What music player is everybody using now days?
I need just a decent basic player with mp3, aac, and flac support.
playing with DeaDBeef right now.
Rhythmbox.
does all that, and:
  • has an actually random shuffle
  • Scrobbles
  • doesn’t disrupt playlists or shuffle all with the search function
  • has multipane sorter
  • consistent design language that doesn’t hurt your eyes
Audacious, I want it simple, since I have everything sorted in the file system. No need for any media databases then.
To answer the question in the threads title. I use lollypop.
I don’t know if it fits your requirements tho.
Clementine, primarily for podcasts but also radio and some mp3’s
iTunes. (Bracing for a wave of hate)
Less on a wave of hate, but more on you are going to be reminded about contributing something relevant in a Linux thread.
Anyways on-topic:
I use whatever is default for me, so Amarok.
Whoops. Didn’t see the Linux part. Sorry.
Primarily either Amarok or Clementine, I like to switch it up. :stuck_out_tongue:
+1 for Lollypop, simple and clean interface. Though I still use Rhythmbox to rip CDs.
Not exactly what you are looking for But I think everyone should know about pianobar. It’s an amazing Pandora CLI interface.
Except for the ALAC audio codec which might hide behind some .m4a files. I had to convert them to MP3 when I switched from iTunes.
Tomahawk. Nuff said…
iTunes and YouTube
I’m using foobar2000, works great, allows for metadata editing of files and works really well under wine with play on linux.
VLC.
Does what I need.
I still use Windows Media Player lol… If ain’t broke, don’t fix it
CMUS or MOC
Simple, lightweight, and is fairly easy to learn
Used Audacious for a while, now trying Clementine. Need something that can sort properly, edit metadata and write to USB drives.
Rip Winamp :frowning:
you can still get WinAmp.
Just because it’s not updated, doesn’t mean you can’t use it
