I have the USW-KM314 Switch where the USB-Audio occasionally decides to not start properly causing my speakers (connected to the 3.5mm jack) to not work. I have tried multiple solutions including updating Microsoft’s wdma_usb.inf driver, setting the hub power management so that windows cannot turn it off, disabling fast boot/startup, and trying different USB cables/ports. None of these options seem to work. What’s worse is that I cannot diagnose why it is happening. It only happens occasionally. To fix, I uninstall the device, power the switch off by unplugging, and then re-plug the switch back in. I’m debating on switching back to analog audio/getting an external DAC. I do not believe the device should be starting incorrectly as much as it does. Any ideas for how to trouble shoot this would be greatly appreciated. Error codes are below:
