I got it to work by installing the nvidia proprietary drivers
now I have different unrelated issue
error: failed to commit transaction (conflicting files)
zita-resampler: /usr/lib/libzita-resampler.so.1 exists in filesystem
Errors occurred, no packages were upgraded.
Hello, I got a new PC on which I can use Windows programms in a VM with Looking-glass and pci-passthough.
Now i wonder how I could use the guest GPU as the main host GPU while the VM is not running.
I loaded the gpu and audio module:
somehow snd_hda_intel does not load, but I guess that is not a problem because I do not plan to use the audio device.
How do I proceed from here? do I need to start a new X-server and plasmashell, or is there a way to migrate the running x-session to the new graphics card?
you can use ksysguard which is a highly customizable system monitor. However it might not work very well with desktop-environments other than KDE/Plasma.
I am aware of ksysguard and it is exactly what I want. But I am on XFCE on the machine I need it for right now. I thought there might be something else but I might end up installing that one. Thanks.
Just upgraded my laptop to 4.15.4 and now my keyboard backlight is borked. There is no delay before dimming, at all. It starts dimming as I type, between key presses. How do I adjust this in Fedora 26?
Edit: It just started working correctly on its own. Dunno.
How do i install two linux distros onto one drive to dual booty? Sure I can install it fine but when it comes to installing the bootloader(GRUB) on the second operating system there is no option to add the entry to grub. In my attempts i fuck up and either overwrite grub on the original operating system installed; or the second os installs but doesnt add the entry to grub
i wanna die
im trying to install parrot and manjaro on my laptop with a fancy ssd.
help me im starving.
does this qualify for the
"The small linux problem thread?"
Conky is a fun thing but I donāt think it can print out a graph over time.
Think something like psensor but for clockspeeds, that is what Iām looking for.
Right so I got Gnome on Wayland and its slowly gotten slower and slower and way more crashier. Its insane. Is there anything I can do or is gnome just grap?
Log in screen freezes for a solid second or two, putting my mouse cursor in the dock lags the whole system. Its nuts.
conky can show you a graph of those, if you have it load a lua script that will draw you the graph. Itās more of an process to setup, but once you at lua scripts to conky, it can do just about anything. the only reason I wouldnāt say do this, is that if your only looking for a it to show you 1 graph, itās might be more effort then is needed. but if you want to know more than that, conky all the way.
This allows you to chart and log any sensors your kernel can access.
That means have it log to a file or show any other sorts of graphs as well as attach other remote machines for monitoring.
In capability and ease of setup and use Conky got nothing on this.
