Ultimate 2x R9700 guide for Qwen 3.8 27b MXFP4: ~200t/s c=1; 500t/s at c=8
I’m sure it will for 4/5-bit versions as the VRAM covers most of the weights. If both cards are on PCIe 3.0 x16 then it should at least be comparable to the PCIe 4.0 x8/x8 setups that are still common.
PCIE Gen5 8x/8x motherboard is $319. If you need more than 2 GPUS, it could get pricey with Threadripper, Epyc or Xeon. You maybe able to get a Refurbished Lenovo ThinkStation P620 3945WX. Not sure how to fit multiple R9700s in there.
I don’t think anybody’s managed to do any like-for-like testing, but there’s been some anecdotal evidence that PCIE 5.0 x8/x8 on a consumer board isn’t actually as fast in radiance as PCIE 4.0 x16/x16 on a Threadripper/EPYC board.
Strikes me as a job for a YouTuber with a ludicrous amount of hardware lying around. Paging @wendell :slight_smile:
PCIE 5.0 x8/x8. 64GB. Dual R9700. Model: qwen3.8-next-flash-fp8-iq4r-moe
| test               |    t/s (Radiance 1.15.1) |     ttfr | 11e (old engine) | Δ vs 11e |
| pp2048             |   6790.7 ±56 |   302 ms |          — | ~parity  |
| tg1024             | **179.5 ±1.7** |   302 ms |        181.4 | −1% (noise) |
| tg1024 @ d4096     |   174.7 ±11.0 |   888 ms |        170.9 | +2% |
| tg1024 @ d32768    |   184.3 ±10.1 |  4901 ms |        192.8 | −4% (noise) |
| tg1024 @ d131072   |   **199.7 ±9.8** | 19366 ms |        196.8 | +1.4% |
| tg1024 @ d196608   |   **210.8 ±12.1** | 29477 ms |        187.2 | **+12.6%** |
@deepfreezed - It won’t really affect decode, PCIE bandwidth and latency is far more important for prefill.
Also, it’s better to try pp4096 or pp8192.
There has been no update to DS4.1-Flash support for some days, and Issue 382 reports KLD regression on QFN with 1.16.0.
Haven’t upgraded beyond 1.15.1 myself, but how well DS4.1-Flash at 2- to 3-bit performs against QFN at 5- to 8-bit, I might well pull the merge author’s fork to find out…The old V3/R1 did fine, but they did not do much tool calls.
Would you mind elaborating? :slight_smile:
Like, what is the context you’re using DS4.1 Flash to build? What System Roles and prompting do you have? What harness and what judge model? So you use it for planning or implementation or both?
Just trying to get a sense of how well that model does for various components and pipelines - especially for how much attention these Q1 and Q2 variants are getting with MoE offloading.
It would have been stock Hermes Agent harness for the moment, I expect. I do not think a 2-bit quant could be much more than a fun experiment even with Unsloth’s imatrix, but I might be surprised.
It could well be a good planner for personal projects or for creative uses the same way V3/R1 was, even if long-context tool loops probably won’t hold at that bit count.
I think Hermes Agent by default uses the main model as the closest thing it had to a judge model. Fine by me for my use case.
Either way the model would have to finish quantizing first. I have just (re-)learned that imatrix quantization is slow, ~60MB/s on the source model with an 8-core Zen 4 with rad-convert.
Ooooo….see comment here:
Radiance 2.0 might support multiple models per instance. That would actually be really useful for me, because I’m in the early stages of a project which could potentially need TTS, STT and image gen models on one card (although STT might be able to run on CPU, depending on latency).
I’ll be interest to see how it affects latency. My current setup translates stt, sends to llm, llm sends response to stt, stt returns it to the client, memory model runs in the background when other processes are idle.
I imagine it could improve response times for longer replies quite a bit.
I’ve tracked enough benchmarks on launch80 discord from multiple self reported folks and can safely say , pcie5 x8/x8 is almost as good as pcie4 x16/x16
We even have a benchmarks page where we’ve been tracking everyone’s rigs , pcie4 pcie5 , ddr4 ddr5
TP2 TP3 TP4 etc , but mostly based on radiance vllm forks, tcclaviger and new radiance engine
I’d be interested in getting hindsight operations off of Qwen3.8 onto a dedicated smaller model. However my 2 cards on radiance Swift 1.5 don’t seem to struggle with the overhead. Also, someone needs to develop an active compaction mode which predicts the next compaction turn and already has it locked in when quota hits.
