The small linux problem thread
Bit of an FYI
Debian 9.1 GNOME Desktop
Gnome login screen is horribly laggy and the mouse cursor is invisible. This is caused by the login using wayland by default on hardware that doesn’t support some newer features.
In:
/etc/gdm3/daemon.conf
Uncomment:
WaylandEnable=false
This forces the login to use xorg by default which works for me.
Strange issue that doesnt break the userspace but:
After waking from sleep on 3 different machines running Ubuntu GNOME in 16.04, 16.10 and 17.04 the lockscreen is a gay pride banner with crazy artifacting. Everything works as it should and once you slide it away things are normal.
Alright, I’ve bit the bullet and installed F26 on my main system. It’s nice, but it feels like there are a lot of things that “just work™” on other distros that F26 doesn’t quite have.
First issue is discord. I’m not sure if there are binaries for it somewhere. Lots of resources are referencing vishalv/discord-canary, but that appears to be dead. Any suggestions or am I building from source?
Also, I’m having a bit of an issue with Firefox and media streaming. Plex is giving me stream errors. I think it’s a codec issue, but I’m not sure where to grab them. Chromium isn’t suffering this issue after installing the codec libraries. Any advice here?
Got to say though, VM manager is waaay too easy to work with in fedora. I didn’t even have to assign vfio-pci to my GPU’s, just load the module, enable IOMMU and throw the device into the VM config. What a world we live in!
Discord has a stable native linux client now. The discord-canary was a reference to the beta program they had for linux while it was still in development. You should be able to download it straight from the official repos.
If not on their main page they literally have it in front of your face.
They have a precompiled tarball and a .deb to use.
I was looking for a repo package, but this works for the time being. Thanks!
no problem :slight_smile:
Ity bity little problem. ZFS pool mounts and stores files properly, however it does not show up as a mounted volume in debian. I think this will cause issues in the future when trying to setup smb.
Maybe setting up legacy mounting will solve this?
What isn’t showing it as a volume?
show me the output of mount, df, and zfs list
I can’t really say if legacy mounting will solve your problem until I get a bit more info.
  • I haven’t really been able to find a consistent answer/solution to my problem via official channels, so I thought I’d ask around.
So, recently I’ve taken to installing Solus MATE on my laptop ( Dell Inspiron 15 7579 ), and I have issues with screen brightness and keyboard backlight. When I boot up or log in, my keyboard backlight will automatically turn on to high. The other issue is that the screen brightness is on high, like, ALWAYS. Though I can adjust keyboard backlight (despite it turning right the fuck back on when I log in again), I can not adjust the screen brightness via the brightness keys on the keyboard or within the GUI. This is an issue that not only occurs in Solus MATE, but also in Ubuntu MATE, Fedora MATE, Linux Mint MATE, and Manjaro MATE, which suggests that this issue is likely more tied into an issue with MATE, especially since this is not a problem with GNOME, Cinnamon, Xfce, KDE, Deepin, or Budgie desktop environments.
PLEASE DON’T SUGGEST XBACKLIGHT - IT’S NOT A SOLUTION, IT’S A HACK. THANK YOU. :wink:
Try installing and using xfce-power-manager instead
If it appears in ubuntu mate you may have luck emailing Martin wimpress ( mate Dev) he has a couple of Dell laptops so would be the best person to ask. As you say it seems to be a mate issue so I doubt anyone on here will be able to find a fix for you.
I have the problem with Solus Budgie on my XPS 13, but only with the screen backlight, the keyboard backlight stays off by default. (I think this laptop has the keyboard backlight handled by hardware)
I think it’s a problem with the desktop manager. Solus uses LightDM, which is probably issue #1. Unfortunately I don’t really have a resolution for this, but if there’s not already a bug report, maybe we should open one with either Ubuntu MATE or upstream MATE. That would probably be the best place to get the issue fixed.
Much thanks @SgtAwesomesauce @Baz @blackfire for the suggestions!
I am getting this issue when I shut down my laptop
[2224.624867] wlp5s0:failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-22)
[2226.643460] cgroup: cgroup2:unknown option ""
[2227.408033] Power down
the laptop begins its shutdown phase and then get’s stuck at the third line, at which point the fans ramp up to 100 and the only way to shut it down is to hold the power button. The laptop also has a issue with suspending where it will shut down instead of suspending to ram.
