Why?
its part of FHS which is required for systemd. /bin just symlinks to /usr/bin. which is defaulting to /bin instead of /usr/bin because /bin is searched first from the PATH variable
/bin
and /usr/bin
predate systemd.
FHS you linked shows the purpose of each. The reason yum is in both will be because /bin
will symlink to /usr/bin
. Some distros donāt bother with the separation of defining commands needed for single user mode only and all other commands.
edit: Fedora, CentOS etc. dont bother with this distinction. No idea on other distros.
Totally forgot about that, thanks.
Ubuntu does not symlink /bin
and /sbin
Internet says the file size limit is mainly down to filesystem support. It probably copies in chunks, but it basically has zero documentation unless you read the source yourself.
Iāve copied 500GB files over SCP to ext4. Probably a FS limitation.
Sweet. When I get the chance Iāll try to find the open source GNU scp and decipher this. Iāll post it back here once I figure it out.
Thanks for the 411
For the past couple of days, Iāve been noticing some issues with Fedora 27 staying asleep on my ASUS ZenBook 3 Deluxe UX490UA when Iāve got the lid closed.
I know itās gone into sleep mode, but it seems it doesnāt stay that way or continuously awakens. I find the battery drained down (roughly half way or so) after having it unplugged from a full charge and when placed in the carrying case for several hours.
What can I do to remedy this?
Does your device have orientation sensors? Iāve found that with my laptop (a 2-in-1 Inspiron), significant changes in orientation or rapid movement will awaken the sleeping bear. (Using F27.) If so, try turning rotation lock on and see if it changes anything, it did for me. If not, it may be something else.
Anyone had stability issues with kernel 4.14 and 4.15 (not sure about earlier) with Ryzen 1600? getting lots of random crashing even with C6 disabled.
No, I donāt believe it has orientation sensors. (Iām assuming this is common on the 2-in-1 laptops, which mine isnāt.)
So for the last 3 or so weeks, my realtek 8289 onboard NIC stopped working. The problem started once I added two SSDs to my system. Since then, the NIC is not recognized by Debian SID or by Arch Linux. Weird thing is that when I take the SSDs out, there is no difference in functionality.
I will create another thread if need be to detail what I have done (a lot) but my real question, is, have you ever had hardware like a NIC just cease to function and not come back online under GNU/Linux?
For specifications, I am running a ASUS Sabertooth 990FX r2.0.
Chrome has been giving me sync issues all day in Solus.
Does anyone else have this problem? I can sign in, but I have to do it every time I open Chrome.
I am having a issue where my main antergos wonāt boot to the start screen luckily I am able to go to a fallback to continue temporary use.
checking the journal with this
sudo journalctl -b -1 -r
gives me this.
Feb 21 11:26:20 ThinkParch-E570 mtp-probe[481]: bus: 1, device: 3 was not an MTP device
Feb 21 11:26:20 ThinkParch-E570 mtp-probe[481]: checking bus 1, device 3: "/sys/devices/pci0000:00/0000:00:14.0/usb1/1-7"
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Feb 21 11:26:20 ThinkParch-E570 NetworkManager[397]: <info> [1519233980.3383] manager[0x5624ca480080]: rfkill: WWAN hardware radio set enabled
Feb 21 11:26:20 ThinkParch-E570 NetworkManager[397]: <info> [1519233980.3383] manager[0x5624ca480080]: rfkill: WiFi hardware radio set enabled
Feb 21 11:26:20 ThinkParch-E570 NetworkManager[397]: <info> [1519233980.3381] rfkill1: found WiFi radio killswitch (at /sys/devices/pci0000:00/0000:00:1d.3/0000:05:00.0/ieee80211
Feb 21 11:26:20 ThinkParch-E570 NetworkManager[397]: <info> [1519233980.3375] dns-mgr[0x5624ca49c960]: init: dns=default, rc-manager=symlink
Feb 21 11:26:20 ThinkParch-E570 NetworkManager[397]: <info> [1519233980.3373] hostname: hostname changed from (none) to "ThinkParch-E570"
Feb 21 11:26:20 ThinkParch-E570 NetworkManager[397]: <info> [1519233980.3373] hostname: hostname: using hostnamed
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started Hostname Service.