Has anyone tried the IQ4R-L-V4 recipe? 24% lower quality-loss than the official FP8 checkpoint at 55% of its size?
I use embeddinggemma2 as the embeddingmodel in hindsight and it works great. Less than 1GB
I am another Radiance user. My rig is the following specs.
AMD Ryzen 9950x3d
Gigabyte X870e X3d Ice
2x48gb 5600 ddr5 g.skill
Samsung 9100 pro 2tb nvme
running on Windows 11 pro. (this is different from most radiance setups)
I had to port radiance to windows, but it works, and works very well. tokens/second and prefill are on par with linux users and it is reliable enough to run for days with no problems without restarts
There is another user who also ported Radiance to Windows and he released his, it’s called “Brilliance”
DeepSeek-V4.1-Flash, iq2_xxs on --tp 1
baKon’s development fork @ acc9ae5, the 1.15.0 upstream merge from a few days ago, on --tp 1, with the provided recipe except all iq1_s changed to iq2_xxs, quantized with Unsloth’s imatrix.
Model is 277.2GB total. Resident memory 166GiB after benchmark.
Parameters
1xR9700@240W, PCIe 5.0 x16, DDR5-5200
    --tp 1 \
    --placement expert_tiered \
    --kv-cache-dtype bf16 \
    --ngram-placement disk \
    --host-pool-mib 147456 \
    --host-headroom-mib 16384 \
    --embedding-placement vram \
    --max-num-seqs 2 \
    --max-model-len 1048576 \
    --max-num-batched-tokens 8192 \
    --checkpoint-interval 8192 \
    --checkpoint-slots 32
model test t/s (total) t/s (req) peak t/s peak t/s (req) ttfr (ms) est_ppt (ms) e2e_ttft (ms)
deepseek-ai/DeepSeek-V4.1-Flash-1017 pp8192 (c1) 1256.15 ± 18.41 1256.15 ± 18.41 6523.43 ± 96.60 6522.92 ± 96.60 6523.43 ± 96.60
deepseek-ai/DeepSeek-V4.1-Flash-1017 tg256 (c1) 12.74 ± 0.34 12.74 ± 0.34 13.33 ± 0.47 13.33 ± 0.47
deepseek-ai/DeepSeek-V4.1-Flash-1017 pp8192 (c2) 1205.69 ± 24.12 711.28 ± 238.94 12394.30 ± 2612.41 12393.79 ± 2612.41 12394.30 ± 2612.41
deepseek-ai/DeepSeek-V4.1-Flash-1017 tg256 (c2) 13.88 ± 0.95 7.38 ± 0.20 16.00 ± 0.00 8.00 ± 0.00
2x1M tokens of KV cache is also only 6.6GiB, but whether the model remains sufficiently intact to make that huge context window useful at iq2_xxs is a separate matter.
DSpark acceptance on the llama-benchy test set is also low at 42% on the first token, 13% through 5 on the above benchmark. I do now know whether this is normal. Prefill staging is also not active during the benchmark.
Perfomance is still looking compelling for something this size.
DDR5-5200, 4 sticks or 2?
Also, is the fork attempting to support DeepSeek? Radiance official does not state it supports DeepSeek.
4 sticks, on AM5. Cannot reach 128GB+ without that.
It’s not too unreasonable back in mid-2025, but sadly not anymore.
It’s one of the contributors’ development fork. Right now it’s still missing vision and tool support. For reference, there’s a pull request at the upstream repo.
ok, I finally had some time to work on getting things cooperating/working.
Brushed-up my skills with using podman for containers, got radiance up, then open-webui, and was able to sync the two.