Aside from that, I am also having issues where the bluetooth automatically turns on every time I start up the laptop is there a command I can do to shutdown location and bluetooth?
Distro? Hardware? Any proprietary drivers?
Shutdown:
Check /var/log/messages for the latest shutdown logs & post them here.
Bluetooth:
You should have a .conf file in /etc/bluetooth/
edit or add the line
reboot to test
Try disabling or uninstalling the WiFi driver temporarily as a test.
Not sure what the cgroup issue is about, they shouldn’t have anything to do with sleep, they’re just another process to the kernel.
Are you by any chance running Arch?
Arch(Antergos), Lenovo Thinkpad E570
Getting the logs
@KoalaAteMySnack
It could be arch, but I am not getting the same error on my desktop
sudo journalctl -b -1 -r
from this Reboot/Shut down log / Newbie Corner / Arch Linux Forums
used this code to view logs two minute log
Oct 05 10:44:36 ThinkParch-E570 systemd-journald[170]: Journal stopped
Oct 05 10:44:36 ThinkParch-E570 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Oct 05 10:44:36 ThinkParch-E570 kernel: systemd-shutdow: 38 output lines suppressed due to ratelimiting
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Shutting down.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Starting Power-Off...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Reached target Final Step.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Reached target Shutdown.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Remount Root and Kernel File Systems.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Create Static Device Nodes in /dev.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Local File Systems (Pre).
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Reached target Unmount All Filesystems.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounted /boot.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-uuid/a7d3b2b5-6636-4514-bf68-8d55ef8dc8ad.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Deactivated swap /dev/sda4.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-id/ata-KINGSTON_SV300S37A120G_50026B736500A35C-part4.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-id/wwn-0x50026b736500a35c-part4.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-label/AntergosSwap.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-partlabel/ANTERGOS_SWAP.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-partuuid/346f8e16-f10f-4483-b0f5-0bf77f7535dd.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:00:17.0-ata-1-part4.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Deactivating swap /dev/disk/by-partuuid/346f8e16-f10f-4483-b0f5-0bf77f7535dd...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Swap.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounted Temporary Directory (/tmp).
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounting /boot...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounted /boot/efi.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounted /run/user/1000.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounted /run/user/120.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounting /run/user/120...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounting /run/user/1000...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounting Temporary Directory (/tmp)...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Unmounting /boot/efi...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Local File Systems.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Create Volatile Files and Directories.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Removed slice system-systemd\x2dbacklight.slice.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Load/Save Random Seed.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Encrypted Volumes.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Set Up Additional Binary Formats.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Load Kernel Modules.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Apply Kernel Variables.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopping Load/Save Random Seed...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target System Initialization.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Closed D-Bus System Message Bus Socket.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped CUPS Scheduler.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Paths.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Removed slice User and Session Slice.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Slices.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Closed CUPS Scheduler.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Sockets.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Basic System.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped D-Bus System Message Bus.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopping D-Bus System Message Bus...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Network Manager.
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.4071] exiting (success)
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <warn>  [1507218276.4071] dns-mgr: could not commit DNS changes on shutdown: /usr/bin/resolvconf returned error code
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: No resolv.conf for interface NetworkManager
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.3804] dns-mgr: Removing DNS information from /usr/bin/resolvconf
Oct 05 10:44:36 ThinkParch-E570 dbus[279]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.nm-dispatcher.service': Refusing activation, D-Bus is shutting down.
Oct 05 10:44:36 ThinkParch-E570 dbus[279]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.3493] manager: NetworkManager state is now DISCONNECTED
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped WPA supplicant.
Oct 05 10:44:36 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-TERMINATING
Oct 05 10:44:36 ThinkParch-E570 wpa_supplicant[483]: nl80211: deinit ifname=wlp5s0 disabled_11b_rates=0
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.2547] dns-mgr: Removing DNS information from /usr/bin/resolvconf
Oct 05 10:44:36 ThinkParch-E570 kernel: wlp5s0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-22)
Oct 05 10:44:36 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-DISCONNECTED bssid=84:d4:7e:2d:2d:41 reason=3 locally_generated=1
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target User and Group Name Lookups.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Login Service.