Feb 21 11:26:20 ThinkParch-E570 dbus-daemon[377]: [system] Successfully activated service 'org.freedesktop.hostname1'
Feb 21 11:26:20 ThinkParch-E570 haveged[374]: haveged: fills: 0, generated: 0
Feb 21 11:26:20 ThinkParch-E570 haveged[374]: haveged: tot tests(BA8): A:1/1 B:1/1 continuous tests(B): last entropy estimate 8.00246
Feb 21 11:26:20 ThinkParch-E570 haveged[374]: haveged: cpu: (L4 VC); data: 32K (L4 V); inst: 32K (L4 V); idx: 22/40; sz: 32398/59688
Feb 21 11:26:20 ThinkParch-E570 haveged[374]: haveged: ver: 1.9.1; arch: x86; vend: GenuineIntel; build: (gcc 7.2.0 ITV); collect: 128K
Feb 21 11:26:20 ThinkParch-E570 systemd-udevd[224]: worker [231] failed while handling '/devices/pci0000:00/0000:00:1c.0/0000:01:00.0'
Feb 21 11:26:20 ThinkParch-E570 systemd-udevd[224]: worker [231] terminated by signal 11 (SEGV)
Feb 21 11:26:20 ThinkParch-E570 kernel: RIP: nvGetClocks+0x74/0x260 [nvidiafb] RSP: ffffb418c1e53798
Feb 21 11:26:20 ThinkParch-E570 kernel: Code: 00 41 81 e2 f0 fe 00 00 41 81 fa 90 02 00 00 74 11 41 89 db c1 eb 10 0f b6 db 41 c1 eb 18 44 0f af cb 0f af c2 31 d2 41 0f af c3 <41>
Feb 21 11:26:20 ThinkParch-E570 kernel: R13: 000055b1ad926b60 R14: 0000000000020000 R15: 00007ffd74431290
Feb 21 11:26:20 ThinkParch-E570 kernel: R10: 0000000000000005 R11: 0000000000000246 R12: 000055b1ae16c440
Feb 21 11:26:20 ThinkParch-E570 kernel: RBP: 00007f2e77eb6cb5 R08: 0000000000000006 R09: 00007ffd7442f880
Feb 21 11:26:20 ThinkParch-E570 kernel: RDX: 00007f2e77eb6cb5 RSI: 0000000000015250 RDI: 000055b1ae16c440
Feb 21 11:26:20 ThinkParch-E570 kernel: RAX: ffffffffffffffda RBX: 000055b1ad918090 RCX: 00007f2e785fe6ca
Feb 21 11:26:20 ThinkParch-E570 kernel: RSP: 002b:00007ffd74430798 EFLAGS: 00000246 ORIG_RAX: 00000000000000af
Feb 21 11:26:20 ThinkParch-E570 kernel: RIP: 0033:0x7f2e785fe6ca
Feb 21 11:26:20 ThinkParch-E570 kernel: entry_SYSCALL_64_after_hwframe+0x21/0x86
Feb 21 11:26:20 ThinkParch-E570 kernel: do_syscall_64+0x75/0x190
Feb 21 11:26:20 ThinkParch-E570 kernel: SyS_init_module+0x163/0x1a0
Feb 21 11:26:20 ThinkParch-E570 kernel: ? SyS_init_module+0x163/0x1a0
Feb 21 11:26:20 ThinkParch-E570 kernel: ? vmap_page_range_noflush+0x27b/0x380
Feb 21 11:26:20 ThinkParch-E570 kernel: ? alloc_vmap_area+0x61/0x360
Feb 21 11:26:20 ThinkParch-E570 kernel: load_module+0x26ad/0x2b30
Feb 21 11:26:20 ThinkParch-E570 kernel: do_init_module+0x5b/0x205
Feb 21 11:26:20 ThinkParch-E570 kernel: ? kmem_cache_alloc_trace+0xa1/0x1c0
Feb 21 11:26:20 ThinkParch-E570 kernel: ? free_unref_page_commit+0x66/0xf0
Feb 21 11:26:20 ThinkParch-E570 kernel: do_one_initcall+0x4e/0x190
Feb 21 11:26:20 ThinkParch-E570 kernel: ? nvidiafb_resume+0x90/0x90 [nvidiafb]
Feb 21 11:26:20 ThinkParch-E570 kernel: driver_register+0x57/0xc0
Feb 21 11:26:20 ThinkParch-E570 kernel: bus_add_driver+0x1c2/0x260
Feb 21 11:26:20 ThinkParch-E570 kernel: bus_for_each_dev+0x6b/0xb0
Feb 21 11:26:20 ThinkParch-E570 kernel: ? driver_probe_device+0x480/0x480
Feb 21 11:26:20 ThinkParch-E570 kernel: __driver_attach+0xa0/0xe0
Feb 21 11:26:20 ThinkParch-E570 kernel: driver_probe_device+0x315/0x480
