Ultimate 2x R9700 guide for Qwen 3.8 27b MXFP4: ~200t/s c=1; 500t/s at c=8
there isnt a mutually exclusive way, but there is a judge model role if you assign it here, then that will be the model for judging
Yeah, I’ve set that, just wanted a way to force one model to always be judge, but never be a worker bee. (That way I could force child workstreams onto other models and tune the judge separately.)
I’ve also found I can just tell the coordinator to spawn children with a specific model, and that usually does the trick.
Loading up multiple workstreams on the dual R9700 setup is indeed giving me 500+ tokens/s decode. Very nice!
Holy Carp :fish:! What a speedup!
512 tokens in 6.0s = 85.6 tok/s
I just hopped over from llama.cpp to radiance. Only 1 R9700 on AMD4.
Using qwen3.8-27b-mxfp4.rad
tp=1
Sanity check result:
python3 -c "
               import json, time, urllib.request
               t0 = time.time()
               req = urllib.request.Request(
                 'http://localhost:8300/v1/chat/completions',
                 data=json.dumps({
                   'model': 'qwen35',
                   'messages': [{'role': 'user', 'content': 'Write a short story about a sentient dot matrix printer.'}],
                   'max_tokens': 512,
                   'temperature': 0
                 }).encode(),
                 headers={'Content-Type': 'application/json'},
                 method='POST'
               resp = urllib.request.urlopen(req, timeout=300)
               t1 = time.time()
               result = json.loads(resp.read())
               tokens = result['usage']['completion_tokens']
               print(f'{tokens} tokens in {t1-t0:.1f}s = {tokens/(t1-t0):.1f} tok/s')
This feels over twice as fast as before!
Is this some dashboard from home assistant?
Qwen3.8-Flash-Next quantization and --tp 1 performance ladder
I wondered how fast and how good different quantizations of the excellent QFN model are in Radiance, and which one would work best for me. Now I have an idea.
Quantizations tested:
Published weights
q5-w5dn64-bf16ple: gostar77/qwen3.8-flash-next-radiance-q5-w5dn64-bf16ple on HF
fp8-iq4r: Project owner’s own StillDeadcode/qwen3.8-next-flash-fp8-iq4r-moe on HF
Homebrewed 8-bit quantizations
w8-pe-bf16ple: fp8 routed experts, int8 trunk, bf16 n-gram table, and the 10 protected experts from the official fp8-iq4r quantization.
fp8-pe-bf16ple: Same as above except with trunk quantized to fp8, same as the routed experts.
fp8-pe: Same as above except with n-gram table quantized to fp8 as well, same as that of the published fp8-iq4r container.
Quality
All comparison are made against the bf16 version of the same model, ran off the disk tier.
WikiText2
(Yes, I know it’s over-fitted since at least Alpaca/Vicuna, and probably overrepresents calibration effect.)
candidate KL mean KL med KL p99 top-1 ppl x Compare: ShareGPT text band
w8-pe-bf16ple 0.02264 0.00603 0.251 94.59% 1.0010x 0.0117
q5-w5dn64-bf16ple 0.03520 0.00940 0.397 93.28% 1.0041x 0.0175
fp8-pe-bf16ple 0.03928 0.01123 0.430 92.88% 1.0108x 0.0214
fp8-pe 0.04091 0.01148 0.445 92.88% 1.0114x 0.0202
fp8-iq4r 0.04393 0.01130 0.500 92.50% 1.0019x 0.0190
ShareGPT assistant band
Wrong chat template column: KL from chat trace with whatever chat template the ShareGPT data came with, rather than QFN’s own - That does interesting things with quantized models.