Oct 05 10:44:36 ThinkParch-E570 kernel: wlp5s0: deauthenticating from 84:d4:7e:2d:2d:41 by local choice (Reason: 3=DEAUTH_LEAVING)
Oct 05 10:44:36 ThinkParch-E570 wpa_supplicant[483]: p2p-dev-wlp5s0: CTRL-EVENT-TERMINATING
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.1919] dhcp4 (wlp5s0): state changed bound -> done
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.1919] dhcp4 (wlp5s0): canceled DHCP transaction
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.1917] device (wlp5s0): state change: deactivating -> unmanaged (reason 'removed', internal state 'managed')
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.1589] manager: NetworkManager state is now DISCONNECTING
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.1588] device (wlp5s0): state change: activated -> deactivating (reason 'unmanaged', internal state 'managed')
Oct 05 10:44:36 ThinkParch-E570 NetworkManager[282]: <info>  [1507218276.1577] caught SIGTERM, shutting down normally.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopping Network Manager...
Oct 05 10:44:36 ThinkParch-E570 wpa_supplicant[483]: nl80211: deinit ifname=p2p-dev-wlp5s0 disabled_11b_rates=0
Oct 05 10:44:36 ThinkParch-E570 wpa_supplicant[483]: nl80211: Failed to set IPv4 unicast in multicast filter
Oct 05 10:44:36 ThinkParch-E570 wpa_supplicant[483]: nl80211: Failed to open /proc/sys/net/ipv4/conf/p2p-dev-wlp5s0/drop_unicast_in_l2_multicast: No such file or directory
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopping WPA supplicant...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Network.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped clamav daemon.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped target Remote File Systems.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopped Permit User Sessions.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopping Permit User Sessions...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Stopping Login Service...
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Removed slice User Slice of gdm.
Oct 05 10:44:36 ThinkParch-E570 systemd[1]: Removed slice User Slice of edd.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Started Generate shutdown-ramfs.
Oct 05 10:44:35 ThinkParch-E570 mkinitcpio[7163]: ==> Build complete.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Session c1 of user gdm.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped User Manager for UID 1000.
Oct 05 10:44:35 ThinkParch-E570 systemd[767]: pam_unix(systemd-user:session): session closed for user edd
Oct 05 10:44:35 ThinkParch-E570 mkinitcpio[7163]:   -> Running build hook: [sd-shutdown]
Oct 05 10:44:35 ThinkParch-E570 mkinitcpio[7163]: ==> Starting build: none
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Received SIGRTMIN+24 from PID 7175 (kill).
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Starting Exit the Session...
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Reached target Shutdown.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Closed D-Bus User Message Bus Socket.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Closed Sound System.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Closed GnuPG cryptographic agent and passphrase cache.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Closed GnuPG network certificate management daemon.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped target Sockets.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped target Paths.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped target Timers.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped target Basic System.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped D-Bus User Message Bus.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Session c2 of user edd.
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) Server terminated successfully (0). Closing log file.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Manage, Install and Generate Color Profiles.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped User Manager for UID 120.
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:67
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) UnloadModule: "libinput"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:69
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:70
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:65
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:66
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:72
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:75
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:76
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:77
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:78
Oct 05 10:44:35 ThinkParch-E570 systemd[492]: pam_unix(systemd-user:session): session closed for user gdm
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:79
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:80
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:81
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:64
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:73
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:82
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped GNOME Display Manager.
Oct 05 10:44:35 ThinkParch-E570 gdm[382]: GLib: g_hash_table_find: assertion 'version == hash_table->version' failed
Oct 05 10:44:35 ThinkParch-E570 gdm[382]: Unable to kill session worker process
Oct 05 10:44:35 ThinkParch-E570 gdm[382]: Child process 439 was already dead.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Bluetooth service.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Virtual filesystem service.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Daemon for power management.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Received SIGRTMIN+24 from PID 7164 (kill).
