disabled all plugins turned off wifi
Oct 05 14:28:39 ThinkParch-E570 systemd-journald[161]: Journal stopped
Oct 05 14:28:39 ThinkParch-E570 systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Oct 05 14:28:38 ThinkParch-E570 kernel: systemd-shutdow: 38 output lines suppressed due to ratelimiting
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Shutting down.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Starting Power-Off...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Reached target Final Step.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Reached target Unmount All Filesystems.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-uuid/a7d3b2b5-6636-4514-bf68-8d55ef8dc8ad.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Deactivated swap /dev/sda4.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-id/ata-KINGSTON_SV300S37A120G_50026B736500A35C-part4.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-id/wwn-0x50026b736500a35c-part4.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-label/AntergosSwap.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-partlabel/ANTERGOS_SWAP.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-partuuid/346f8e16-f10f-4483-b0f5-0bf77f7535dd.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Deactivated swap /dev/disk/by-path/pci-0000:00:17.0-ata-1-part4.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Reached target Shutdown.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Create Static Device Nodes in /dev.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Remount Root and Kernel File Systems.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Local File Systems (Pre).
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Unmounted /boot.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Deactivating swap /dev/disk/by-path/pci-0000:00:17.0-ata-1-part4...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Swap.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Unmounted Temporary Directory (/tmp).
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Unmounted /run/user/1000.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Unmounting /boot...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Unmounted /boot/efi.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Unmounting /run/user/1000...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Unmounting /boot/efi...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Unmounting Temporary Directory (/tmp)...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Local File Systems.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Create Volatile Files and Directories.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Update UTMP about System Boot/Shutdown.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Removed slice system-systemd\x2dbacklight.slice.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Load/Save Screen Backlight Brightness of backlight:intel_backlight.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Load/Save Random Seed.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Load Kernel Modules.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Apply Kernel Variables.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Set Up Additional Binary Formats.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopping Load/Save Screen Backlight Brightness of backlight:intel_backlight...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopping Load/Save Random Seed...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopping Update UTMP about System Boot/Shutdown...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Forward Password Requests to Wall Directory Watch.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Dispatch Password Requests to Console Directory Watch.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Encrypted Volumes.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target System Initialization.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Closed D-Bus System Message Bus Socket.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Closed CUPS Scheduler.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Closed Avahi mDNS/DNS-SD Stack Activation Socket.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Sockets.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped CUPS Scheduler.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Paths.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Removed slice User and Session Slice.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Slices.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Basic System.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped D-Bus System Message Bus.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopping D-Bus System Message Bus...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Network Manager.
Oct 05 14:28:38 ThinkParch-E570 NetworkManager[317]: <info> [1507231718.7449] exiting (success)
Oct 05 14:28:38 ThinkParch-E570 NetworkManager[317]: <warn> [1507231718.7449] dns-mgr: could not commit DNS changes on shutdown: /usr/bin/resolvconf returned error code
Oct 05 14:28:38 ThinkParch-E570 NetworkManager[317]: No resolv.conf for interface NetworkManager
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target User and Group Name Lookups.
Oct 05 14:28:38 ThinkParch-E570 NetworkManager[317]: <info> [1507231718.7176] dns-mgr: Removing DNS information from /usr/bin/resolvconf
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Login Service.
Oct 05 14:28:38 ThinkParch-E570 NetworkManager[317]: <info> [1507231718.6340] device (wlp5s0): set-hw-addr: reset MAC address to 00:28:F8:20:25:C4 (unmanage)
Oct 05 14:28:38 ThinkParch-E570 NetworkManager[317]: <info> [1507231718.6339] device (wlp5s0): state change: unavailable -> unmanaged (reason 'unmanaged', internal state 'managed')
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped WPA supplicant.
Oct 05 14:28:38 ThinkParch-E570 NetworkManager[317]: <info> [1507231718.6324] caught SIGTERM, shutting down normally.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopping Network Manager...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopping WPA supplicant...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Network.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped clamav daemon.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped target Remote File Systems.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Permit User Sessions.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopping Permit User Sessions...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopping Login Service...
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Removed slice User Slice of edd.
Oct 05 14:28:38 ThinkParch-E570 systemd[1]: Stopped Session c2 of user edd.
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) Server terminated successfully (0). Closing log file.
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (WW) xf86CloseConsole: VT_ACTIVATE failed: Input/output error
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (WW) xf86CloseConsole: VT_GETMODE failed: Input/output error
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (WW) xf86CloseConsole: KDSETMODE failed: Input/output error
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:67
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) UnloadModule: "libinput"
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:69
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:70
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:65
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:66
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:80
Oct 05 14:28:38 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:73
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:74
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) UnloadModule: "libinput"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:75
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:76
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:77
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:78
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped GNOME Display Manager.