ShareGPT itself is likely OOD for an 2026 LLM, so please take the results below with a pinch of salt.
candidate KL mean KL med KL p99 top-1 ppl x Compare: Wrong chat template KL Compare: Wikitext KL
w8-pe-bf16ple 0.02911 0.00575 0.351 93.82% 0.9319x 0.1225 0.0226
q5-w5dn64-bf16ple 0.04846 0.00982 0.545 91.59% 0.9656x 0.1096 0.0352
fp8-iq4r 0.05258 0.01030 0.620 91.56% 1.1192x 0.1299 0.0439
fp8-pe-bf16ple 0.08600 0.01849 0.857 88.54% 0.7403x 0.1269 0.0393
fp8-pe 0.08919 0.01762 0.989 88.88% 0.7565x 0.1343 0.0409
Notes
All models are evaluated on 1.12.0-era bare-metal local build. Retest with main@8da043c showed zero delta.
Quantizing trunk to scaled fp8 ruins inference performance and more-or-less entirely offsets the gain from keeping the routed experts at fp8. I no longer run those containers.
Performance of the interesting quantizations at tp=1
Setup: 1x R9700(XFX) at 240W, PCIe 5.0 x16, 256GB DDR5-5200 JEDEC & 7800X3D host-side with WD SN8100 @ PCIe 5.0 x4 disk tier for model load and n-gram table, Ubuntu 24.04.5 LTS HWE, kernel 7.0.0.38, amdgpu 7.1.3, Radiance Docker releases 1.12.0 through 1.15.0.
w8-pe-bf16ple: Homebrewed max-quality quantization, i8 trunk, fp8 weight, bf16 PLE
118GiB + --prefix-cache-mib resident RAM with the below serving flags
Recipe:
blk.34.ffn_*_exps.407.weight         cast dtype=bf16
blk.34.ffn_*_exps.496.weight         cast dtype=bf16
blk.44.ffn_*_exps.292.weight         cast dtype=bf16
blk.44.ffn_*_exps.350.weight         cast dtype=bf16
blk.46.ffn_*_exps.290.weight         cast dtype=bf16
blk.46.ffn_*_exps.392.weight         cast dtype=bf16
blk.47.ffn_*_exps.122.weight         cast dtype=bf16
blk.47.ffn_*_exps.143.weight         cast dtype=bf16
blk.47.ffn_*_exps.399.weight         cast dtype=bf16
blk.47.ffn_*_exps.445.weight         cast dtype=bf16
blk.*.ffn_*_exps.*.weight            rtn  codes=fp8_e4m3 block=128x128 scale=bf16
*_hc_down.weight                     rtn  codes=fp8_e4m3 group=128 scale=f32
*_hc_up.weight                       rtn  codes=fp8_e4m3 group=80 scale=f32
mtp.fc_hidden.weight                 rtn  codes=fp8_e4m3 group=128 scale=f32
mtp.fc_embedding.weight              rtn  codes=fp8_e4m3 group=128 scale=f32
blk.*.attn_qg.weight                 rtn  codes=i8 group=128 scale=bf16 clamp=sym rule=search
blk.*.attn_k.weight                  rtn  codes=i8 group=128 scale=bf16 clamp=sym rule=search
blk.*.attn_v.weight                  rtn  codes=i8 group=128 scale=bf16 clamp=sym rule=search
