What Graphics Card to Get?
I usually buy from www.dabs.ie but I have found a cheaper 7850 on Amazon:
http://www.amazon.co.uk/XFX-Radeon-HD7850-Dual-PCI-E2xDHDMI2xmini-DPA/dp/B009VPY8F8/ref=sr_1_4?s=computers&ie=UTF8&qid=1389892507&sr=1-4&keywords=HD+Radeon+7850+2GB
That is quite a bit cheaper than Dabs. However, I would definitely advocate getting a 7850 with a better cooler, if you can afford it. I know that you said the top end of your budget is 200 euros. You could grab a decent 7850 for around 150. And there is the 7870 available for sub-200. An XFX 7870 available for around 160-170.
However, I think the single best purchase you could make would be the 270:
http://www.dabs.ie/products/gigabyte-amd-radeon-r9-270-950mhz-2gb-pci-express-3-0-hdmi-oc-952C.html?q=270&src=16
Decent enough cooler. You can overclock this 270 to the same speed as the 270x. The 270x is an up-to-date 7870.
Hope that all makes sense.
Would I really need a better cooler for the 7850? I mean the most intensive game I would really be playing at the moment is Need for Speed. I doubt that would raise the temperature that much, would it? I really don't really have a lot of cash at the moment.
If you're stuck, you could do worse than the 7850 XFX. The cooler can prove to be a little noisy, and a little hot. But it is perfectly functional. It's up to you. It will certainly give you the performance that you want, but you should ensure that you have good airflow in your chassis. Anything to help.
Mmmm....... I dunno, I think my cooling is fairly good, it never seems to get very hot and seeing as I have headphones on all the time I never really hear any noise.
125 euros is a good price for this kind of performance increase. I'm sure you will enjoy it, dude. Plenty of people do use XFX cards. I think they come with lifetime warranty
Thanks and €125? Its £125 which €150
If that's the case, I would seriously suggest grabbing the 270 off Dabs.ie
It's only 17 euros more for a much more up-to-date, and a decently powerful card which will do a better job of using 2GB of Vram, in comparsion to the 7850, which is really only ideal for 1GB. The 270 is just a downclocked, up-to-date version of the 7870. And you can easily clock it up beyond those speeds.
Is this the card you are talking about?
Also I take it this card will be compatible with all my other specs.
Yep and yep. 17 euros for a card that will certainly play Battlefield 4 on ultra presets at 1080p with your APU. Be sure to overclock it a bit.
Your power supply is powerful enough for the card, but let me check that it has the necessary connectors.
Ok and I take it there are plenty of overclocking tutorials for this card because I have'nt overclocked any other components of my computer
The Gigabyte card, the cheaper 270, requires two six pin peripheral connectors - according to Dabs. That seems overkill for this particular card. The other models of 270 only require a single PCIe connector. So I will have to take a couple of minutes to double check.
Right, ok.
Ok. Unfortunately, the Gigabyte card does require 2 PCIe 6 pin power connectors. Your CX430 only has one. However, there are models of both the 7850 and the 270 which only require a single 6pin connector. So you will either have to spend more on the 270 to grab a model which is more fitting for your system, or check that the XFX is a single PCIe 6pin power requirement.
Which includes this following card found on Dabs:
http://www.dabs.ie/products/sapphire-technology-amd-radeon-r9-270-2gb-pci-express-3-0-hdmi-dual-x-oc-95NN.html?q=270&src=16
Is there a version of the 270 that will work with my pc on dabs?
Updated, dude. I often make edits to my posts.
Ok so first off all your saying this card wont work
and then this one is is good
Right ok... hmmm.... I dunno... I think I should be able to afford it.
Hopefully prices might go down slightly before March
It's not a case of will or won't work. Different "brands" of the same GPU will have different power requirements. Your CX430 power supply has one connector, which is suitable for one card, and not the other card which requires two connectors. I'm not going to lie about it. You can see for yourself in any given spec sheet of those devices.
Ignore the 500W power supply requirement. This is an overestimate to compensate for other parts of your computer. But a typical gaming PC with a card of this power shouldn't draw more than 350W.
To make it abundantly clear, the card that requires one connector will work absolutely fine with your CX430.
If you want to choose a different card, ensure that it only requires one PCIe connector.
I knew what you meant when you said it had 2 connectors
Well, I think you've got a good idea of what to look for now. Best of luck, and let us know when you buy it or if you need any overclocking tips. There are video tutorials on YouTube.
