Might have to check it out.
Praise be to the fedora magazine though for keeping my linux geeking strong though. Introduced me to exa and glances lol
powerlineā¦ So thatās what that is. I noticed it in terminals on Linux Lite 4.0 (searching for lightweight distros for an old netbook) but didnāt know what was up with the new appearance.
Did you like it?
It was a new eye catching aesthetic, but I didnāt play with it much yet. I had no idea what it was or how it could be used or customized.
In general Iām often torn between having the full path and user name at the prompt for unabiguity versus a more compact prompt for clarity.
Iād probably keep the defaults, but especially on small screens my preference will be whichever is most information dense.
Complete Linux noob here, taken the switch over from Windows a month or so ago.
I am still having trouble learning my way around installing packages.
This is the package that I am trying to install - https://github.com/LN-Zap/zap-desktop#install
I have extracted the file but I can not see a .deb or .AppImage file anywhere; I am clearly missing something obvious
I am using Ubuntu 18.04
Thanks
You are probably downloading the source - you wonāt find a precompiled package from that.
The readme lists this as the download:
I am having a couple problems as a new linux user on a asus laptop with nvidia graphics. I am using debian 9.5.
Hi, Iāve been dual booting Ubuntu and Windows 10 for a few months now. Really I only use the Ubuntu installation, but yesterday needed to boot into Windows, Windows updated, and now I canāt boot into Ubuntu. Anyone know of a fix?
Thinkpad e480
Ubuntu 18.04
Kernel 4.18
Windows 10
Version 1803
Is it booting directly to windows without the option of booting into Ubuntu or does Ubuntu boot part of the way and fail?
If it is the first, then you need to reinstall grub. There are plenty of guides on how to do this, most of them for ubuntu basically this wiki page with pictures- https://help.ubuntu.com/community/RecoveringUbuntuAfterInstallingWindows
If it is the second, then let us know what exact error(s) you are seeing.
It was the first. Thank you!
pfft
use plain vanilla sh
because it is everywhere. you might not find bash or zsh on #ancientUnixVariant
#UnixNeckbeardMasterRace
donāt get me started on PERL. use AWK instead because you might not find perl
edit:
Plus, awk is faster and more efficient (possibly)
I had to fix an AIX serverās fstab before using cat because an admin fucked it up and vi wasnāt available cave man tools ftw
that must have been annoying.
Not so bad, you just write the whole thing locally on your desktop then do the old cat << EOF bit and paste the whole thing into your SSH session. If you have to type it in locally at a terminal, now that would suck.
cat << EOF masterrace.
No remote access. I did it via single user mode on console on physical hardware.
I used to feel that way ā¦ sometimes resorting to ksh-isms. But itās less important now that #properunixen are relatively rare. On the other hand, bash-isms can make shell scripts somewhat less readable (in my opinion) - and shell scripts can get pretty unreadable on their own.
If weāre swapping old war stories, there was this time when I set a root password that couldnāt be typed on the system console - login defaulted to the old standard of ā#ā killing a character and ā@ā killing a line (or perhaps the other way around). Or that time when someone had a vi accident and wiped out half of the main named zone file.
And I have a full feral beard; none of this trendy beard stuff.
Whats the best way to mount a drive. By uuid or /dev/sda ?
And ive seen multiple ways to grab a uuid, they are different numbers. Iām assuming one is the drive and one is the partition?
Trying to find some good documentation on this.
Uuid.
UUID is the one you want. Using /dev/sda is fine if youāre not removing and adding drives routinely. The UUID is persistent while /dev/sd(x) is dependent on which sata port you use. If your not using port 0 for your drive that you list in fstab as /dev/sda and then add another drive in a lower number port, your new drive will become /dev/sda and you will have trouble booting.