Feb 21 11:26:20 ThinkParch-E570 kernel: pci_device_probe+0x146/0x1b0
Feb 21 11:26:20 ThinkParch-E570 kernel: ? pci_match_device+0xd9/0x100
Feb 21 11:26:20 ThinkParch-E570 kernel: local_pci_probe+0x42/0xa0
Feb 21 11:26:20 ThinkParch-E570 kernel: nvidiafb_probe+0x612/0x9e0 [nvidiafb]
Feb 21 11:26:20 ThinkParch-E570 kernel: register_framebuffer+0x248/0x350
Feb 21 11:26:20 ThinkParch-E570 kernel: ? down+0x12/0x50
Feb 21 11:26:20 ThinkParch-E570 kernel: blocking_notifier_call_chain+0x3e/0x60
Feb 21 11:26:20 ThinkParch-E570 kernel: notifier_call_chain+0x47/0x70
Feb 21 11:26:20 ThinkParch-E570 kernel: do_fbcon_takeover+0x58/0xb0
Feb 21 11:26:20 ThinkParch-E570 kernel: do_take_over_console+0x7b/0x190
Feb 21 11:26:20 ThinkParch-E570 kernel: do_bind_con_driver+0x1f4/0x400
Feb 21 11:26:20 ThinkParch-E570 kernel: visual_init+0xd5/0x130
Feb 21 11:26:20 ThinkParch-E570 kernel: fbcon_init+0x482/0x660
Feb 21 11:26:20 ThinkParch-E570 kernel: nvidiafb_set_par+0x471/0xa00 [nvidiafb]
Feb 21 11:26:20 ThinkParch-E570 kernel: ? kobject_uevent_env+0x117/0x620
Feb 21 11:26:20 ThinkParch-E570 kernel: ? kobj_ns_drop+0x60/0x60
Feb 21 11:26:20 ThinkParch-E570 kernel: NVCalcStateExt+0x636/0x8d0 [nvidiafb]
Feb 21 11:26:20 ThinkParch-E570 kernel: Call Trace:
Feb 21 11:26:20 ThinkParch-E570 kernel: CR2: 00007f7df84256f0 CR3: 000000046993a004 CR4: 00000000003606e0
Feb 21 11:26:20 ThinkParch-E570 kernel: CS: 0010 DS: 0000 ES: 0000 CR0: 0000000080050033
Feb 21 11:26:20 ThinkParch-E570 kernel: FS: 00007f2e78cb78c0(0000) GS:ffffa318ff500000(0000) knlGS:0000000000000000
Feb 21 11:26:20 ThinkParch-E570 kernel: R13: 0000000000000010 R14: 0000000000050000 R15: 0000000000000008
Feb 21 11:26:20 ThinkParch-E570 kernel: R10: 0000000000001290 R11: 00000000000000ba R12: 0000000000006247
Feb 21 11:26:20 ThinkParch-E570 kernel: RBP: ffffa318ea79e510 R08: ffffb418c1e537ec R09: 0000000000000000
Feb 21 11:26:20 ThinkParch-E570 kernel: RDX: 0000000000000000 RSI: ffffb418c1e537d8 RDI: ffffa318ea79e418
Feb 21 11:26:20 ThinkParch-E570 kernel: RAX: 000000000516b430 RBX: 00000000000000df RCX: 0000000000000007
Feb 21 11:26:20 ThinkParch-E570 kernel: RSP: 0018:ffffb418c1e53798 EFLAGS: 00010206
Feb 21 11:26:20 ThinkParch-E570 kernel: RIP: 0010:nvGetClocks+0x74/0x260 [nvidiafb]
Feb 21 11:26:20 ThinkParch-E570 kernel: Hardware name: LENOVO 20H5CTO1WW/20H5CTO1WW, BIOS R0DET33W (1.09 ) 10/13/2016
Feb 21 11:26:20 ThinkParch-E570 kernel: CPU: 2 PID: 231 Comm: systemd-udevd Not tainted 4.15.3-2-ARCH #1
Feb 21 11:26:20 ThinkParch-E570 kernel: shpchp intel_pch_thermal tpm_tis soundcore evdev wmi tpm_tis_core battery mac_hid ac tpm rtc_cmos sg crypto_user ip_tables x_tables ext4 c
Feb 21 11:26:20 ThinkParch-E570 kernel: Modules linked in: arc4 intel_rapl x86_pkg_temp_thermal intel_powerclamp coretemp kvm_intel kvm snd_soc_skl iTCO_wdt iTCO_vendor_support sn
Feb 21 11:26:20 ThinkParch-E570 kernel: divide error: 0000 [#1] PREEMPT SMP PTI
Feb 21 11:26:20 ThinkParch-E570 kernel: nvidiafb: Using CRT on CRTC 0
Feb 21 11:26:20 ThinkParch-E570 kernel: ...Defaulting to CRTCNumber 0
Feb 21 11:26:20 ThinkParch-E570 kernel: nvidiafb: Unable to detect which CRTCNumber...