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) systemd-logind: releasing fd for 13:71
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event7  - (II) ThinkPad Extra Buttons: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "40"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event18 - (II) TPPS/2 IBM TrackPoint: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "39"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event9  - (II) SynPS/2 Synaptics TouchPad: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "38"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event0  - (II) AT Translated Set 2 keyboard: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "37"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event17 - (II) HDA Intel PCH HDMI/DP,pcm=10: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "36"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event16 - (II) HDA Intel PCH HDMI/DP,pcm=9: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "35"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event15 - (II) HDA Intel PCH HDMI/DP,pcm=8: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "34"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event14 - (II) HDA Intel PCH HDMI/DP,pcm=7: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "33"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event13 - (II) HDA Intel PCH HDMI/DP,pcm=3: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "32"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event12 - (II) HDA Intel PCH Headphone: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "31"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event11 - (II) HDA Intel PCH Mic: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "30"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event8  - (II) Integrated Camera: Integrated C: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "29"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event2  - (II) Sleep Button: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "28"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event1  - (II) Lid Switch: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "27"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event6  - (II) Video Bus: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "26"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event5  - (II) Video Bus: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "25"
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (II) event3  - (II) Power Button: (II) device removed
Oct 05 10:44:35 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[779]: (**) Option "fd" "22"
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Accessibility services bus.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Modem Manager.
Oct 05 10:44:35 ThinkParch-E570 NetworkManager[282]: <warn>  [1507218275.4429] error requesting auth for org.freedesktop.NetworkManager.wifi.share.open: Authorization check failed: Refusing activation, D-Bus is
Oct 05 10:44:35 ThinkParch-E570 NetworkManager[282]: <warn>  [1507218275.4429] error requesting auth for org.freedesktop.NetworkManager.wifi.share.protected: Authorization check failed: Refusing activation, D-Bu
Oct 05 10:44:35 ThinkParch-E570 dbus[279]: [system] Activation via systemd failed for unit 'polkit.service': Refusing activation, D-Bus is shutting down.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped clamav updater.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Entropy Harvesting Daemon.
Oct 05 10:44:35 ThinkParch-E570 dbus[279]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Oct 05 10:44:35 ThinkParch-E570 ModemManager[283]: <info>  ModemManager is shut down
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped CUPS Scheduler.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Disk Manager.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Location Lookup Service.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Accounts Service.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Authorization Manager.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Unmounted /run/user/1000/gvfs.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Entropy Harvesting Daemon...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Removed slice system-getty.slice.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Session c1 of user gdm.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping clamav updater...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Starting Generate shutdown-ramfs...
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Evolution address book service.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Starting Exit the Session...
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Bluetooth OBEX service.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Evolution calendar service.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Reached target Shutdown.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Closed Sound System.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Closed D-Bus User Message Bus Socket.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Evolution source registry.
Oct 05 10:44:35 ThinkParch-E570 haveged[274]: haveged starting up
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Oct 05 10:44:35 ThinkParch-E570 haveged[274]: haveged: Stopping due to signal 15
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Closed GnuPG network certificate management daemon.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Closed GnuPG cryptographic agent and passphrase cache.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopped target Sockets.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopped target Paths.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Sound Service.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopped target Timers.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopped target Basic System.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopped Accessibility services bus.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopped Sound Service.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Virtual filesystem service - disk device monitor.
Oct 05 10:44:35 ThinkParch-E570 NetworkManager[282]: <info>  [1507218275.4133] ModemManager disappeared from bus
Oct 05 10:44:35 ThinkParch-E570 udisksd[906]: udisks daemon version 2.7.3 exiting
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Daily man-db cache update.
Oct 05 10:44:35 ThinkParch-E570 bluetoothd[480]: Exit
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Monthly clean packages cache.
Oct 05 10:44:35 ThinkParch-E570 bluetoothd[480]: Stopping SDP server
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Modem Manager...
Oct 05 10:44:35 ThinkParch-E570 ModemManager[283]: <info>  Caught signal, shutting down...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping clamav daemon...
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopped D-Bus User Message Bus.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Tracker metadata database store and lookup manager.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped Virtual filesystem metadata service.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping D-Bus User Message Bus...
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Evolution calendar service...
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Virtual filesystem service...
Oct 05 10:44:35 ThinkParch-E570 avahi-daemon[278]: avahi-daemon 0.7 exiting.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Bluetooth OBEX service...
Oct 05 10:44:35 ThinkParch-E570 obexd[1126]: Terminating
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Accessibility services bus...
Oct 05 10:44:35 ThinkParch-E570 bluetoothd[480]: Endpoint unregistered: sender=:1.66 path=/MediaEndpoint/A2DPSink
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Evolution source registry...
Oct 05 10:44:35 ThinkParch-E570 bluetoothd[480]: Endpoint unregistered: sender=:1.66 path=/MediaEndpoint/A2DPSource
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopped target Default.
