We have two different USB 3.0 bottle openers we are thinking about Which do you prefer. We are going to do 32 and 64 for the storage. Is that too large or good?
Also, let me know if you think you would buy one. Imagine our logo laser etched onto it. I think the prices will be $25 and $39. That is not certain yet.
I was leaning toward the one on the right... but the rounded one will work on a keychain and is better for opening beer. So, which one?
Overall, the one on the left is easier to handle and open bottles with, from my experience. However, it's easy to contest that it's just as easy to open bottles for the one on the right and I like the security that comes with having a cap on the USB while you're using it as a bottle opener.
I'd pick the one on the right if you're going to use it as a USB at all. If it's more of a vanity thing, then the one on the left will be just fine.
You could probably just hot glue a half-circle onto the cap and use that for the key chain if the cap is tight and strong enough. That also makes it so that your USB isn't weighed down by your key chain when in use.
I like the looks of the right one better, but: whichever one is faster is the better stick... Because I have had everything from slower than USB 2.0 to super fast with USB 3.0 sticks. And the slow ones are annoying.
I vote left. Looks good and I like when USB sticks use the USB port connector as a structural part of the body - as long as it is well-made. Also 32 and 64GB are perfect.
I prefer the one on the right. Two reasons, the first being that it looks better. Second reason, i've seen a couple of models that look pretty much the same as the one on the left and a lot of them had the USB end bent, so it didn't go into a USB slot anymore.
The one on the left looks like the better bottle opener but the one on the right a much better USB stick - it has an end cap, and won't block the adjacent port at all, which the one on the left may.
Yeah... the left one looks like it would bend under the pressure of opening bottles. I don't know why, it just looks cheap. the right one looks much more durable.
I like the right one. There would be no problem opening bottles with it. 32GB is more than enough. I would personally not buy it, since I have 16GB stick and lots of local storage. Plus shipping would be most likely really expensive for a USB stick.
Stop adding such cool things to the store I'm broke lol. This will be great just to be the nerd at the drinking parties, would love to have that rectangular one its very sleek.
