(TrueNAS Scale) System won't boot with all drives attached
I have finished the migration from my old TrueNAS Scale drives to my new system almost without any issues.
(See also: Migrating TrueNAS Scale Question)
However, when I first tried to boot the system, it did not work so I unplugged the 3 data drives and then attached them once the system had booted.
Now though, it seems that the system is unable to boot with all drives attached again and it just hangs on the BIOS Splash Screen. Any ideas what might be causing this problem? (At this point, I cannot enter the BIOS. The only way to get into the BIOS is to press the restart button and then then hitting the appropriate key.)
How long did you wait at the splash screen with all drives installed?
Are the three drives you’re removing on the same controller?
I haven’t stopped the time but I would say 5-10mins…
Not sure if they are on the same controller, what I have noticed though is that one drive does not show up in the BIOS.
Also, CSM appears to be enabled and I am wondering if I should turn it off. (Would I have to re-install the OS then?)
I wonder if your system would boot with only the “invisible” drive removed, or with a different drive in that slot.
Do you have that Orico PCIe M.2 to SATA chips? or something like a SATA expansion board? It needs CSM, otherwise turn it off and stay with UEFI
No. I disabled CSM but it did not solve the issue. (I still leave it off of course.)
I did not try a different drive in the slot but when I put one drive in a different slot of the mainboard it was able to boot without any issues. I am curious if this stays so, but only time will tell.
Thanks for your help! :slight_smile:
