Trying to GPU-Passthrough on demand
Few of you have seen my (and others) struggle to use AMD Ryzen 7xxx iGPU for host, while isolating the dGPU for our VMs.
This post has a lot of information and the problems few people facing.
I had a workaround that was convenient, where I had my “shared” monitor off, until the boot menu loads up, and then I was switching it on, and worked seamlessly, and was trouble free even with multiple VM reboots.
However, I replaced my monitor few days ago and now that workaround is not working anymore, so I need to get under the desk, remove the cable, boot, and after I boot up the VM, to plug the cable… This is very inconvenient I must say…
So, I need your help to solve this once and for all.
I was thinking to try a modified “single-GPU-passthrough” technique, but have my host still running on my iGPU as it is now. So, what I need to do is just “ignore” my dGPU, and just pass it through on demand when I am starting a VM.
Steve has a demo here how it is done, but they don’t have a tutorial of the scripts etc they are using.
Tried to follow his guide on their blog, but few things not working.
So, when I try to run the “nvidia-disable” commands, which executes this:
sudo rmmod nvidia_modeset nvidia_uvm nvidia && echo "NVIDIA drivers removed" && sudo modprobe -i vfio_pci vfio_pci_core vfio_iommu_type1 && echo "VFIO drivers added" && sudo virsh nodedev-detach pci_0000_01_00_0 && echo "GPU detached (now vfio ready)" && echo "COMPLETED!"'
I am getting an error:
rmmod: ERROR: Module nvidia_modeset is in use by: nvidia_drm
rmmod: ERROR: Module nvidia is in use by: nvidia_modeset
Can somebody guide me through this please?
inxi -F
System:
  Host: wizzy-manjaro-kde6 Kernel: 6.10.5-1-MANJARO arch: x86_64 bits: 64
  Desktop: KDE Plasma v: 6.0.5 Distro: Manjaro Linux
Machine:
  Type: Desktop System: Gigabyte product: X670E AORUS MASTER v: -CF
    serial: <superuser required>
  Mobo: Gigabyte model: X670E AORUS MASTER serial: <superuser required>
    UEFI: American Megatrends LLC. v: F30 date: 05/22/2024
CPU:
  Info: 16-core model: AMD Ryzen 9 7950X3D bits: 64 type: MT MCP MCM cache:
    L2: 16 MiB
  Speed (MHz): avg: 2992 min/max: 545/5759 cores: 1: 3305 2: 3228 3: 3932
    4: 3229 5: 4510 6: 3625 7: 545 8: 545 9: 3190 10: 545 11: 3888 12: 545
    13: 3169 14: 3164 15: 3388 16: 4746 17: 3221 18: 3125 19: 545 20: 3168
    21: 4631 22: 3908 23: 3182 24: 545 25: 3796 26: 3185 27: 545 28: 3199
    29: 4418 30: 4725 31: 3648 32: 4368
Graphics:
  Device-1: NVIDIA AD103 [GeForce RTX 4080] driver: nvidia v: 550.107.02
  Device-2: AMD Raphael driver: amdgpu v: kernel
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_wayland driver: X: loaded: amdgpu,nouveau
    unloaded: modesetting failed: nvidia dri: radeonsi gpu: nvidia,amdgpu
    resolution: 1: 3440x1440 2: 1440x2560
  API: EGL v: 1.5 drivers: kms_swrast,nvidia,radeonsi,swrast
    platforms: gbm,wayland,x11,surfaceless,device
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 24.1.6-arch1.1
    renderer: llvmpipe (LLVM 18.1.8 256 bits)
  API: Vulkan v: 1.3.279 drivers: nvidia,radv surfaces: xcb,xlib,wayland
Audio:
  Device-1: NVIDIA driver: snd_hda_intel
  Device-2: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB
  Device-3: Creative Sound Blaster X5
    driver: cdc_acm,hid-generic,snd-usb-audio,usbhid type: USB
  Device-4: KTMicro USB_Audio_Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB
  API: ALSA v: k6.10.5-1-MANJARO status: kernel-api
  Server-1: PipeWire v: 1.2.2 status: active
Network:
  Device-1: Intel 82576 Gigabit Network driver: igb
  IF: enp12s0f0 state: up speed: 1000 Mbps duplex: full
    mac: 98:b7:85:01:e3:3e
  Device-2: Intel 82576 Gigabit Network driver: igb
  IF: enp12s0f1 state: down mac: 98:b7:85:01:e3:3f
  Device-3: Intel Ethernet I225-V driver: igc
  IF: enp13s0 state: up speed: 1000 Mbps duplex: full mac: 74:56:3c:4b:74:7e
  Device-4: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
  IF: wlp14s0 state: down mac: 5a:0a:dd:f2:bd:20
  Device-5: Realtek RTL8153 Gigabit Ethernet Adapter driver: r8152 type: USB
  IF: enp22s0u1u2u3 state: up speed: 1000 Mbps duplex: full
    mac: 34:1b:22:83:0f:1f
  IF-ID-1: virbr0 state: down mac: 52:54:00:3d:8b:7c
Bluetooth:
  Device-1: Intel AX210 Bluetooth driver: btusb type: USB
  Report: rfkill ID: hci0 rfk-id: 0 state: down bt-service: enabled,running
    rfk-block: hardware: no software: yes address: see --recommends
Drives:
  Local Storage: total: 5.52 TiB used: 1.19 TiB (21.6%)
  ID-1: /dev/nvme0n1 vendor: Kingston model: SKC3000D2048G size: 1.86 TiB
  ID-2: /dev/nvme1n1 vendor: Seagate model: XPG GAMMIX S50 Lite
  ID-3: /dev/nvme2n1 vendor: Samsung model: SSD 970 EVO 500GB
  ID-4: /dev/sda vendor: Crucial model: CT2000BX500SSD1 size: 1.82 TiB
  ID-5: /dev/sdb vendor: Samsung model: SSD 850 EVO 500GB size: 465.76 GiB
Partition:
  ID-1: / size: 448.43 GiB used: 34.05 GiB (7.6%) fs: ext4 dev: /dev/nvme2n1p2
  ID-2: /boot/efi size: 299.4 MiB used: 296 KiB (0.1%) fs: vfat
    dev: /dev/nvme2n1p1
Swap:
  ID-1: swap-1 type: partition size: 8.8 GiB used: 10.2 MiB (0.1%)
    dev: /dev/nvme2n1p3
Sensors:
  System Temperatures: cpu: 40.6 C mobo: N/A gpu: amdgpu temp: 36.0 C
  Fan Speeds (rpm): N/A
Info:
  Memory: total: 64 GiB note: est. available: 61.76 GiB
    used: 41.54 GiB (67.3%)
  Processes: 546 Uptime: 1h 26m Shell: Zsh inxi: 3.3.35
Anyone?
I have been fighting this f* thing for days and haven’t been able to make it work… :worried:
Start with sudo lsof /dev/nvidia0. This shows which processes are using the GPU. Some process is using the GPU so the driver can’t be unloaded.
The method looks to be essentially the same as the proven pass through of a guest-only GPU where the GPU is bound to vfio-pci on bootup. Only on top of that, it has some scripts to attach the GPU to the host OS later on (or detach once more) and render through that.
If I understand you correctly, the issue you are dealing with is already without trying the ‘attach+detach’ scripts. To prevent the nvidia drivers from grabbing the card (or any GPU driver for that matter) on bootup, which you most probably should, the usual approach is to attach the GPU to the vfio-pci driver during early bootup.
I’m using the following configuration (replace the device IDs as shown by lspci -nn):
/etc/modprobe.d/vfio.conf:
#Use the correct device IDs for your system
options vfio-pci ids=1002:73df,1002:ab28
/etc/mkinitcpio.conf:
MODULES=(... vfio_pci vfio vfio_iommu_type1 ...)
HOOKS=(... modconf ...)
Rebuild initramfs via mkinitcpio.
(I’m surprised to see attaching+detaching working in the guide with GDM; back when I tried, Gnome/GDM held on to the device and didn’t let me detach the driver anymore, even after sending a remove uevent, so I gave up on that)
If that config doesn’t boot (I stumbled on some other post of yours), check your mainboard firmware setup if you can set it to always prefer the iGPU. If that doesn’t work, try adding video=efifb:off to the kernel command line. However, that will hide the boot screen.
Thank you for your reply. I tried that config multiple times, it doesn’t work.
I also tried to have “amdgpu” loaded before vfio modules, or at the end. Different behavior, but none of them worked either.
Made that change, again different behavior, again, didn’t work:
@quilt when I boot without the cable attached, cause this is the only way I can, I am getting this:
lsof: WARNING: can't stat() fuse.portal file system /run/user/1000/doc
      Output information may be incomplete.
lsof: status error on /dev/nvidia0: No such file or directory
Strange, is there any other Nvidia file under /dev?
Nope, nothing that would ring a bell. There are video0, video1 but when I am trying lsof, I am getting:
sudo lsof /dev/video0         ✔
[sudo] password for wizard:
And the nvidia module is loaded? AFAIK there should be an NVIDIA file in /dev if the driver is loaded
When I have the cable detached, it works ok, meaning, Nvidia is controlled by the vfio driver.
01:00.0 VGA compatible controller [0300]: NVIDIA Corporation AD103 [GeForce RTX 4080] [10de:2704] (rev a1)
        Subsystem: Gigabyte Technology Co., Ltd Device [1458:40bc]
        Kernel driver in use: vfio-pci
        Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device [0403]: NVIDIA Corporation Device [10de:22bb] (rev a1)
        Kernel modules: snd_hda_intel
15:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Raphael [1002:164e] (rev c9)
        Subsystem: Gigabyte Technology Co., Ltd Device [1458:d000]
        Kernel driver in use: amdgpu
        Kernel modules: amdgpu
When I am attaching the cable before boot, it is not, and then I have a blank screen. I can try to make it fail and give you the output then.
UPDATE:
I couldn’t find a solution on how to do the above, however, my original concept was to have my VM working with VGA pass-through, and since it was failing to assign vfio drivers on the Nvidia on boot, I was looking to do it later on, on demand.
That became very confusing and I was hitting a wall, so I looked around and found a user willing to help, but his knowledge was around Fedora, instead of Manjaro.
So, I did try to apply his suggested steps to Fedora, and worked flawlessly, and not I don’t even need that workaround where I had to keep my main monitor off, until the boot menu to work.
My understanding is that Dracut, default initramfs generator for Fedora 40, works differently and thus can properly load the correct drivers, bypassing or overriding UEFI’s stack, while mkinitcpio does not and once my PCIe VGA is used for POST, it cannot get a hold of it.
I have contacted Gigabyte for that issue, cause for me this is 100% BIOS problem, but I don’t expect much.
Anyway, if you have a similar issue, try installing Dracut (works for Manjaro), and see if that solves the issue.
Another small update.
Gigabyte finally released a fixed BIOS version (33x) where they do actually address the iGPU/dGPU issue (among others, like turning off LEDs when shutdown).
However, Manjaro still does not work correct with mkinitcpio.
Didn’t try with Dracut, I was so pissed, I revert to Fedora 40, which I don’t really like, but at least my VM works like a charm.