Oct 05 14:28:37 ThinkParch-E570 gdm[424]: GLib: g_hash_table_find: assertion 'version == hash_table->version' failed
Oct 05 14:28:37 ThinkParch-E570 gdm[424]: Failed to contact accountsservice: Error calling StartServiceByName for org.freedesktop.Accounts: GDBus.Error:org.freedesktop.systemd1.ShuttingDown: Refusing activation,
Oct 05 14:28:37 ThinkParch-E570 dbus[270]: [system] Activation via systemd failed for unit 'accounts-daemon.service': Refusing activation, D-Bus is shutting down.
Oct 05 14:28:37 ThinkParch-E570 dbus[270]: [system] Activating via systemd: service name='org.freedesktop.Accounts' unit='accounts-daemon.service'
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:79
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Started Generate shutdown-ramfs.
Oct 05 14:28:37 ThinkParch-E570 mkinitcpio[2077]: ==> Build complete.
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:64
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:81
Oct 05 14:28:37 ThinkParch-E570 gdm[424]: Freeing conversation 'gdm-password' with active job
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:82
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped User Manager for UID 1000.
Oct 05 14:28:37 ThinkParch-E570 systemd[773]: pam_unix(systemd-user:session): session closed for user edd
Oct 05 14:28:37 ThinkParch-E570 mkinitcpio[2077]: -> Running build hook: [sd-shutdown]
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Unmounted /run/user/120.
Oct 05 14:28:37 ThinkParch-E570 mkinitcpio[2077]: ==> Starting build: none
Oct 05 14:28:37 ThinkParch-E570 systemd-logind[266]: Removed session c1.
Oct 05 14:28:37 ThinkParch-E570 NetworkManager[317]: <warn> [1507231717.6602] error requesting auth for org.freedesktop.NetworkManager.wifi.share.open: Authorization check failed: Refusing activation, D-Bus is
Oct 05 14:28:37 ThinkParch-E570 NetworkManager[317]: <warn> [1507231717.6602] error requesting auth for org.freedesktop.NetworkManager.wifi.share.protected: Authorization check failed: Refusing activation, D-Bu
Oct 05 14:28:37 ThinkParch-E570 dbus[270]: [system] Activation via systemd failed for unit 'polkit.service': Refusing activation, D-Bus is shutting down.
Oct 05 14:28:37 ThinkParch-E570 dbus[270]: [system] Activation via systemd failed for unit 'dbus-org.freedesktop.Avahi.service': Refusing activation, D-Bus is shutting down.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Removed slice User Slice of gdm.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Session c1 of user gdm.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Received SIGRTMIN+24 from PID 2087 (kill).
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped User Manager for UID 120.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Starting Exit the Session...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Reached target Shutdown.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Closed Sound System.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Closed GnuPG network certificate management daemon.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Closed GnuPG cryptographic agent and passphrase cache.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Closed D-Bus User Message Bus Socket.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped target Sockets.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped target Timers.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped target Paths.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped target Basic System.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped Sound Service.
Oct 05 14:28:37 ThinkParch-E570 systemd[512]: pam_unix(systemd-user:session): session closed for user gdm
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Disk Manager.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Location Lookup Service.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Modem Manager.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Received SIGRTMIN+24 from PID 2086 (kill).
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped Evolution source registry.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Starting Exit the Session...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped Evolution calendar service.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Reached target Shutdown.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Closed D-Bus User Message Bus Socket.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopped target Paths.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Closed GnuPG cryptographic agent (ssh-agent emulation).
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Closed GnuPG cryptographic agent and passphrase cache (access for web browsers).
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Closed Sound System.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Closed GnuPG network certificate management daemon.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Closed GnuPG cryptographic agent and passphrase cache.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Closed GnuPG cryptographic agent and passphrase cache (restricted).
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopped target Sockets.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopped target Timers.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopped target Basic System.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopped D-Bus User Message Bus.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Authorization Manager.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Avahi mDNS/DNS-SD Stack.
Oct 05 14:28:37 ThinkParch-E570 chromium.desktop[1328]: [1328:1328:1005/142837.619609:ERROR:zygote_communication_linux.cc(297)] Failed to send GetTerminationStatus message to zygote
Oct 05 14:28:37 ThinkParch-E570 dbus[270]: [system] Activating via systemd: service name='org.freedesktop.PolicyKit1' unit='polkit.service'
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped Virtual filesystem service.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Bluetooth service.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Network Manager Script Dispatcher Service.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped CUPS Scheduler.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Manage, Install and Generate Color Profiles.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped RealtimeKit Scheduling Policy Service.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Daemon for power management.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Accounts Service.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Entropy Harvesting Daemon.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped clamav updater.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Unmounted /run/user/1000/gvfs.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped GnuPG cryptographic agent and passphrase cache.
