Ryzen 9 9950X3D Vs Intel 270K Plus in COMSOL
Hi L1
We are looking into a smaller, incremental upgrade to our COMSOL-Pc at the company, and have had the luck to find some “cheaper” DDR5 sticks (4x48Gb 5400Mhz C38), so i started diving into which CPU could be the best choice for the “lowest price”
We have found two candidates:
AMD
Ryzen 9 9950X3D (Based off of the Benchmark-charts found in different threads in here)
Asrock X870E
Price ~1400USD
Pros Cons
Easy to set up Higher Price
Runs relatively cool Lower Ram Bandwidth
Less Power consumption Inter-Die Latency
Easy CO’ing and Ram-tuning (~+7%perf)
^Cooler and more efficient at higher Mhz
AVX-512
Intel
Intel Ultra 270K Plus
TG Contact Frame
Msi Mag z890
Price ~820Usd
Pros Cons
Competitative against R9) Power Hungry
High Ram Bandwidth High Temps under loads
Overclockable (~+15%Perf) Will draw up towards 500w when OC’s
Migher Max Ram Speeds ^And run at ~100c+ during sims
High TJMax (105-115c) Beefy Cooling and higher noise
Missing AVX-512
I cannot seem to find a lot of examples of people with 270K Plus processors, running the benchmarks, and therefore its really hard to compare!
I can see there is a ~25% compute benefit when comparing 7950X3D to the 9950X3D, and i assume around 5-10% when tuned properly
I can see that in raw compute-cases the 270K Plus Beats the 9950X3D, and it has a higher potential when Overclocking (Both up to +40% higher Ram Bandwidth and +15% compute performance increase)
But it runs very hot! - I have looked into buy’ing a Delidded 270K Plus from ThermalGrizzly in order to apply Liquidmetal to keep it cooler under sustained loads, even thou we are planning to cool it with a Noctua 360mm AIO, i think it needs extra measures to not boil over time.
Do anyone have a setup with a 270K Plus (And maybe Oc’es) that might be able to run a few benchmarks in order to have it compared to the Ryzen CPUs?
Or maybe have some concrete knowledge to light on this issue? - Thanks in advance :smiley:
Ps.
Links to the Benchark-threads:
CFD-Multiphysics Benchmark for x86 and ARM (Windows/macOS/Linux) - High-Performance Computing / Multiphysics & Simulation - Level1Techs Forums
Older:
Workstation for Monte Carlo Simulations - High-Performance Computing / Multiphysics & Simulation - Level1Techs Forums