Getting Radiance up (and running):
RENDER_GID=$(getent group render | cut -d: -f3)
VIDEO_GID=$(getent group video | cut -d: -f3)
podman run --rm -it \
  --device /dev/kfd --device /dev/dri \
  --group-add ${RENDER_GID} --group-add ${VIDEO_GID} \
  --ipc host --network host \
  --security-opt seccomp=unconfined --cap-add=SYS_PTRACE \
  --ulimit memlock=-1:-1 \
  -e HIP_VISIBLE_DEVICES=0,1 \
  -v /srv/models/rad/qwen3.8-27b-fp8.rad:/model.rad:ro \
  --name radiance \
  stilldeadcode/radiance:latest \
  --model /model.rad \
  --tp 2 --tp-wire wht6 \
  --max-model-len 409600 \
  --max-num-seqs 8 \
  --kv-cache-dtype fp8 \
  --gpu-headroom-mib 96 \
  --num-speculative-tokens 7 \
  --host 0.0.0.0 --port 8300
Stats from running Wendell’s breakout_prompt.txt:
cache_n: 6144
prompt_n: 7984
prompt_ms: 1545.860937
prompt_per_token_ms:
0.19361985683867736
prompt_per_second:
5164.75952584343
predicted_n: 99997
predicted_ms:
854096.599845
predicted_per_token_ms:
8.54130765075603
predicted_per_second:
117.07809165631511
ttft_ms: 1565.621338
total_ms: 855662.221183
draft_n: 206584
draft_n_accepted: 70484
input_tokens: 14128
output_tokens: 99997
total_tokens: 114125
Do not have the understanding yet to interpret those stats.
I have the Gigabyte slotted above the XFX (~5mm spacing) on the H13SAE-MF. The Δt was 98C/47C (respectively), fans were full-bore the entire time, and the box was tapping 640+W at the wall. Forgot to measure dB’s, but the noise was enough that I’d want to house her in another room if I were to be doing long runs like this regularly :wink:
I have what it takes to extend the XFS card (using a 8cm PCIe 5.0 riser) to enable better intake for the Gigabyte, but I’m dallying on that next-step.
More to come…
What model?
Quick look:
prompt_n is prefill, so you’re getting a lovely 5,165 tok/s
predicted_per_second: 117.07809165631511 tok/s - mine averages 130tok/s
ttft (time to first token) is excellend at 1.57s (I get 2.65s)
Your draft acceptance is low. I average 49%. Not sure what improvements you could make, but this would give you more speed.
thx!
qwen3.8-27b-fp8.rad
This is the first time I’ve actually gotten everything to play well together. Prompt flags had to be modified a bit to cater to podman, and I’m still learning how to adjust.
Radiance [W]arnings:
W --max-model-len 409600 is past the 262144 positions the model was trained on and nothing scales its ro
tary, so positions beyond them are extrapolated; a model card's YaRN extension is --rope-scaling yarn:FA
CTOR (docs/YARN.md)
W kernel plugin 'libhalo' has no device code for device 0: the fat binary has code objects for [gfx1151] and this card runs [gfx1201, gfx12-generic]. Its 487 device kernel(s) are left out of selection here.
W kernel plugin 'libr3d' has no device code for device 0: the fat binary has code objects for [gfx1151, gfx11-generic] and this card runs [gfx1201, gfx12-generic]. Its 109 device kernel(s) are left out of selection here.
W tp wire: LOSSY (--tp-wire wht6) at 128 KiB a message and above. A cross-rank all-reduce of that size carries a quantised payload instead of bf16 (libr4d's is Walsh-Hadamard-rotated 6-bit at two ranks and tiered int8 at three and four), so this process does not compute the same function the exact wire does. Steps of at most 12 rows are exact: single-sequence decode, and a decode step until sequences x (1 + speculative depth) passes that; prefill and a busy decode step are lossy. --tp-wire-min-kb moves the floor.
W startup report: cards-differ: the cards serving this model are not set up alike -- root port link: 32.0 GT/s x4 on 0000:06:00.0; 32.0 GT/s x8 on 0000:03:00.0; top PCIe power level: 2: 32.0GT/s, x4 1143Mhz on 0000:06:00.0; 2: 32.0GT/s, x8 1143Mhz on 0000:03:00.0. Fix: make the settings match (the power cap and voltage offset are per card under /sys/class/drm/cardN/device; set them with the server stopped)
:03:00.0 is the Gigabyte (HIP 0)
:06:00.0 is the XFS (HIP 1)
:12:00.0 is the integrated GPU (HIP 2)
Guessing this is a combo of the PHY shenanigans inherent in the H13SAE-MF mixed with having the 4565P’s integrated gpu, though I have explicitly asserted:
Much more to learn!
