Nice. Seems to have mounted just fine with the uuid that blkid reported. Thanks
One more thing, my workstation supports hot plugging and works fine (formated and imaged the new drive this way). I assumed the server would but I cant find the drives unless I reboot. Its a supermicro board, is this not always supported?
Iām having trouble taking ownership of one of the hard drives in my computer. I saved it from when my computer was set up with windows, it has a two word name Local Disk (which I didnāt think to change while in windows) So trying to use chown to take ownership doesnāt work cause itās taking Local and Disk as two separate arguments, and I canāt rename it for the same reason. any advice on how to get the name changed so i can actually start using my data?
oh, my bad. Iām new to linux. and no it appears to not have worked
edit: nevermind iām dumb and used / instead of āā it worked now.
edit2: it wonāt let me put the slash cause apparently itās used for some formatting on the forums but you get the idea.
I have boost disabled and have all C-States Disabled. However whenever I boot my CPU will sit at 1.3Ghz and I have to run āecho performance | tee /sys/devices/system/cpu/cpu*/cpufreq/scaling_governorā
Any ideas why I need to run this after every reboot?
That is the expected behavior when you have low power mode support enabled in the BIOS. Without running that command the CPU will run at full speed if you run something intensive.
However the performance governor is still preferred for running games, which is why software such as Feralās gamemode exists.
Iām trying to run a GPU miner on my AMD R9 290
It worked fine using Nicehash on Windows.
Iām now using Ubuntu and using the bundled open source driver for gaming and that works fine.
When I attempt to run the miner I get this error
[2018-10-06 23:17:10] Error UNKNOWN_ERROR when calling clGetPlatformIDs for number of platforms.
[2018-10-06 23:17:10] No OpenCL platform found.
[2018-10-06 23:17:10] AMD OpenCL platform NOT found.
[2018-10-06 23:17:10] Failed to start threads."
I am guessing that this is because I am using the OpenSource driver? Is there a way to solve this issue without downloading the driver from AMD?