Oct 05 14:28:37 ThinkParch-E570 gpg-agent[1854]: gpg-agent (GnuPG) 2.2.1 stopped
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped D-Bus User Message Bus.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopped Sound Service.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Starting Generate shutdown-ramfs...
Oct 05 14:28:37 ThinkParch-E570 bluetoothd[518]: Exit
Oct 05 14:28:37 ThinkParch-E570 bluetoothd[518]: Stopping SDP server
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Bluetooth service...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped target Bluetooth.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping CUPS Scheduler...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Daily verification of password and group files.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping User Manager for UID 1000...
Oct 05 14:28:37 ThinkParch-E570 bluetoothd[518]: Terminating
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped Tracker metadata database store and lookup manager.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped Virtual filesystem metadata service.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped Evolution address book service.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped Virtual filesystem service - Media Transfer Protocol monitor.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped Virtual filesystem service - disk device monitor.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping GnuPG cryptographic agent and passphrase cache...
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopped Accessibility services bus.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping Virtual filesystem service...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping Evolution address book service...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopped target Default.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping Virtual filesystem service - Media Transfer Protocol monitor...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping Sound Service...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping Tracker metadata database store and lookup manager...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping Virtual filesystem service - disk device monitor...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping Evolution calendar service...
Oct 05 14:28:37 ThinkParch-E570 NetworkManager[317]: <info> [1507231717.5631] ModemManager disappeared from bus
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping Evolution source registry...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping D-Bus User Message Bus...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: Stopping Virtual filesystem metadata service...
Oct 05 14:28:37 ThinkParch-E570 gpg-agent[1854]: SIGTERM received - shutting down ...
Oct 05 14:28:37 ThinkParch-E570 tracker-store[1038]: OK
Oct 05 14:28:37 ThinkParch-E570 tracker-store[1038]: Received signal:15->'Terminated'
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Location Lookup Service...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Daily rotation of log files.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping GNOME Display Manager...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Modem Manager...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped target Login Prompts.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Monthly clean packages cache.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Daily man-db cache update.
Oct 05 14:28:37 ThinkParch-E570 ModemManager[318]: <info> ModemManager is shut down
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Entropy Harvesting Daemon...
Oct 05 14:28:37 ThinkParch-E570 gvfsd[835]: A connection to the bus can't be made
Oct 05 14:28:37 ThinkParch-E570 ModemManager[318]: <info> Caught signal, shutting down...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping clamav daemon...
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) systemd-logind: releasing fd for 13:71
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event7 - (II) ThinkPad Extra Buttons: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "40"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event18 - (II) TPPS/2 IBM TrackPoint: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "39"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event17 - (II) SynPS/2 Synaptics TouchPad: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "38"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event0 - (II) AT Translated Set 2 keyboard: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "37"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event15 - (II) HDA Intel PCH HDMI/DP,pcm=10: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "36"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event14 - (II) HDA Intel PCH HDMI/DP,pcm=9: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "35"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event13 - (II) HDA Intel PCH HDMI/DP,pcm=8: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "34"
Oct 05 14:28:37 ThinkParch-E570 haveged[319]: haveged starting up
Oct 05 14:28:37 ThinkParch-E570 haveged[319]: haveged: Stopping due to signal 15
Oct 05 14:28:37 ThinkParch-E570 dbus[270]: [system] Activating via systemd: service name='org.freedesktop.Avahi' unit='dbus-org.freedesktop.Avahi.service'
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event12 - (II) HDA Intel PCH HDMI/DP,pcm=7: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "33"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event11 - (II) HDA Intel PCH HDMI/DP,pcm=3: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "32"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event10 - (II) HDA Intel PCH Headphone: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "31"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event9 - (II) HDA Intel PCH Mic: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "30"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event16 - (II) Integrated Camera: Integrated C: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "29"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event2 - (II) Sleep Button: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "28"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event1 - (II) Lid Switch: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "27"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event6 - (II) Video Bus: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "26"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event5 - (II) Video Bus: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "25"
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (II) event3 - (II) Power Button: (II) device removed
Oct 05 14:28:37 ThinkParch-E570 /usr/lib/gdm/gdm-x-session[785]: (**) Option "fd" "22"
Oct 05 14:28:37 ThinkParch-E570 avahi-daemon[268]: avahi-daemon 0.7 exiting.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Avahi mDNS/DNS-SD Stack...