blk.*.attn_output.weight             rtn  codes=i8 group=128 scale=bf16 clamp=sym rule=search
blk.*.ssm_inz.weight                 rtn  codes=i8 group=128 scale=bf16 clamp=sym rule=search
blk.*.ssm_out.weight                 rtn  codes=i8 group=128 scale=bf16 clamp=sym rule=search
blk.*.ffn_gate_up_shexp.weight       rtn  codes=i8 group=128 scale=bf16 clamp=sym rule=search
blk.*.ffn_down_shexp.weight          rtn  codes=i8 group=128 scale=bf16 clamp=sym rule=search
# No rule for blk.*.ple_ngram.weight, leaving it at original bf16
mtp.draft_head.weight                rtn  codes=u2 zero=u8 group=128 scale=f16
Serving flags:
      --model /models/qwen3.8-next-flash-w8-pe-bf16ple.rad
      --served-model-name Qwen/Qwen3.8-Flash-Next
      --host :: --port ${PORT:-8000} --api-key ${RADIANCE_API_KEY:?set RADIANCE_API_KEY in .env}
      --tp 1 --max-num-seqs 4 --max-model-len 262144
      --placement expert_tiered --host-pool-mib 114688 --gpu-headroom-mib 96 --ngram-placement disk
      --kv-cache-dtype bf16
      --prefix-cache-mib 16384
      --num-speculative-tokens 3 --draft-coupling on --max-num-batched-tokens 4096 --checkpoint-interval 4096
1.12.0
model test t/s (total) t/s (req) peak t/s peak t/s (req) ttfr (ms) est_ppt (ms) e2e_ttft (ms)
Qwen/Qwen3.8-Flash-Next pp8192 (c1) 2096.07 ± 23.90 2096.07 ± 23.90 3909.86 ± 44.84 3909.42 ± 44.84 3909.86 ± 44.84
Qwen/Qwen3.8-Flash-Next tg256 (c1) 48.98 ± 5.61 48.98 ± 5.61 49.67 ± 5.73 49.67 ± 5.73
Qwen/Qwen3.8-Flash-Next pp8192 (c2) 2156.31 ± 6.87 1078.23 ± 3.44 7599.07 ± 24.19 7598.63 ± 24.19 7599.07 ± 24.19
Qwen/Qwen3.8-Flash-Next tg256 (c2) 57.57 ± 1.08 29.45 ± 1.09 60.00 ± 1.63 30.00 ± 1.15
Qwen/Qwen3.8-Flash-Next pp8192 (c3) 1909.24 ± 13.00 774.90 ± 100.00 10767.80 ± 1509.06 10767.36 ± 1509.06 10767.80 ± 1509.06
Qwen/Qwen3.8-Flash-Next tg256 (c3) 52.70 ± 2.72 19.81 ± 2.61 61.33 ± 3.09 20.44 ± 2.54
Qwen/Qwen3.8-Flash-Next pp8192 (c4) 1973.62 ± 16.68 668.82 ± 191.85 13217.49 ± 3430.07 13217.05 ± 3430.07 13217.49 ± 3430.07
Qwen/Qwen3.8-Flash-Next tg256 (c4) 46.20 ± 1.25 15.25 ± 2.59 62.67 ± 0.94 15.75 ± 2.68
1.14.0
Qwen/Qwen3.8-Flash-Next pp8192 (c1) 2128.99 ± 2.55 2128.99 ± 2.55 3848.54 ± 4.58 3848.16 ± 4.58 3848.54 ± 4.58
Qwen/Qwen3.8-Flash-Next tg256 (c1) 45.50 ± 1.54 45.50 ± 1.54 46.00 ± 1.63 46.00 ± 1.63
Qwen/Qwen3.8-Flash-Next pp8192 (c2) 1973.89 ± 1.31 1035.90 ± 48.90 7927.14 ± 374.19 7926.76 ± 374.19 7927.14 ± 374.19
Qwen/Qwen3.8-Flash-Next tg256 (c2) 54.28 ± 2.53 28.73 ± 1.91 58.67 ± 3.30 29.33 ± 1.97
