Happy to hear the thread was helpful. @aBav.Normie-Pleb @WarwicK7 @wendell I just finished extensively testing the custom BIOS with the 3 GPUs and with both CPUs (Ryzen 7 3700X and Ryzen 3 3200G)
“Not Working” cards indicated a Windows Code 43 in device manager and GPU-Z Bus Interface indicated “PCI-Express X16 1.1” even though the PCIE Gen version was selected manually in the BIOS.
Testing with CPU: Ryzen 7 3700X
Three GPU Setup
PCIE 1 - Gen 1 (Working)
PCIE 2 - Gen 1 (Working)
PCIE 3 - Gen 1 (Working)
PCIE 1 - Gen 2 (Working)
PCIE 2 - Gen 2 (Working)
PCIE 3 - Gen 2 (Working)
PCIE 1 - Gen 3 (Working)
PCIE 2 - Gen 3 (Not Working)
PCIE 3 - Gen 3 (Working)
PCIE 2 - Gen 2 (Not Working)
PCIE 1 - Gen 4 (Working)
PCIE 3 - Gen 4 (Not Working)
Two GPU Setup
PCIE 2 - Gen 1 (Not Working)
PCIE 1 - Gen 3 (Not Working)
PCIE 1 - Gen 4 (Not Working)
PCIE 2 - Gen 4 (Not Working)
PCIE 1 - Gen 1 (Not Working)
PCIE 1 - Gen 2 (Not Working)
PCIE 3 - Gen 4 (Working)
One GPU Setup
PCIE 1 - Gen 2 ( Working)
PCIE 2 - Gen 2 ( Working)
PCIE 3 - Gen 2 ( Working)
Testing with CPU: Ryzen 3 3200G
Two GPU Setup
PCIE 1 - Gen 3 (Working - Currently Using)
PCIE 3 - Gen 3 (Working - Currently Using)
PCIE 1 - Gen 4 (N.B. Not tested, but will likely work)
PCIE 3 - Gen 4 (N.B. Not tested, but will likely work)
I will follow up with ASUS and update.