Oct 05 10:44:35 ThinkParch-E570 bluetoothd[480]: Endpoint unregistered: sender=:1.42 path=/MediaEndpoint/A2DPSink
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Virtual filesystem service - disk device monitor...
Oct 05 10:44:35 ThinkParch-E570 bluetoothd[480]: Endpoint unregistered: sender=:1.42 path=/MediaEndpoint/A2DPSource
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Evolution address book service...
Oct 05 10:44:35 ThinkParch-E570 gnome-session-binary[506]: WARNING: Lost name on bus: org.gnome.SessionManager
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Sound Service...
Oct 05 10:44:35 ThinkParch-E570 avahi-daemon[278]: Leaving mDNS multicast group on interface wlp5s0.IPv4 with address 10.194.124.229.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Oct 05 10:44:35 ThinkParch-E570 avahi-daemon[278]: Leaving mDNS multicast group on interface wlp5s0.IPv6 with address fe80::bb6:44ec:be5b:7ef7.
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Tracker metadata database store and lookup manager...
Oct 05 10:44:35 ThinkParch-E570 avahi-daemon[278]: Got SIGTERM, quitting.
Oct 05 10:44:35 ThinkParch-E570 gnome-session[506]: gnome-session-binary[506]: WARNING: Lost name on bus: org.gnome.SessionManager
Oct 05 10:44:35 ThinkParch-E570 tracker-store[1043]: OK
Oct 05 10:44:35 ThinkParch-E570 tracker-store[1043]: Received signal:15->'Terminated'
Oct 05 10:44:35 ThinkParch-E570 systemd[766]: Stopping Virtual filesystem metadata service...
Oct 05 10:44:35 ThinkParch-E570 bluetoothd[480]: Terminating
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopping Accessibility services bus...
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopped target Default.
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopping Sound Service...
Oct 05 10:44:35 ThinkParch-E570 systemd[491]: Stopping D-Bus User Message Bus...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped target Login Prompts.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped target Multi-User System.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping GNOME Display Manager...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped target Graphical Interface.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Daily rotation of log files.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped Daily verification of password and group files.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped target Timers.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped target Sound Card.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping CUPS Scheduler...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping User Manager for UID 120...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Location Lookup Service...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Daemon for power management...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Session c2 of user edd.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Manage, Install and Generate Color Profiles...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping User Manager for UID 1000...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Bluetooth service...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopped target Bluetooth.
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Authorization Manager...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Disk Manager...
Oct 05 10:44:35 ThinkParch-E570 systemd[1]: Stopping Accounts Service...
Oct 05 10:44:35 ThinkParch-E570 gnome-session-binary[789]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 10:44:35 ThinkParch-E570 gnome-session[789]: gnome-session-binary[789]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 10:44:35 ThinkParch-E570 systemd-logind[277]: System is powering down.
Oct 05 10:44:33 ThinkParch-E570 gnome-session-binary[789]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 10:44:33 ThinkParch-E570 gnome-session[789]: gnome-session-binary[789]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 10:44:26 ThinkParch-E570 sudo[6048]: pam_unix(sudo:session): session closed for user root