Feb 21 11:26:20 ThinkParch-E570 kernel: ...Using default of CRT
Feb 21 11:26:20 ThinkParch-E570 kernel: nvidiafb: Unable to detect display type...
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started Modem Manager.
Feb 21 11:26:20 ThinkParch-E570 polkitd[403]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started Authorization Manager.
Feb 21 11:26:20 ThinkParch-E570 dbus-daemon[377]: [system] Successfully activated service 'org.freedesktop.PolicyKit1'
Feb 21 11:26:20 ThinkParch-E570 polkitd[403]: Finished loading, compiling and executing 5 rules
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Starting Hostname Service...
Feb 21 11:26:20 ThinkParch-E570 dbus-daemon[377]: [system] Activating via systemd: service name='org.freedesktop.hostname1' unit='dbus-org.freedesktop.hostname1.service' requested
Feb 21 11:26:20 ThinkParch-E570 NetworkManager[397]: <info> [1519233980.2840] manager[0x5624ca480080]: monitoring kernel firmware directory '/usr/lib/firmware'.
Feb 21 11:26:20 ThinkParch-E570 polkitd[403]: Loading rules from directory /usr/share/polkit-1/rules.d
Feb 21 11:26:20 ThinkParch-E570 polkitd[403]: Loading rules from directory /etc/polkit-1/rules.d
Feb 21 11:26:20 ThinkParch-E570 NetworkManager[397]: <info> [1519233980.2755] Read config: /etc/NetworkManager/NetworkManager.conf (lib: 20-connectivity.conf)
Feb 21 11:26:20 ThinkParch-E570 NetworkManager[397]: <info> [1519233980.2754] NetworkManager (version 1.10.5dev+3+g5159c34ea-1, Arch Linux) is starting... (for the first time)
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Starting Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Created slice system-systemd\x2dbacklight.slice.
Feb 21 11:26:20 ThinkParch-E570 kernel: snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
Feb 21 11:26:20 ThinkParch-E570 polkitd[403]: Started polkitd version 0.114
Feb 21 11:26:20 ThinkParch-E570 systemd-udevd[240]: Process '/usr/bin/tlp auto' failed with exit code 4.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Starting Authorization Manager...
Feb 21 11:26:20 ThinkParch-E570 dbus-daemon[377]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service' requested by ':1.3' (uid=0 pid=3
Feb 21 11:26:20 ThinkParch-E570 avahi-daemon[376]: Server startup complete. Host name is ThinkParch-E570.local. Local service cookie is 2771671212.
Feb 21 11:26:20 ThinkParch-E570 avahi-daemon[376]: Network interface enumeration completed.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started Login Service.
Feb 21 11:26:20 ThinkParch-E570 avahi-daemon[376]: No service file found in /etc/avahi/services.
Feb 21 11:26:20 ThinkParch-E570 avahi-daemon[376]: Successfully dropped remaining capabilities.
Feb 21 11:26:20 ThinkParch-E570 avahi-daemon[376]: Successfully called chroot().
Feb 21 11:26:20 ThinkParch-E570 systemd-logind[373]: Watching system buttons on /dev/input/event5 (ThinkPad Extra Buttons)
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started Avahi mDNS/DNS-SD Stack.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Starting Network Manager...
Feb 21 11:26:20 ThinkParch-E570 kernel: iwlwifi 0000:05:00.0 wlp5s0: renamed from wlan0
Feb 21 11:26:20 ThinkParch-E570 systemd-udevd[234]: link_config: autonegotiation is unset or enabled, the speed and duplex are not writable.
Feb 21 11:26:20 ThinkParch-E570 kernel: thermal thermal_zone3: failed to read out thermal zone (-61)
Feb 21 11:26:20 ThinkParch-E570 kernel: (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
Feb 21 11:26:20 ThinkParch-E570 kernel: ieee80211 phy0: Selected rate control algorithm 'iwl-mvm-rs'
Feb 21 11:26:20 ThinkParch-E570 systemd-logind[373]: New seat seat0.