Qwen/Qwen3.8-Flash-Next pp8192 (c3) 1915.43 ± 5.73 794.55 ± 135.53 10603.80 ± 1739.75 10603.42 ± 1739.75 10603.80 ± 1739.75
Qwen/Qwen3.8-Flash-Next tg256 (c3) 48.97 ± 3.58 19.00 ± 2.62 58.67 ± 2.87 19.56 ± 2.75
Qwen/Qwen3.8-Flash-Next pp8192 (c4) 1998.15 ± 14.96 644.29 ± 151.54 13418.72 ± 3003.77 13418.35 ± 3003.77 13418.72 ± 3003.77
Qwen/Qwen3.8-Flash-Next tg256 (c4) 47.67 ± 0.81 15.50 ± 2.32 63.67 ± 2.05 15.92 ± 2.36
1.15.0
Qwen/Qwen3.8-Flash-Next pp8192 (c1) 2122.00 ± 11.92 2122.00 ± 11.92 3861.71 ± 21.99 3861.26 ± 21.99 3861.71 ± 21.99
Qwen/Qwen3.8-Flash-Next tg256 (c1) 47.99 ± 1.71 47.99 ± 1.71 48.67 ± 1.70 48.67 ± 1.70
Qwen/Qwen3.8-Flash-Next pp8192 (c2) 2040.26 ± 75.13 1055.64 ± 44.35 7775.57 ± 336.02 7775.13 ± 336.02 7775.57 ± 336.02
Qwen/Qwen3.8-Flash-Next tg256 (c2) 57.00 ± 1.62 30.34 ± 2.38 62.00 ± 3.74 31.00 ± 2.58
Qwen/Qwen3.8-Flash-Next pp8192 (c3) 1974.04 ± 21.23 823.94 ± 162.29 10308.64 ± 1874.01 10308.20 ± 1874.01 10308.64 ± 1874.01
Qwen/Qwen3.8-Flash-Next tg256 (c3) 49.13 ± 3.12 19.79 ± 2.85 60.67 ± 0.94 20.22 ± 2.90
Qwen/Qwen3.8-Flash-Next pp8192 (c4) 2004.00 ± 38.85 680.10 ± 192.45 12945.91 ± 3233.36 12945.46 ± 3233.36 12945.91 ± 3233.36
Qwen/Qwen3.8-Flash-Next tg256 (c4) 48.44 ± 1.90 16.17 ± 2.85 66.67 ± 0.94 16.67 ± 2.84
q5-w5dn64-bf16ple: gostar77/qwen3.8-flash-next-radiance-q5-w5dn64-bf16ple on HF, bf16 PLE
70GiB + --prefix-cache-mib resident RAM with the below serving flags
Serving flags:
      --model /models/qwen4exp-w5dn64-bf16ple-gptq.rad
      --placement expert_tiered --host-pool-mib 65536 --gpu-headroom-mib 96 --ngram-placement disk
      --prefix-cache-mib 16384 # probably not needed, 4096 serves fine, see results below
1.12.0
Qwen/Qwen3.8-Flash-Next pp8192 (c1) 3841.36 ± 14.11 3841.36 ± 14.11 2133.21 ± 7.94 2132.78 ± 7.94 2133.21 ± 7.94
Qwen/Qwen3.8-Flash-Next tg256 (c1) 97.24 ± 6.12 97.24 ± 6.12 97.67 ± 6.24 97.67 ± 6.24
Qwen/Qwen3.8-Flash-Next pp8192 (c2) 3883.51 ± 125.84 1942.00 ± 62.94 4223.62 ± 139.44 4223.19 ± 139.44 4223.62 ± 139.44
Qwen/Qwen3.8-Flash-Next tg256 (c2) 146.45 ± 3.15 74.66 ± 2.03 150.33 ± 1.89 75.17 ± 1.95
Qwen/Qwen3.8-Flash-Next pp8192 (c3) 3695.35 ± 36.05 1463.78 ± 167.62 5677.59 ± 698.90 5677.16 ± 698.90 5677.59 ± 698.90
Qwen/Qwen3.8-Flash-Next tg256 (c3) 122.30 ± 3.58 47.20 ± 6.52 143.33 ± 2.62 47.78 ± 6.39
Qwen/Qwen3.8-Flash-Next pp8192 (c4) 3771.60 ± 31.07 1279.25 ± 387.67 6930.41 ± 1774.40 6929.97 ± 1774.40 6930.41 ± 1774.40