Oct 05 10:44:22 ThinkParch-E570 gnome-shell[826]: Ignored exception from dbus method: Gio.IOErrorEnum: GDBus.Error:org.gtk.GDBus.UnmappedGError.Quark._g_2dio_2derror_2dquark.Code19: Operation was cancelled
Oct 05 10:44:22 ThinkParch-E570 gnome-session-binary[789]: Entering running state
Oct 05 10:44:20 ThinkParch-E570 kernel: [drm:intel_pipe_update_end [i915]] *ERROR* Atomic update failure on pipe A (start=61208 end=61209) time 120 us, min 1073, max 1079, scanline start 1072, end 1080
Oct 05 10:44:19 ThinkParch-E570 gnome-session-binary[789]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 10:44:19 ThinkParch-E570 gnome-session[789]: gnome-session-binary[789]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 10:43:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=144400
Oct 05 10:42:59 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-48 noise=9999 txrate=144400
Oct 05 10:42:59 ThinkParch-E570 NetworkManager[282]: <info>  [1507218179.4751] device (wlp5s0): supplicant interface state: associated -> completed
Oct 05 10:42:59 ThinkParch-E570 NetworkManager[282]: <info>  [1507218179.4747] device (wlp5s0): supplicant interface state: associating -> associated
Oct 05 10:42:59 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-48 noise=9999 txrate=11000
Oct 05 10:42:59 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-CONNECTED - Connection to 84:d4:7e:2d:2d:41 completed [id=0 id_str=]
Oct 05 10:42:59 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: WPA: Key negotiation completed with 84:d4:7e:2d:2d:41 [PTK=CCMP GTK=CCMP]
Oct 05 10:42:59 ThinkParch-E570 NetworkManager[282]: <info>  [1507218179.4670] device (wlp5s0): supplicant interface state: authenticating -> associating
Oct 05 10:42:59 ThinkParch-E570 kernel: wlp5s0: associated
Oct 05 10:42:59 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Oct 05 10:42:59 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: Associated with 84:d4:7e:2d:2d:41
Oct 05 10:42:59 ThinkParch-E570 NetworkManager[282]: <info>  [1507218179.4496] device (wlp5s0): supplicant interface state: completed -> authenticating
Oct 05 10:42:59 ThinkParch-E570 kernel: wlp5s0: RX AssocResp from 84:d4:7e:2d:2d:41 (capab=0x431 status=0 aid=1)
Oct 05 10:42:59 ThinkParch-E570 kernel: wlp5s0: associate with 84:d4:7e:2d:2d:41 (try 1/3)
Oct 05 10:42:59 ThinkParch-E570 kernel: wlp5s0: authenticated
Oct 05 10:42:59 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: Trying to associate with 84:d4:7e:2d:2d:41 (SSID='uni net' freq=2462 MHz)
Oct 05 10:42:59 ThinkParch-E570 kernel: wlp5s0: send auth to 84:d4:7e:2d:2d:41 (try 1/3)
Oct 05 10:42:59 ThinkParch-E570 kernel: wlp5s0: authenticate with 84:d4:7e:2d:2d:41
Oct 05 10:42:59 ThinkParch-E570 kernel: wlp5s0: disconnect from AP 84:d4:7e:2d:2d:51 for new auth to 84:d4:7e:2d:2d:41
Oct 05 10:42:59 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: SME: Trying to authenticate with 84:d4:7e:2d:2d:41 (SSID='uni nett' freq=2462 MHz)
Oct 05 10:42:46 ThinkParch-E570 variety.desktop[1045]: INFO: 2017-10-05 10:42:46,000: update_indicator() 'Setting file info to: /home/edd/Pictures/desktop backgrounds/fzzvhloka5qy.png'
Oct 05 10:42:45 ThinkParch-E570 systemd[1]: Started Cleanup of Temporary Directories.
Oct 05 10:42:45 ThinkParch-E570 variety.desktop[1045]: INFO: 2017-10-05 10:42:45,954: do_set_wp() 'Calling do_set_wp with /home/edd/Pictures/desktop backgrounds/fzzvhloka5qy.png, time: 1507218165.95'
Oct 05 10:42:45 ThinkParch-E570 variety.desktop[1045]: INFO: 2017-10-05 10:42:45,952: prepare_thread() 'Prepared buffer contains 97 images'
Oct 05 10:42:45 ThinkParch-E570 variety.desktop[1045]: INFO: 2017-10-05 10:42:45,951: set_wallpaper() 'Calling set_wallpaper with /home/edd/Pictures/desktop backgrounds/fzzvhloka5qy.png'
Oct 05 10:42:45 ThinkParch-E570 systemd[1]: Starting Cleanup of Temporary Directories...
Oct 05 10:42:45 ThinkParch-E570 variety.desktop[1045]: INFO: 2017-10-05 10:42:45,949: regular_change_thread() 'regular_change changes wallpaper'
Oct 05 10:40:58 ThinkParch-E570 kernel: wlp5s0: Limiting TX power to 36 (36 - 0) dBm as advertised by 84:d4:7e:2d:2d:51
Oct 05 10:40:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-63 noise=9999 txrate=360000
Oct 05 10:40:58 ThinkParch-E570 NetworkManager[282]: <info>  [1507218058.1900] device (wlp5s0): supplicant interface state: associated -> completed
Oct 05 10:40:58 ThinkParch-E570 NetworkManager[282]: <info>  [1507218058.1899] device (wlp5s0): supplicant interface state: associating -> associated
Oct 05 10:40:58 ThinkParch-E570 NetworkManager[282]: <info>  [1507218058.1887] device (wlp5s0): supplicant interface state: authenticating -> associating
Oct 05 10:40:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-CONNECTED - Connection to 84:d4:7e:2d:2d:51 completed [id=0 id_str=]
Oct 05 10:40:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: WPA: Key negotiation completed with 84:d4:7e:2d:2d:51 [PTK=CCMP GTK=CCMP]
Oct 05 10:40:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Oct 05 10:40:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: Associated with 84:d4:7e:2d:2d:51
Oct 05 10:40:58 ThinkParch-E570 kernel: wlp5s0: associated
Oct 05 10:40:58 ThinkParch-E570 kernel: wlp5s0: RX AssocResp from 84:d4:7e:2d:2d:51 (capab=0x11 status=0 aid=1)
Oct 05 10:40:58 ThinkParch-E570 kernel: wlp5s0: associate with 84:d4:7e:2d:2d:51 (try 1/3)
Oct 05 10:40:58 ThinkParch-E570 kernel: wlp5s0: authenticated
Oct 05 10:40:58 ThinkParch-E570 NetworkManager[282]: <info>  [1507218058.1530] device (wlp5s0): supplicant interface state: completed -> authenticating
Oct 05 10:40:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: Trying to associate with 84:d4:7e:2d:2d:51 (SSID='uni net' freq=5805 MHz)
Oct 05 10:40:58 ThinkParch-E570 kernel: wlp5s0: send auth to 84:d4:7e:2d:2d:51 (try 1/3)
Oct 05 10:40:58 ThinkParch-E570 kernel: wlp5s0: authenticate with 84:d4:7e:2d:2d:51
Oct 05 10:40:58 ThinkParch-E570 kernel: wlp5s0: disconnect from AP 84:d4:7e:2d:2d:41 for new auth to 84:d4:7e:2d:2d:51
Oct 05 10:40:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: SME: Trying to authenticate with 84:d4:7e:2d:2d:51 (SSID='uni net' freq=5805 MHz)
Oct 05 10:40:50 ThinkParch-E570 sudo[6048]: pam_unix(sudo:session): session opened for user root by edd(uid=0)
Oct 05 10:40:50 ThinkParch-E570 sudo[6048]:      edd : TTY=pts/1 ; PWD=/home/edd ; USER=root ; COMMAND=/usr/bin/journalctl -b -1 -r
Oct 05 10:40:43 ThinkParch-E570 sudo[4959]: pam_unix(sudo:session): session closed for user root
Oct 05 10:38:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-49 noise=9999 txrate=144400
Oct 05 10:42:59 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: SME: Trying to authenticate with 84:d4:7e:2d:2d:41 (SSID='uni net' freq=2462 MHz)
Oct 05 10:38:58 ThinkParch-E570 NetworkManager[282]: <info>  [1507217938.6024] device (wlp5s0): supplicant interface state: 4-way handshake -> completed
Oct 05 10:38:58 ThinkParch-E570 NetworkManager[282]: <info>  [1507217938.5997] device (wlp5s0): supplicant interface state: associating -> 4-way handshake
Oct 05 10:38:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-50 noise=9999 txrate=11000
Oct 05 10:38:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-CONNECTED - Connection to 84:d4:7e:2d:2d:41 completed [id=0 id_str=]
Oct 05 10:38:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: WPA: Key negotiation completed with 84:d4:7e:2d:2d:41 [PTK=CCMP GTK=CCMP]
Oct 05 10:38:58 ThinkParch-E570 NetworkManager[282]: <info>  [1507217938.5827] device (wlp5s0): supplicant interface state: authenticating -> associating
Oct 05 10:38:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Oct 05 10:38:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: Associated with 84:d4:7e:2d:2d:41
Oct 05 10:38:58 ThinkParch-E570 kernel: wlp5s0: associated
Oct 05 10:38:58 ThinkParch-E570 kernel: wlp5s0: RX AssocResp from 84:d4:7e:2d:2d:41 (capab=0x431 status=0 aid=1)
Oct 05 10:38:58 ThinkParch-E570 kernel: wlp5s0: associate with 84:d4:7e:2d:2d:41 (try 1/3)
Oct 05 10:38:58 ThinkParch-E570 kernel: wlp5s0: authenticated
Oct 05 10:38:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: Trying to associate with 84:d4:7e:2d:2d:41 (SSID='uni net' freq=2462 MHz)
Oct 05 10:38:58 ThinkParch-E570 NetworkManager[282]: <info>  [1507217938.5619] device (wlp5s0): supplicant interface state: completed -> authenticating
Oct 05 10:38:58 ThinkParch-E570 kernel: wlp5s0: send auth to 84:d4:7e:2d:2d:41 (try 1/3)
Oct 05 10:38:58 ThinkParch-E570 kernel: wlp5s0: authenticate with 84:d4:7e:2d:2d:41
Oct 05 10:38:58 ThinkParch-E570 kernel: wlp5s0: disconnect from AP 84:d4:7e:2d:2d:51 for new auth to 84:d4:7e:2d:2d:41
Oct 05 10:38:58 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: SME: Trying to authenticate with 84:d4:7e:2d:2d:41 (SSID='uni net' freq=2462 MHz)
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935787        [email protected]        WARN        Please specify whether you want browser_style or not in your browser_ac
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935646        addons.xpi        ERROR        Failed to clean updated system add-ons directories.