Feb 21 11:26:20 ThinkParch-E570 systemd-logind[373]: Watching system buttons on /dev/input/event3 (AT Translated Set 2 keyboard)
Feb 21 11:26:20 ThinkParch-E570 systemd-logind[373]: Watching system buttons on /dev/input/event1 (Sleep Button)
Feb 21 11:26:20 ThinkParch-E570 systemd-logind[373]: Watching system buttons on /dev/input/event0 (Lid Switch)
Feb 21 11:26:20 ThinkParch-E570 ModemManager[375]: <info> ModemManager (version 1.7.990) starting in system bus...
Feb 21 11:26:20 ThinkParch-E570 kernel: intel_rapl: Found RAPL domain dram
Feb 21 11:26:20 ThinkParch-E570 kernel: intel_rapl: Found RAPL domain uncore
Feb 21 11:26:20 ThinkParch-E570 kernel: intel_rapl: Found RAPL domain core
Feb 21 11:26:20 ThinkParch-E570 kernel: intel_rapl: Found RAPL domain package
Feb 21 11:26:20 ThinkParch-E570 avahi-daemon[376]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Feb 21 11:26:20 ThinkParch-E570 avahi-daemon[376]: avahi-daemon 0.7 starting up.
Feb 21 11:26:20 ThinkParch-E570 avahi-daemon[376]: Successfully dropped root privileges.
Feb 21 11:26:20 ThinkParch-E570 avahi-daemon[376]: Found user 'avahi' (UID 84) and group 'avahi' (GID 84).
Feb 21 11:26:20 ThinkParch-E570 systemd-logind[373]: Watching system buttons on /dev/input/event2 (Power Button)
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started D-Bus System Message Bus.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Starting Avahi mDNS/DNS-SD Stack...
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Starting Modem Manager...
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started Entropy Harvesting Daemon.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Starting Login Service...
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Reached target Basic System.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Reached target Sockets.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Listening on CUPS Scheduler.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Reached target Timers.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started Daily locate database update.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Reached target Paths.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started CUPS Scheduler.
Feb 21 11:26:20 ThinkParch-E570 systemd[1]: Started Daily rotation of log files.
this reoccurring issue is showing up every time I look at the long
I am really paranoid about updating the system because an update might mess up the fallback I am currently using
I remember seeing someone mention something about nvidia screwing with drivers, but I donāt remember setting nvidia as my main display
Does the issue go away when you add nomodeset
to the kernel arguments?
how do I change that?
should be able to press e at the grub menu and add nomodeset
to the end of the line that begins with linux or linuxefi
Im stuck, I can boot into the fallback and LTS fallback, but im not sure what I should do, I was thinking of removing novearu, but I am afraid of breaking it further
as mentioned here
https://bbs.archlinux.org/viewtopic.php?id=234646
You canāt remove nouveau (itās built into the kernel). You can, however, blacklist nouveau in /etc/modprobe.d
If you havenāt already looked at this page, it may be of help to you:
Having a minor issue with my Ubuntu system.
Only works if I start in recovery mode, drop to a terminal and execute mount /dev/sdb2 / -oremount,rw
then continue booting.
Iām fairly certain this is the culprit:
ā systemd-remount-fs.service - Remount Root and Kernel File Systems
Loaded: loaded (/lib/systemd/system/systemd-remount-fs.service; static; vendor preset: enabled)
Active: failed (Result: exit-code) since Thu 2018-02-22 16:10:24 PST; 1min 36s ago
Docs: man:systemd-remount-fs.service(8)
https://www.freedesktop.org/wiki/Software/systemd/APIFileSystems
Process: 2941 ExecStart=/lib/systemd/systemd-remount-fs (code=exited, status=1/FAILURE)
Main PID: 2941 (code=exited, status=1/FAILURE)
CPU: 24ms
Feb 22 16:10:24 metropolis systemd[1]: Starting Remount Root and Kernel File Systems...
Feb 22 16:10:24 metropolis systemd-remount-fs[2941]: mount: /: mount point not mounted or bad option.
Feb 22 16:10:24 metropolis systemd-remount-fs[2941]: /bin/mount for / exited with exit status 32.
Feb 22 16:10:24 metropolis systemd[1]: systemd-remount-fs.service: Main process exited, code=exited, status=1/FAILURE
Feb 22 16:10:24 metropolis systemd[1]: Failed to start Remount Root and Kernel File Systems.
Feb 22 16:10:24 metropolis systemd[1]: systemd-remount-fs.service: Unit entered failed state.
Feb 22 16:10:24 metropolis systemd[1]: systemd-remount-fs.service: Failed with result 'exit-code'.
Using BTRFS root.
Update: Fixed it.
I had converted my ext4 partition to btrfs, and left in the errors=remount-ro
flag in /etc/fstab
. Works just fine now.