Qwen/Qwen3.8-Flash-Next tg256 (c4) 107.63 ± 6.89 39.81 ± 9.18 161.00 ± 4.32 40.33 ± 9.08
1.14.0
Qwen/Qwen3.8-Flash-Next pp8192 (c1) 3883.53 ± 4.41 3883.53 ± 4.41 2110.23 ± 2.28 2109.77 ± 2.28 2110.23 ± 2.28
Qwen/Qwen3.8-Flash-Next tg256 (c1) 96.60 ± 5.07 96.60 ± 5.07 97.00 ± 4.97 97.00 ± 4.97
Qwen/Qwen3.8-Flash-Next pp8192 (c2) 3927.53 ± 100.81 1988.22 ± 45.02 4123.41 ± 96.18 4122.95 ± 96.18 4123.41 ± 96.18
Qwen/Qwen3.8-Flash-Next tg256 (c2) 133.18 ± 2.53 71.18 ± 3.73 143.00 ± 2.16 71.50 ± 3.55
Qwen/Qwen3.8-Flash-Next pp8192 (c3) 3689.36 ± 26.12 1512.12 ± 244.60 5556.40 ± 865.39 5555.94 ± 865.39 5556.40 ± 865.39
Qwen/Qwen3.8-Flash-Next tg256 (c3) 115.90 ± 8.32 46.44 ± 7.48 140.67 ± 1.70 46.89 ± 7.40
Qwen/Qwen3.8-Flash-Next pp8192 (c4) 3741.36 ± 56.82 1251.06 ± 348.95 7005.69 ± 1675.17 7005.23 ± 1675.17 7005.69 ± 1675.17
Qwen/Qwen3.8-Flash-Next tg256 (c4) 107.16 ± 7.38 38.16 ± 8.50 155.00 ± 6.38 38.75 ± 8.48
1.15.0
Qwen/Qwen3.8-Flash-Next pp8192 (c1) 3945.36 ± 73.86 3945.36 ± 73.86 2077.88 ± 38.38 2077.33 ± 38.38 2077.88 ± 38.38
Qwen/Qwen3.8-Flash-Next tg256 (c1) 98.24 ± 5.51 98.24 ± 5.51 98.67 ± 5.44 98.67 ± 5.44
Qwen/Qwen3.8-Flash-Next pp8192 (c2) 3787.46 ± 55.81 2083.60 ± 287.42 3996.12 ± 461.16 3995.57 ± 461.16 3996.12 ± 461.16
Qwen/Qwen3.8-Flash-Next tg256 (c2) 121.76 ± 9.37 69.00 ± 7.86 139.00 ± 6.16 69.50 ± 7.70
Qwen/Qwen3.8-Flash-Next pp8192 (c3) 3695.82 ± 3.92 1488.58 ± 263.39 5666.86 ± 930.49 5666.31 ± 930.49 5666.86 ± 930.49
Qwen/Qwen3.8-Flash-Next tg256 (c3) 118.77 ± 8.23 49.77 ± 7.43 151.33 ± 3.09 50.44 ± 7.38
Qwen/Qwen3.8-Flash-Next pp8192 (c4) 3788.99 ± 45.34 1254.64 ± 344.45 6966.75 ± 1626.05 6966.21 ± 1626.05 6966.75 ± 1626.05
Qwen/Qwen3.8-Flash-Next tg256 (c4) 111.75 ± 7.37 40.73 ± 9.64 165.33 ± 8.06 41.33 ± 9.54
fp8-iq4r: official StillDeadcode/qwen3.8-next-flash-fp8-iq4r-moe on HF
54GiB + --prefix-cache-mib resident RAM with the below serving flags
Serving flags:
      --model /models/qwen3.8-next-flash-fp8-iq4r-moe.rad
      --placement expert_tiered --host-pool-mib 49032 --gpu-headroom-mib 96 --ngram-placement disk
1.12.0
Qwen/Qwen3.8-Flash-Next pp8192 (c1) 3957.56 ± 13.55 3957.56 ± 13.55 2070.66 ± 7.09 2070.24 ± 7.09 2070.66 ± 7.09
Qwen/Qwen3.8-Flash-Next tg256 (c1) 104.54 ± 6.82 104.54 ± 6.82 105.00 ± 6.98 105.00 ± 6.98
Qwen/Qwen3.8-Flash-Next pp8192 (c2) 4106.83 ± 70.70 2057.13 ± 40.65 3984.61 ± 77.70 3984.19 ± 77.70 3984.61 ± 77.70
Qwen/Qwen3.8-Flash-Next tg256 (c2) 156.84 ± 10.50 81.39 ± 4.88 164.00 ± 7.12 82.00 ± 5.13
