…and don’t have a cat.
I have a 22 LB maine coon , 10 months old, named Archer
no issues with him tearing things up, → he loves music, classic cars, motorcycles , daily walks on a leash, and Italian food.
The factory short tiny heatsinks are poor at dispersing heat, just like the gigabit chip heatsink (see above in the thread). So I found a company that made them specifically for this board in a more effective size/ design
I modified / edited / rebuilt the CPU heatsinks
I made from scratch the gigabit chip heatsink
I bought, premade, the mosfet/voltage regulator heatsinks
This just reminded me of the “seeing eye cat” stories on arfcom
That’s what she says …
so I added the upgraded heatsinks, overall result nothing too spectacular, those components are running 7-12C cooler, so I think it was worth the effort:
combined with the edited/improved cpu coolers, the cpu heatsinks have a a full copper plate to completely cover the supersized 9684x’s footprint
The copper plate is 5mm thick
heatpipes and fin adhesion was improved
more fins were added to the full 120mm
combine with 350-3000 rpm phanteks t30
and outcome (quiet silent and cool running, even under load its not obtrusive)
If you ever decide to go with a 140mm tower cooler, the Sanyo Denki 140mm 9RA fans are the best “quiet” fan available on the market that can still scale up to high performance.
Compared to the brand new Noctua NF-A14x25 G2 fans just released, at 1250rpm a 9RA1412P1G001 is quieter, makes 40% more static pressure and 15% less airflow; although behind a heatsink’s finstack the Sanyo is also going to flow more air than the Noctua too.
On top of that the Sanyo scales to 230% of the airflow of the Noctua and over six times more static pressure at a louder volume if needed. The downside is the Sanyo costs about 50% more than a Noctua and is thicker.
Noctua fans overrated, still good but not otherworldly, the real magic is their heatsinks
I don’t mind it THICK, ….my T30’s are THICK
Noctua is definitely overpriced and over rated
I too was a believer for many years, - took guts to venture outside of the zone and look at what was out there….
I’ve even found some Chinese 120mm that are similar blade design as the new noctua and the same sort of material but also ship with the second fan inverted and counter rotating for the same cou cooler set up
Yep, nictua overrated and overpriced
Looks like a nice fan indeed - and it’s not even poo poo brown (a plus)
Sanyo is very common inside servers and switches, for a reason, I assume.
Yes. I don’t think I’ve ever seen the 9RA fans in “normal” computer equipment though, supposedly they are targeted for use in medical equipment that needs to be quiet, which conveniently overlaps with home PC needs.
Yeah I’m using some in one of my home servers.
Unfortunately I didn’t properly check that I’ve ordered the correct product code the last time.
The one in the front ends with product code G0011 (non ribed frame) the one in the back ends with product code G001 (ribed frame). Problem was fixed with oscillating tool ![]()
If you are interested in some discussion of mGPU configuration as it relates to this PC as a test bed, please head over to:
hopefully this will generate some more interest in mGPU apps and gaming
When using thermal pads, I have found that the Gelid Ultimate (15w) have been the most stable and consistent. On some of my builds, 2 year old Gelid Ultimate pads are performing at 100%
I was disappointed in the Thermal Grizzly pads as they became brittle/crumbly in less than 6 months.
These are my go-to thermal pads. I’ll use laird if I need pads under 0.5mm though.
bumping for relevancy
Turns out EPYC 2nd gen and newer are the most efficient virtualization server CPU’s, but cooling several hundred watts can be a chore.
I dont think I missed it anywhere in this thread. but do you have any suggestions for cooling socket SP5? noctua while not mythical has served me well for cooling sp3. but noctua has opted to not provide a cooler for sp5.
thank you kindly.