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935603        addons.xpi        WARN        Add-on [email protected] is missing bootstrap method install
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935588        addons.xpi        WARN        Add-on [email protected] is missing bootstrap method uninstall
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935507        addons.xpi        WARN        Please specify whether you want browser_style or not in your options_ui options.
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935283        addons.update-checker        WARN        Update manifest for [email protected] did not contain an updates property
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935277        addons.update-checker        WARN        Update manifest for [email protected] did not contain an updates property
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935272        addons.update-checker        WARN        Update manifest for [email protected] did not contain an updates property
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935241        addons.update-checker        WARN        Update manifest for [email protected] did not contain an updates property
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935227        addons.update-checker        WARN        Update manifest for {972ce4c6-7e08-4474-a285-3208198ce6fd} did not contain an updates property
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935216        addons.update-checker        WARN        Update manifest for [email protected] did not contain an updates property
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935194        addons.update-checker        WARN        Update manifest for [email protected] did not contain an updates property
Oct 05 10:38:55 ThinkParch-E570 firefox.desktop[2080]: 1507217935161        addons.update-checker        WARN        Update manifest for [email protected] did not contain an updates property
Oct 05 10:37:42 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-60 noise=9999 txrate=400000
Oct 05 10:37:13 ThinkParch-E570 org.gnome.Nautilus[787]: [2564:2593:1005/103713.308892:ERROR:connection_factory_impl.cc(386)] Failed to connect to MCS endpoint with error -105
Oct 05 10:37:13 ThinkParch-E570 org.gnome.Nautilus[787]: [2564:2593:1005/103713.308828:ERROR:connection_factory_impl.cc(386)] Failed to connect to MCS endpoint with error -105
Oct 05 10:37:04 ThinkParch-E570 kernel: wlp5s0: Limiting TX power to 36 (36 - 0) dBm as advertised by 84:d4:7e:2d:2d:51
Oct 05 10:37:04 ThinkParch-E570 NetworkManager[282]: <info>  [1507217824.1815] device (wlp5s0): supplicant interface state: associated -> completed
Oct 05 10:37:04 ThinkParch-E570 NetworkManager[282]: <info>  [1507217824.1810] device (wlp5s0): supplicant interface state: associating -> associated
Oct 05 10:37:04 ThinkParch-E570 NetworkManager[282]: <info>  [1507217824.1809] device (wlp5s0): supplicant interface state: authenticating -> associating
Oct 05 10:37:04 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-64 noise=9999 txrate=12000
Oct 05 10:37:04 ThinkParch-E570 wpa_supplicant[483]: wlp5s0: CTRL-EVENT-CONNECTED - Connection to 84:d4:7e:2d:2d:51 completed [id=0 id_str=]
Some how this worked and now bluetooth is no longer auto starting
rfkill block bluetooth
bluetooth is turned off
rfkill list
0: tpacpi_bluetooth_sw: Bluetooth
	Soft blocked: yes
	Hard blocked: no
1: phy0: Wireless LAN
	Soft blocked: no
	Hard blocked: no
source bluetooth from [solved]Turn on/off bluetooth hardware working in GNOME but not in KDE / Newbie Corner / Arch Linux Forums
I dunno why bluetooth got enabled, my guess is that when DE hopping, KDE must have different bluetooth settings then gnome so that’s why bluetooth auto enabled?
Not sure if that was the issue or if it was something else
still trying to figure out how to solve the other issue
