Migrating TrueNAS Scale Question
Hey,
so as I was stating in another thread I am about to build a new PC and I would like to migrate my TrueNAS Scale system to this new one. The problem with my NAS currently is that it is still not running and the new CPU did not help (the problem might be somewhere else).
Consequently, I have a NAS which I cannot turn on and with data on disks I would prefer not to lose. I have the following two questions:
  • I assume I can just install TrueNAS scale on the new machine, plug the drives in, import them into the system and I should have access to my data again, correct? Is there anything I should be careful about? Also, I assume I need to adjust access permissions for smb again and I assume this won’t have an impact on usability
  • Speaking of which, is there a way to get the settings as well? I assume there is not, unless I would have exported them before
  • If I was to add a special metadata NVMe drive to the pool, I assume data already on the disk will not be moved? For example, if I was to set it to store files below a certain file size there as well, neither those files nor the metadata will be moved on the existing pool. What will be moved / added is new data.
Thanks for the help!
Most important is to migrate the pool. Don’t overcomplicate it with adding disks for metadata.
Install a new instance, move disks there and import the pool. This works fine with ZFS, Ive done it multiple times.
Once this step is done, you can tune permissions, ACLs and so on. All that stuff is secondary.
Thanks!
Yeah the first step is migrating the pool. Once everything is running, I would like to set something like this up. That being said, I am wondering if a dedicated NVMe pool makes more sense than a special metadata device :thinking:
