See my reply on Feb 11.
See my reply on Feb 11. There are things missing in the original post.
I’ve been working through this guide and multiple others. I was really banging my head on getting the pulseaudio config set up correctly, I kept seeing: pulseaudio: Reason: Connection refused
after googling around for awhile I found a post suggesting that perhaps selinux was the culprit and it turned out to be the case. For the meantime I’m setting selinux to permissive until I figure out how to configure correctly for this.
On to the next problem!
I would recommend a tool called setroubleshoot. This’ll notify you about any SELinux issues and help you solve them.
just saw your post now. thanx man, i will try these things as soon as i have the time!
Can confirm this is needed. Thanks for sharing JDawg and BansheeHero
Big thanks to everyone on this thread. Was a huge help, finally got my dual boot Fedora31/Win10 setup converted over to VFIO and LookingGlass.
Just a couple outstanding items that would love to get fixed up, hoping someone has some ideas:
- Audio: Has anyone gotten audio to pass from the VM to Pulse on the host? If so how?
- Have been reading and trying things from: PCI passthrough guide for Arch, LookingGlass wiki and these forums (mainly this threads section on QEMU Audio). But nothing has worked so far. Can’t get any audio from the win10 VM
- Was already considering getting a USB DAC, given how well the USB switches over I am tempted to get one and plug it into the USB card I was initially using for keyboard and mouse on the VM. Has anyone tried this?
- Automating the creation of the shared memory file:
- Anyone found a way to reliably create the shm file?
- I was trying to use /etc/tmpfiles.d as described here to create the file at boot. It creates the file and it appears to have all the right permissions, but the LookingGlass client gives a permission error when launching. If I manually recreate the shm file as root, then set the ownership/perms to “user:kvm” and “660” then LookingGlass launches fine.
Appreciate any help or advice on these last couple issues.
I could have sworn I had that in my guide. I’ll have to update it…
Okay, so you need ich6 or ich9. Last I checked, it’s not working properly on the latest windows 10 builds, due to driver issues. Causes major instability issues. So, stay on older builds (pre 1903) and don’t update unless you want to move away from it.
My recommendation is this:
Spring for the USB DAC. You can get a cheap one, but it’s a much better solution, all in.
Systemd unit file. Set it up to run on boot, as root, just have it execute a script in /usr/local/bin/ that sets it up.
Yeah, using ich9, that is what virt-manager setup. My win10 VM is 1909, didn’t know I needed to lock it to 1903 and doesn’t look like windows will let me roll that back. Might make a fresh VM just to try it out. Long-term solution will be USB DAC.
Systemd worked, here is what i did:
/etc/systemd/system/looking-glass.service
[Unit]
Description=Setup SHM for LookingGlass
[Service]
Type=oneshot
ExecStart=/usr/local/bin/looking-glass-shm.sh
ExecReload=/usr/local/bin/looking-glass-shm.sh
RemainAfterExit=true
#/usr/bin/bash
shm_file=/dev/shm/looking-glass
user=USER
group=kvm
perms=660
touch $shm_file && chown $user:$group $shm_file && chmod $perms $shm_file
On CLI
chmod +x /usr/local/bin/looking-glass-shm.sh
chmod +x /etc/systemd/system/looking-glass.service
systemctl daemon-reload
systemctl start looking-glass.service
Thanks for the suggestions. To the internet to research USB DACs.
After rebooting I am getting the permission issue again. Now removing the shm file and rectreating with “systemctl restart looking-glass.service” is not working:
Traceback
Error starting domain: internal error: process exited while connecting to monitor: 2020-04-22T21:50:02.570798Z qemu-system-x86_64: -object memory-backend-file,id=shmmem-shmem0,mem-path=/dev/shm/looking-glass,size=33554432,share=yes: can't open backing store /dev/shm/looking-glass for guest RAM: Permission denied
Traceback (most recent call last):
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 75, in cb_wrapper
callback(asyncjob, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/asyncjob.py", line 111, in tmpcb
callback(*args, **kwargs)
File "/usr/share/virt-manager/virtManager/object/libvirtobject.py", line 66, in newfn
ret = fn(self, *args, **kwargs)
File "/usr/share/virt-manager/virtManager/object/domain.py", line 1279, in startup
self._backend.create()
File "/usr/lib64/python3.7/site-packages/libvirt.py", line 1136, in create
if ret == -1: raise libvirtError ('virDomainCreate() failed', dom=self)
libvirt.libvirtError: internal error: process exited while connecting to monitor: 2020-04-22T21:50:02.570798Z qemu-system-x86_64: -object memory-backend-file,id=shmmem-shmem0,mem-path=/dev/shm/looking-glass,size=33554432,share=yes: can't open backing store /dev/shm/looking-glass for guest RAM: Permission denied
If I delete the shm file and then run the same touch-chown-chmod command then the VM will launch. Whether it is manually created, systemctl or tmpfiles.d the permissions look the same:
-rw-rw----. 1 USER kvm 0 Apr 22 12:00 /dev/shm/looking-glass
Wondering if this is something with SELinux?