Qwen/Qwen3.8-Flash-Next pp8192 (c3) 3820.97 ± 35.71 1547.19 ± 233.36 5413.95 ± 794.29 5413.53 ± 794.29 5413.95 ± 794.29
Qwen/Qwen3.8-Flash-Next tg256 (c3) 135.40 ± 8.66 54.93 ± 9.21 166.67 ± 1.70 55.56 ± 9.20
Qwen/Qwen3.8-Flash-Next pp8192 (c4) 3907.31 ± 19.13 1248.67 ± 277.90 6885.01 ± 1460.96 6884.59 ± 1460.96 6885.01 ± 1460.96
Qwen/Qwen3.8-Flash-Next tg256 (c4) 124.79 ± 1.19 45.64 ± 10.68 184.33 ± 6.02 46.08 ± 10.59
1.14.0
Qwen/Qwen3.8-Flash-Next pp8192 (c1) 4005.07 ± 4.70 4005.07 ± 4.70 2046.13 ± 2.48 2045.74 ± 2.48 2046.13 ± 2.48
Qwen/Qwen3.8-Flash-Next tg256 (c1) 111.88 ± 0.79 111.88 ± 0.79 112.33 ± 0.94 112.33 ± 0.94
Qwen/Qwen3.8-Flash-Next pp8192 (c2) 4020.73 ± 72.47 2157.51 ± 280.35 3850.70 ± 410.47 3850.31 ± 410.47 3850.70 ± 410.47
Qwen/Qwen3.8-Flash-Next tg256 (c2) 146.48 ± 22.08 80.15 ± 9.17 161.00 ± 14.35 80.50 ± 9.27
Qwen/Qwen3.8-Flash-Next pp8192 (c3) 3913.13 ± 24.55 1560.92 ± 265.46 5390.43 ± 841.39 5390.04 ± 841.39 5390.43 ± 841.39
Qwen/Qwen3.8-Flash-Next tg256 (c3) 133.23 ± 8.92 54.78 ± 9.20 165.33 ± 5.31 55.11 ± 9.17
Qwen/Qwen3.8-Flash-Next pp8192 (c4) 3981.68 ± 7.70 1347.96 ± 413.82 6594.91 ± 1719.22 6594.52 ± 1719.22 6594.91 ± 1719.22
Qwen/Qwen3.8-Flash-Next tg256 (c4) 111.80 ± 13.03 45.38 ± 15.36 182.33 ± 11.90 45.92 ± 15.36
1.15.0
Qwen/Qwen3.8-Flash-Next pp8192 (c1) 4022.99 ± 3.67 4022.99 ± 3.67 2037.04 ± 1.86 2036.55 ± 1.86 2037.04 ± 1.86
Qwen/Qwen3.8-Flash-Next tg256 (c1) 111.81 ± 7.00 111.81 ± 7.00 112.33 ± 7.04 112.33 ± 7.04
Qwen/Qwen3.8-Flash-Next pp8192 (c2) 4050.87 ± 112.56 2181.14 ± 272.04 3806.01 ± 398.19 3805.52 ± 398.19 3806.01 ± 398.19
Qwen/Qwen3.8-Flash-Next tg256 (c2) 144.85 ± 20.48 78.45 ± 9.44 157.67 ± 8.99 78.83 ± 9.62
Qwen/Qwen3.8-Flash-Next pp8192 (c3) 3884.06 ± 39.40 1530.13 ± 170.57 5427.17 ± 648.13 5426.68 ± 648.13 5427.17 ± 648.13
Qwen/Qwen3.8-Flash-Next tg256 (c3) 143.59 ± 1.28 55.66 ± 7.59 168.67 ± 1.70 56.22 ± 7.63
Qwen/Qwen3.8-Flash-Next pp8192 (c4) 3955.49 ± 21.06 1318.94 ± 364.86 6665.56 ± 1666.43 6665.07 ± 1666.43 6665.56 ± 1666.43
Qwen/Qwen3.8-Flash-Next tg256 (c4) 122.57 ± 5.59 45.45 ± 11.41 183.67 ± 2.05 45.92 ± 11.35
All quantizations tested with llama-benchy at 0.4.1.dev1+ge9be34457
Other notes
At tp=1, serving QFN at 4-bit requires 64GB, 5-bit requires 96GB, and 8-bit requires 128GB host RAM, with the prefix cache running right up against and not quite fitting within the capacity limit at 4-bit and 8-bit. An expensive proposition, when a single 2x64GB kit is right up there with another R9700.
