc…
Having said that, I believe the more amount of cpu cache and more higher tech cpu cache you have the more faster the operations would go. Epyc’s designed for FEM and consumer CPU’s such as 7950X3d may show some difference
I use cloud heavily , If comsol allows it I would consider using a local cluster of consumer CPU’s 256GB ram 7950x3d since monte carlo sim loops (cycles) are usually running independently
So as a mechanical engineer who is coding since undergrad. These are my ideas. They really may be wrong , unrelated , irrelevant or shortsighted. Sorry for if any inconvenience in advance . Thats why I tried to keep it short.
9950X3D in the house here is results for the micro speaker 360k DOF small batch benchmark, using AOCL BLAS, pretty impressed with the speed up on average 23%! Best times around 5 minutes.
