Why are hard drives painted black with a shiny top?
I believe the top plate is usually stainless steel which doesn’t take to paint as well as aluminum. It is thinner and doesn’t make contact with any of the moving parts so its likely not needed for its thermal properties, but more as a protective shield. Thinness is important so there is more internal room for platters and heads.
Anyone who’s destroyed a hard drive with a sledgehammer or shoot it with a gun knows, the top plate will likely bend and dent but the aluminum body is more likely to shatter and crack under force. They are clearly different metals.
I believe that it is a non-conductive heat emissive coating/paint (depending on your definition of paint). I use to rebuild electric motors and GE (General Electric Corp.) made a coating that we used inside of them (I use to use it on the inside of crankcases of race motors [chevy small blocks most;y, 350, 327, 383, etc] i use to build because it was so tough and oil didn’t get entrapped in a porous surface, so we would reduce windage, in other words gained a few horsepower just from paint! its awesome.) I like their version is called Glyptal, or Glyphol, I think it was something like that. I am sure that the hard drive coating is a much improved version, possibly quite different. But I am guessing something along those lines.
actually some are painted and some are anodized
if its black anodizing and is usually scratch resistant to some extent , basically cheap cosmetic reason and prevents surface oxidation.
painting is very cheap compared to anodizing but can cause heat retention.
Painting a heatsink black doesn’t cause any kind of retention, it actually improves the thermal dissapation performance. It’s the same reason why car radiators are usually painted black, it’s the most efficent absorber and emitter of heat.
As for the top, yes they are a form of stainless, this is required because the spindle is supported by the cover, and it needs to be thin, but stiff. It can’t be made out of a magnetic metal as it could cause issues with the voice coil magnets. And finally, it provides magnetic shielding from outside sources preventing data corruption.
I have seen fully black drives such as the WD-Raptors, but they also had additional heatsinking as they ran at 15,000RPM and got very hot. I believe the covers on these were anodized.
In the enterprise world it’s rare to see black disks now I think about it, the only black SAS drives I have seen are some Toshiba SSDs I have in an older server. If it truly was an important measure outside of cosmetics it would be used in the server industry too. So while I can’t say for sure, it certainly looks like it’s just for cosmetics.
My guess:
My first HD was a full height 68 meg MFM that was just aluminum like the one below (not mine)
The IBM PC brought computers out of climate controlled environment to peoples houses. Aluminum in a moist environment doesn’t do to well.
I also had a 1 gig hd that was just aluminum and a Samsung 640 meg HD that was black anodized with the shiny top
Great thread!
providing the paint used is a stoveblack type paint.
this paint readily transfers heat.(stoveblack has a matte finish and a powdery appearance when dry)
but acrylic enamels used in some industrial paints has the opposite effect.
its one reason why it violates electrical code to paint over conduit, any time heat retention is a factor the conductors must be de-rated in the current limit they can carry, and conduit must be able to radiate to free air without restriction.
acrylic paints tend to leave a thicker skin.
Only three manufacturers exist today. I will bet that all three source the drive bodies from the same supplier. I don’t know for sure though.
To cut costs, the supplier offers black coating which in turn means higher returns for the three manufacturers as custom colours would drive up the cost.
Capitalism!
