i am attempting to pass through my NVMe device to my VM, lspci -nnk shows that vfio-pci is loaded into the device, but attempting to start the VM yields this error:
error: internal error: process exited while connecting to monitor: 2019-01-11T23:19:26.245272Z qemu-system-x86_64: -device vfio-pci,host=41:00.0,id=hostdev2,bootindex=
1,bus=pci.0,addr=0x8,rombar=0: vfio 0000:41:00.0: failed to add PCI capability 0x11[0x50]@0xb0: table & pba overlap, or they don’t fit in BARs, or don’t align
ive never seen this error before and have no idea what could be causing it.
any help is apreciated.
Ive seen this before where NVMe devices are using the SMI SM2262 controller. Detailed here: https://bugzilla.kernel.org/show_bug.cgi?id=202055.
I think there’s some things detailed in the later posts which might help patch the issue.
For Intel SSD 660p series, the latest firmware is required for pass-through to work without issues. The latest one should be from mid 2020 at the time of writing this.
Not even any workarounds or special settings for qemu/libvirt are needed, just a simple pass-through setup as with any other PCIe device.
Which tool do you use to update the Intel SSD 660p firmware (preferably under linux)? I’m getting this with a tool found on Intel’s website:
root@debian:~# intelmas load -intelssd 1
WARNING! You have selected to update the drives firmware!
Proceed with the update? (Y|N): Y
Checking for firmware update...
Error: This drive is no longer supported.
root@debian:~#
EDIT: A tool from Solidigm website seems to have worked (sorry can’t post link from my account)
