Why are hard drives painted black with a shiny top?
This is a really, really pointless question but why do all hard drives follow the same colour scheme?
They have black metal at the bottom, then a chome/aluminium looking finish on the top.
I’m pretty sure the black part is metal because it feels cold to the touch (on a drive that isn’t plugged in) and doesn’t have the feel of plastic.
So my question is, is there a technical reason for this design? I have a 10gb Seagate IDE HDD from 1998 and it’s all shiny mirror finish! Something must have driven this change and I’m wondering if there is any reason other than aesthetics.
Could a WD red actually be red? Would that really hurt the performance, or cost?
Huh, that is an interresting question…
I think The frame of the drive is so thick to allow heat dissipation, and reduce vibration
but I don;t know why black is so common, when the top plate is left metalic (just polished)
So here’s a few photos of the IDE drive I mentioned. All polished metal.
What changed and why did black/polished become the norm?
This is also a somewhat interesting shape by today’s standards.
There is a How It’s Made episode that shows the production of hard drives and they get those black aluminum blocks and start filling them with the components. I have some hard drives that are scratched and you can see that the drive is just painted black.
I did find this, where they talk about what grade of aluminum is used in some drives https://www.scrapmetalforum.com/computer-recycling/25497-hard-drive-shells-heatsinks-alloy-separation.html . I looked it up because I wanted to see if they were buying a specific grade of aluminum that was black.
Which makes me ask: Why do they paint them black? Most customers will never see the drive, especially home users. Enterprise users installing them in servers in bulk won’t care what they look like. So why the black paint?
Probably to hide casting and machining marks. It just gives it that “professional” touch for the cost of nearly nothing.
But surely “nearly nothing” in business over a million+ units is a lot.
I have in my hand a 1tb laptop HDD which is mass produced for the low end consumer market. 99.99% of people buying laptops the laptop this is in will never even see it. The other 0.001% won’t care what it looks like. What is the benefit of the black paint?
Because they have class.
Did you ever recieve a product with a scratch in the back?
That paint is the cheapest option to hide all kinds of marks.
This would be my best guess as well. Looking at one I have laying around it’s not pretty or perfect at all, but the matte paint hides everything it really well if you aren’t looking for blemishes. The chassis would definitely have all sorts of noticeable variations in color and polish if it was bare.
So while running these things through a paint step certainly isn’t free, it won’t touch the price in any noticeable way and it’s probably well worth it just to give it the “You payed over $100 for this” feeling.
This is an interesting theory. The 10gb I posted has blemishes, it looks like they are mostly from installing it it different PCs over the the years as the scratches are consistently horizontal across the drive where it’s been slid in/out of tight bays. None of my old black drives have that so maybe the paint is more resistant (or less obviously susceptible) to that kind of wear. Which also explains why the top part isn’t painted, because that never touches the sides of what it’s slid/screwed into.
edit: But again I raise the question of who cares about this. A consumer doesn’t generally replace the dive a lot and in enterprise they don’t really care if it gets scratched going in/out because the look of the drive is irrelevant as long as it’s not faulty. It still seems like a needless expense.
It might be to increase heat dissipation:
Various protective benefits and aesthetically pleasing colors have extended the use of anodization to many industrial and commercial applications. For electronics cooling, however, the advantages of surface anodizing are the dielectric isolation of the cooling components from their electronics environment, and the significant increase in their surface emissivity. The increase in the emissivity coefficient on the anodized surfaces of heat exchangers, electronics cabinets and enclosures, heat sinks, etc. is typically on the order of 0.83 to 0.86 [4]. When compared to the emissivity coefficient of bare aluminum, 0.04 to 0.06 [5], the importance and significance of enhancement of radiation heat transfer would become evident.
Source
Some of the other things mentioned in the article might also be relevant.
Thin layer of black paint would also increase heat dissipation, according to the comments on that article, so that might explain why it’s always back.
Is it paint, or anodized? I’m pretty sure it is anodized which would be more durable than most paints at a comparable thickness. But it does raise one question, is there a separate foundry supplying all of the bottom shells? It would seem a bit silly for every hard drive manufacturer to have their own aluminum foundry just to supply a standardized part.
i would love eletrostatic painting on this
i wonder what it would do if painted this way :thinking:
My guess that it has likely something to do with thermals.
Black is the most economical Color. So when painting then to cover up machine marks its the cheapest over a huge batch.
It has nothing to do with thermals, static elecricity, etc. Its just cheap aesthetic
You can’t have raw aluminum exposed, so it’s either some kind of paint or anodizing, I’m guessing paint is cheaper.
Yeah it is but also yes you could. It just would corrode over time :joy:… it would turn white… thats about it… it wouldnt hurt the integrity of the drive Tbch…
But most are not air sealed / helium drives, I’d rather they were corroded in a more controlled process/environment, than have random chips randomly fly around the platter head.
TomB,
Question is kind of like, “Why do all shoes have soles?”…:wink:
