What Graphics Card to Get?
Hi,
I am thinking of getting a new graphics card for my computer and I want some advice on which one to get.
At the moment these are my PC specs:
CPU - AMD A10 5800k
GPU - AMD HD Radeon 7660D (integrated)
PSU - Corsair 430w Builder Series CX 80+ Bronze
Motherboard - ASRock FM2A55M
Memory - Corsair 4GB DDR3 CL11 XMS3
Hard Drive - Western Digital 1TB Blue 7200RPM
As you can see I have an integrated Radeon 7660D in my AMD A10.
Basically I want to get another graphics card to work with my integrated one, so that I will have better game performance, fps and the like. For example I bought Need for Speed Most Wanted but I only get 20 FPS. I would like at least 40 FPS for it to play well.
It says on the box of my AMD A10 that a Radeon HD 6670 would work but are there any other options?
My budget is around €100 but if there are any really good ones that are not too much more and are really worth it than be sure to let me know.
Thanks and be sure to let me know of any.
I would advise you go with the recommendations on the box of your APU for a good crossfire experience BUT!! the R9 270x is a good card for around £169 ~ $277.99
as for the $100 you really are going to struggle without buying pre-owned I THINK.  I can highly recommend the GTX 760 from Zotac (AMP version) and you get 2 free games with it but its £200 ~ $328.98
with crossfire also comes issues alot of games arn't optimized for crossfire and sometimes will perform worse
http://pcpartpicker.com/parts/video-card/#sort=a7
would be a good place to start
So if I got this
http://www.dabs.ie/products/asus-amd-radeon-r9-270x-1120mhz-2gb-gddr5-pci-e-3-0-hdmi-directcu-ii-top-oc-91BG.html?q=AMD%20Radeon%20R9%20270X&src=16
Would it work with my integrated GPU?
And how would Need For Speed run?
Running an APU in crossfire with a dedicated graphics card isn't going to give you much of a performance boost. Dual GPUs are often a horrible configuration for gaming, and can lead to screen tearing and stutter.
I'd advise saving up a little extra. For $100 you could grab a 7790, which would give you a decent enough boost, but probably not enough to justify the cost. If you are desperate to play many of the latest AAA games, then you should be considering the 7790.
http://pcpartpicker.com/part/powercolor-video-card-ax77901gbd5tdhoc
Sub 100 after mail-in-rebate.
However, the marginal cost benefit at this price point is high. For every $20 that you spend in addition to that, you can get a lot more in return. The 7850 and upwards of that would be really great for your system. This is $130 after the mail-in-rebate:
http://pcpartpicker.com/part/asus-video-card-hd7850dc1gd5
Anything higher than a 7870 or 270x will be bottlenecked by your APU.
I was also going to ask: what resolution do you play at? how fast is your RAM?
And by the 7850 you mean?
1440×900 I think and my ram speed is 1600Mhz
Your integrated GPU can only crossfire with something like a 6670, which is a sub-par performing GPU. I understand the appeal, because people are drawn to "crossfire" or "SLI" configurations.
7850 is a GPU, much like the 270x. Either of those would be a pretty good upgrade. But aiming to crossfire your integrated with a low-end card would be a silly idea. It would be better to run a single, beefier mid-range card.
I didn't realise you were in Ireland. Forgive the American links I posted. There was a 7850 available for less than 100 £ sterling on Dabs. It appears to be sold out now. There's another one for £110, approximately.
for APU only try running faster ram there are videos online with more info and maybe knock the res down to 720 for gaming?
So you're saying to get more ram not a new GPU?
Could you link me to a video?
Does anyone else have any suggestions?
So what your saying is, to use the A10 as just a processor and get a separate dedicated GPU. so if you were me which would you get? The furthest I would stretch would be €200 maybe.
More RAM doesn't equate to more performance. What Slugworth was asking is the speed of your RAM. APUs will give more performance if they have faster RAM. However, with current RAM prices, you would be better-off paying for a mid-range GPU. It will give you the single best boost available.
I cannot make it much more clear. Get a mid-range card like the HD7850. Paired with your current setup, you will be running most games on high/ultra 1080p
Thank you very much. I will get the HD7850
This is the same card yes?
http://m.ebay.ie/itm/380818031773?nav=SEARCH&sbk=1
That is a HD7850.
I used a Powercolor HD7850 for about a year. I liked it a lot. Good performance, fairly low energy use and heat output.
I had a Sapphire HD 7850 1GB and it performed superbly.
Can someone link me to a cheap HD 7850?
That's exactly right. The APU will act just the same as a CPU. And it will allow you to use a pretty decent mid-range card. Something like the 7850 or 7870, or the rebranded R9 equivalents like the 270/ 270x will be really good for you. Those should all fall inside your budget. They will all perform faster than an APU in crossfire with a low-end GPU. So it is the best solution, undoubtedly.
Do you have a vendor that you wish to purchase from? If you can simply link me one in Ireland, I can search for a few GPUs that you will like.
