Recently picked up a dual socket LGA 2011 mobo (Intel s2600cp) which I used in my new build with 2x Intel 2670, 64gb reg ECC DDR3 and a GTX G1 gaming 970 from Gigabyte. Before anyone asks the motherboard has a built in graphic adaptor but I have also tried with a gt 1030.
So I’ve tried to setup PCI express passthrough using this guide (Ubuntu 17.04 -- VFIO PCIe Passthrough & Kernel Update (4.14-rc1)) aswell as some other but to no success was wondering if anyone else has any luck. I’ve been trying for about 2-3 weeks with no avail.
Any input anyone gives thank you in advance it is much appreciated
This part here is generally where it has been falling apart. Everytime it will come up with the nouveau drivers instead. (Yes I did change the binary drivers to nvidias in settings)
I’ve got work now till 6 hours from now I’ll be on my PC tomorrow to check stiff
follow this instead, it’s a much more complete guide, and it’s generally pretty distro agnostic other than the differences in updating initramfs (dracut vs mkinipcio vs. whatever ubuntu uses)