Leaving the n-gram table at bf16 is almost free except for the ~50GB additional consumption of fast storage, for the minimal improvement it provides.
Loading the n-gram table into RAM (–ngram-placement ram, not included in the test above) would provide 150~200tok/s additional prefill speed at 1.14.0 on this setup for ~50-100GB of additional RAM consumption. 1.15.0 closed the gap further with a related bugfix. Not worth it with SSD.
c=2 shows best overall throughput on tp=1, though even c=4 still gains over c=1, under benchmark conditions; In production, any concurrent prefill on tp=1 slows decode to a crawl. I do not know whether more cards would improve this behaviour.
PCIe bandwidth is impactful for models with large portion of its experts in the host RAM tier. I used to get ~2.7kt/s prefill on fp8-iq4r on an earlier version of Radiance, with PCIe 4.0 x16 on the same card. On PCIe 5.0 x16 it is ~4.0kt/s.
5-bit quantization is better than 4-bit, and 8-bit even better though by how much, I don’t know - except probably long-context and OOD performance, correlated with other’s benchmarks at similar bit-depth on vLLM..
tp=2 (7Kt/s+ prefill with fp8-iq4r, faster c=1 decode, much faster c=2+ decode as reported above) is probably optimal for obtaining cost-effective service-grade QFN inference, but tp=1 might still be perfectly usable for single user up to c=4 with 64GB-128GB host RAM.
Results align with Unsloth GGUF QFN quants topping out at ~94% top-1 agreement by their benchmarks. For most other models, this should have been ~98%+ by W8/Q8_0. No idea what’s causing this, or the kind of accuracy penalty this implies without actual long-context comparisons.
Hope this helps someone.
Nice work - that pretty much aligns with my (subjective) experience of trying a few models (including a homebrew FP8 quant of mine). I think gostar77’s Q5 quant is the best compromise of quality vs speed for practical uses, for me at least.
It’s a Grafana dashboard I have running on the Turnstone node.
Man…agentic coding with this thing is nuts.
220-230t/s decode at 150k+ context. The prefill looks low, but that’s only because most of the context is cached, so it’s barely getting started before it stops on each incremental addition.
can you imagine a world where 128gb strix halo is by this point < $2000 MSRP it’s supposed to be. And power users like us could be running 8-16 agents across 2-4 halo boxes that are shared-nothing…
I think I might settle for the R9700 (or R10700, or whatever) being back down to the price it launched at…
Or maybe the R10700/R11700 being 64GB, at a reasonable price point.
Yes, I would like to purchase 2 more R9700’s to finish out my build if prices ever go back down.
One of the online stores here was selling refurbished power color units at $400 below the current rate a few weeks ago, I missed out unfortunately. Probably just returns for coil whine or fans too loud.
Scan still have the Powercolor R9700s at the £1609 price here in the UK - I got one, and it was definitely not a return or refurb.