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: at-spi-dbus-bus.service: Failed with result 'exit-code'.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: at-spi-dbus-bus.service: Unit entered failed state.
Oct 05 14:28:37 ThinkParch-E570 systemd[772]: at-spi-dbus-bus.service: Main process exited, code=exited, status=1/FAILURE
Oct 05 14:28:37 ThinkParch-E570 geoclue[889]: Avahi client failure: Daemon connection failed
Oct 05 14:28:37 ThinkParch-E570 at-spi-bus-launcher[809]: after 0 requests (0 known processed) with 0 events remaining.
Oct 05 14:28:37 ThinkParch-E570 at-spi-bus-launcher[809]: XIO: fatal IO error 4 (Interrupted system call) on X server ":0"
Oct 05 14:28:37 ThinkParch-E570 avahi-daemon[268]: Got SIGTERM, quitting.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping clamav updater...
Oct 05 14:28:37 ThinkParch-E570 udisksd[914]: udisks daemon version 2.7.3 exiting
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped target Multi-User System.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped target Graphical Interface.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Disk Manager...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped Daily Cleanup of Temporary Directories.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped target Timers.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopped target Sound Card.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Authorization Manager...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Network Manager Script Dispatcher Service...
Oct 05 14:28:37 ThinkParch-E570 nm-dispatcher[2048]: Caught signal 15, shutting down...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Daemon for power management...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Session c2 of user edd.
Oct 05 14:28:37 ThinkParch-E570 tracker-miner-fs.desktop[1028]: Received signal:15->'Terminated'
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Accounts Service...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Manage, Install and Generate Color Profiles...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping RealtimeKit Scheduling Policy Service...
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopping D-Bus User Message Bus...
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopping Accessibility services bus...
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopped target Default.
Oct 05 14:28:37 ThinkParch-E570 systemd[511]: Stopping Sound Service...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Removed slice system-getty.slice.
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping User Manager for UID 120...
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Stopping Session c1 of user gdm.
Oct 05 14:28:37 ThinkParch-E570 gnome-session-binary[526]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 14:28:37 ThinkParch-E570 gnome-session[526]: gnome-session-binary[526]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 14:28:37 ThinkParch-E570 gdm[424]: Freeing conversation 'gdm-launch-environment' with active job
Oct 05 14:28:37 ThinkParch-E570 gdm[424]: Tried to look up non-existent conversation gdm-launch-environment
Oct 05 14:28:37 ThinkParch-E570 systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Oct 05 14:28:37 ThinkParch-E570 gnome-session-binary[795]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 14:28:37 ThinkParch-E570 gnome-session[795]: gnome-session-binary[795]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 14:28:37 ThinkParch-E570 systemd-logind[266]: System is powering down.
Oct 05 14:28:37 ThinkParch-E570 gnome-shell[832]: JS WARNING: [resource:///org/gnome/shell/ui/modalDialog.js 311]: reference to undefined property global.gdk_screen
Oct 05 14:28:34 ThinkParch-E570 gnome-session-binary[795]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 14:28:34 ThinkParch-E570 gnome-session[795]: gnome-session-binary[795]: GLib-GObject-CRITICAL: g_object_unref: assertion 'G_IS_OBJECT (object)' failed
Oct 05 14:28:32 ThinkParch-E570 chromium.desktop[1328]: [1328:1357:1005/142832.829731:ERROR:connection_factory_impl.cc(386)] Failed to connect to MCS endpoint with error -106
Oct 05 14:28:31 ThinkParch-E570 nm-dispatcher[2048]: req:2 'down' [wlp5s0]: completed: no scripts
Oct 05 14:28:31 ThinkParch-E570 nm-dispatcher[2048]: req:2 'down' [wlp5s0]: new request (0 scripts)
Oct 05 14:28:31 ThinkParch-E570 wpa_supplicant[469]: nl80211: deinit ifname=wlp5s0 disabled_11b_rates=0
Oct 05 14:28:30 ThinkParch-E570 wpa_supplicant[469]: nl80211: deinit ifname=p2p-dev-wlp5s0 disabled_11b_rates=0
Oct 05 14:28:30 ThinkParch-E570 wpa_supplicant[469]: nl80211: Failed to set IPv4 unicast in multicast filter
Oct 05 14:28:30 ThinkParch-E570 wpa_supplicant[469]: nl80211: Failed to open /proc/sys/net/ipv4/conf/p2p-dev-wlp5s0/drop_unicast_in_l2_multicast: No such file or directory
Oct 05 14:28:30 ThinkParch-E570 NetworkManager[317]: <info> [1507231710.9723] manager: NetworkManager state is now DISCONNECTED
Oct 05 14:28:30 ThinkParch-E570 NetworkManager[317]: <info> [1507231710.9712] manager: NetworkManager state is now CONNECTED_LOCAL
Oct 05 14:28:30 ThinkParch-E570 nm-dispatcher[2048]: req:1 'connectivity-change': completed: no scripts
Oct 05 14:28:30 ThinkParch-E570 nm-dispatcher[2048]: req:1 'connectivity-change': new request (0 scripts)
Oct 05 14:28:30 ThinkParch-E570 systemd[1]: Started Network Manager Script Dispatcher Service.