UPDATE: Yup was SELinux. Newer install and didn’t have SETroubleshoot installed so I wasn’t being notified
. Resolved with:
ausearch -c ‘qemu-system-x86’ --raw | audit2allow -M my-qemusystemx86
semodule -X 300 -i my-qemusystemx86.pp
setsebool -P domain_can_mmap_files 1
After adding these files and config I’m unable get to the Fedora login screen. Every time I boot the primary (hopeful guest) gpu input shows the initial load screen and boot loader, then after selecting the standard Fedora install my secondary (hopeful host) gpu input shows the loading screen that is typically shown before the Fedora login screen, but after it finishes loading, it just shows a black screen instead of the login screen. Any ideas?
Update: Fixed the issue. In my case I’m binding the graphics card in my primary PCIE slot to the vfio drivers, so I needed to create an xorg configuration file (/etc/X11/xorg.conf.d/secondary-gpu.conf) telling Fedora to use the secondary GPU for the OS.
Section "Device"
Identifier "Device0"
Driver "amdgpu"
BusId "PCI:46:0:0"
EndSection
Worth noting here that even though my lspci -nnv output showed that the driver in use for my card was amdgpu, I actually needed a different equivalent driver for xorg for that card. You probably need a different xorg driver if you’re using nvidia, but here’s the command I used to get the necessary driver for my radeon card:
sudo dnf install xorg-x11-drv-amdgpu
Finally, it’s also worth noting that the BusId expects a number in decimal format, but the id shown in the lspci or ls-iommu outputs are in hex format. My cards was 00:2e:00.0, so the 2e became a 46 to get the BusID shown above.
Thanks for this detailed tuto. Trying to make it working on Fedora 32 but no luck. maybe a first question.
After installed a fresh F32, i have followed a tuto to install my Nvidia drivers.
| NVIDIA-SMI 440.82 Driver Version: 440.82 CUDA Version: 10.2 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| 0 GeForce RTX 208… Off | 00000000:0C:00.0 On | N/A |
| 35% 36C P8 2W / 260W | 296MiB / 11011MiB | 2% Default |
| Processes: GPU Memory |
| GPU PID Type Process name Usage |
| 0 2030 G /usr/libexec/Xorg 35MiB |
| 0 2459 G /usr/libexec/Xorg 83MiB |
| 0 2591 G /usr/bin/gnome-shell 158MiB |
0c:00.0 VGA compatible controller [0300]: NVIDIA Corporation TU102 [GeForce RTX 2080 Ti Rev. A] [10de:1e07] (rev a1) (prog-if 00 [VGA controller])
Subsystem: ZOTAC International (MCO) Ltd. Device [19da:1503]
Flags: bus master, fast devsel, latency 0, IRQ 132
Memory at f6000000 (32-bit, non-prefetchable) [size=16M]
Memory at e0000000 (64-bit, prefetchable) [size=256M]
Memory at f0000000 (64-bit, prefetchable) [size=32M]
I/O ports at e000 [size=128]
Expansion ROM at f7000000 [virtual] [disabled] [size=512K]
Capabilities: [60] Power Management version 3
Capabilities: [68] MSI: Enable+ Count=1/1 Maskable- 64bit+
Capabilities: [78] Express Legacy Endpoint, MSI 00
Capabilities: [100] Virtual Channel
Capabilities: [250] Latency Tolerance Reporting
Capabilities: [258] L1 PM Substates
Capabilities: [128] Power Budgeting <?>
Capabilities: [420] Advanced Error Reporting
Capabilities: [600] Vendor Specific Information: ID=0001 Rev=1 Len=024 <?>
Capabilities: [900] Secondary PCI Express
Capabilities: [bb0] Resizable BAR <?>
Kernel driver in use: nvidia
Kernel modules: nouveau, nvidia_drm, nvidia
Working well.
Now following this current tuto, after rebuild the initramfs and checked with the lsinitrd , all required modules and grub conf seems ok.
after reboot , the kernel hang. Before going more in detail, quick question:
is it possible to run on a single host the nvidia driver for linux to keep GPU performance AND the passtrough option and get VM guest performance also with only 1 GPU (2080TI in this case) or must have 2 GPU card inside my rig 1 for my native linux and 1 for my vm ?
Hope i’m clear
Thanks
No. Host OS needs a GPU and will load drivers and take control of the IOMMU group. To pass a GPU to a guest OS you need to skip loading drivers for it in when the host OS boots so the guest OS can load drivers and take control of it when it boots.
There are other methods of accelerating graphics. WIth virgil3d/virtio you might have some luck, but it is unlikely to be anything like pass through performance.
This has been incredibly useful! Thank you.