They are currently ~£1410($1890USD) in Australia, the refurbs were £1175 ($1575 USD). They really jumped up as soon as the alphacool waterblocks were released. The gigabyte models were already at the current price, while the others sat around $1610 USD. All the same now.
My 3xR9700 build cobbled together from spare parts is finally (almost) complete.
Had a spare x570, 5950X, 64GB DDR4, and 2TB Gen5 NVME drive laying around from when I did an am5 platform upgrade on my gaming machine. Was initially running the R9700’s in x8/x8/x4 (x4 on chiptset), but the gen4 plx card arrived over the weekend, and now all three are running gen4 x16 off it, which also is now x16 gen 4 on the motherboard.
GPU’s are mounted to the back of the case with 3d printed adapters (currently on rev10, lets see if 11 fits perfectly). I also shoved a glinet atx board in it, and because I’m weird an nvidia dpu2 (the measly 25g one) in the x4 chipset slot.
I do also have a strix halo, and I currently have both of them working on the software side, making a proxy that also can control the power for the R9700 machine in addition to model swapping. Even at 60W idle, I pay .60 kwh which can add up fast (and I hate giving PGE money). The majority of the time I expect that the strix halo will be enough to handle requests coming in, only firing up the big machine when needed. In theory.
Hypothetically, if I bought a 5090 back in January when they were selling for 6000 AUD (~4200 USD) and now they retail locally for 13000 AUD (~9100 USD), while R9700s are selling for between 2700 AUD (ASRock, XFX) to 2800 AUD (Gigabyte; other AIB partner cards like ASUS and Sapphire et al. not available), if my 5090 was still new-in-box, would it be unreasonable for me to contact the store and request a return/exchange for a set of 3x R9700s?
The 5090 was planned to go into a gaming build but I’ve been too busy with IRL stuff this year to even unbox it, and it’s become so valuable now I’ll probably get robbed trying to sell it; in theory, exchanging it with the store is less risky, and they stand to make like 4-5 grand with this exchange if such a trade would be viable, but then I also wonder if the other parts I’d picked up for the gaming build would be useful in an AI workstation, specifically- CPU = 9800X3D, RAM = 32GB (2x16) DDR5 6000 CL26, Mobo = MSI B850MPOWER which only has 2x DIMM slots (other than needing a higher wattage PSU though the rest should be fine, eg. Case = Silverstone ALTA D1).
I only got one R9700. My productivity isn’t worth another R9700. I am the bottleneck in the loop.
Good taste!
I just picked up Gigabyte X870 Tachyon ICE last week with discount. I happened to have an 8000MT/s 2x24GB kit. Plan to pair it with upcoming Zen 6. The current AMD’s bottleneck is the infinity fabric between IOD and CCD. It only has 64GB read and 32GB write bandwidth (if I recall correctly). Thus, here is not much benefit to go above 6000MT/s right now. I wish Zen 6 can fully utilize the bandwidth of high speed DDR5, something like 128GB/s with 8000MT/s.
I know that my decision of specifying a single R9700 for link-limited RAM-offloaded inference is turning out to be retrospectively suboptimal. Now the cost is definitely prohibitive, and I’ve just switched motherboard to get PCIe 5.0.
Now I can’t wait to find out how DSV4.1-Flash would do when the support merges. Probably not too well on tp=1, but it would still be interesting.
Theoretically, that hypothetical 5090 would still be the superior compute card for anything except VRAM capacity when compared to a 2-3x R9700 cluster, if you have the need for it. Little surprise they are removing it from the market and selling the Pro variety with more VRAM and for much more money instead.
Unfortunately this is where I am too. Buyers regret at PCIe 3.0 x 16 using TP1 for models like QFN - I’m at about 2/3rd the performance of other people after a lot of tuning, except for 27B model at ~4bpw quants fly.
I assume going up to TP2 on PCIe 3.0 x 16 would be better performance for QFN; less weights to shuffle around. But then there’s the potential that I would still have a severe bottleneck for transferring caches around.