Oct 05 14:28:30 ThinkParch-E570 dbus[270]: [system] Successfully activated service 'org.freedesktop.nm_dispatcher'
Oct 05 14:28:30 ThinkParch-E570 systemd[1]: Starting Network Manager Script Dispatcher Service...
Oct 05 14:28:30 ThinkParch-E570 gsd-sharing[955]: Failed to StopUnit service: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit vino-server.service not loaded.
Oct 05 14:28:30 ThinkParch-E570 gsd-sharing[955]: Failed to StopUnit service: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit rygel.service not loaded.
Oct 05 14:28:30 ThinkParch-E570 gsd-sharing[955]: Failed to StopUnit service: GDBus.Error:org.freedesktop.systemd1.NoSuchUnit: Unit gnome-user-share-webdav.service not loaded.
Oct 05 14:28:30 ThinkParch-E570 dbus[270]: [system] Activating via systemd: service name='org.freedesktop.nm_dispatcher' unit='dbus-org.freedesktop.nm-dispatcher.service'
Oct 05 14:28:30 ThinkParch-E570 systemd[1]: Started Load/Save RF Kill Switch Status.
Oct 05 14:28:30 ThinkParch-E570 wpa_supplicant[469]: rfkill: WLAN soft blocked
Oct 05 14:28:30 ThinkParch-E570 NetworkManager[317]: <info> [1507231710.8102] dns-mgr: Removing DNS information from /usr/bin/resolvconf
Oct 05 14:28:30 ThinkParch-E570 NetworkManager[317]: <info> [1507231710.8100] device (wlp5s0): set-hw-addr: set MAC address to 5A:7B:54:7D:EE:4C (scanning)
Oct 05 14:28:30 ThinkParch-E570 NetworkManager[317]: <info> [1507231710.8079] dhcp4 (wlp5s0): state changed bound -> done
Oct 05 14:28:30 ThinkParch-E570 NetworkManager[317]: <info> [1507231710.8079] dhcp4 (wlp5s0): canceled DHCP transaction
Oct 05 14:28:30 ThinkParch-E570 NetworkManager[317]: <info> [1507231710.8076] device (wlp5s0): state change: activated -> unavailable (reason 'none', internal state 'managed')
Oct 05 14:28:30 ThinkParch-E570 NetworkManager[317]: <info> [1507231710.8075] manager: rfkill: WiFi now disabled by radio killswitch
Oct 05 14:28:30 ThinkParch-E570 systemd[1]: Starting Load/Save RF Kill Switch Status...
Oct 05 14:28:30 ThinkParch-E570 avahi-daemon[268]: Withdrawing address record for 10.194.124.229 on wlp5s0.
Oct 05 14:28:30 ThinkParch-E570 avahi-daemon[268]: Withdrawing address record for fe80::bb6:44ec:be5b:7ef7 on wlp5s0.
Oct 05 14:28:30 ThinkParch-E570 avahi-daemon[268]: Leaving mDNS multicast group on interface wlp5s0.IPv4 with address 10.194.124.229.
Oct 05 14:28:30 ThinkParch-E570 avahi-daemon[268]: Interface wlp5s0.IPv4 no longer relevant for mDNS.
Oct 05 14:28:30 ThinkParch-E570 avahi-daemon[268]: Leaving mDNS multicast group on interface wlp5s0.IPv6 with address fe80::bb6:44ec:be5b:7ef7.
Oct 05 14:28:30 ThinkParch-E570 avahi-daemon[268]: Interface wlp5s0.IPv6 no longer relevant for mDNS.
Oct 05 14:28:30 ThinkParch-E570 kernel: wlp5s0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-22)
Oct 05 14:28:30 ThinkParch-E570 NetworkManager[317]: <warn> [1507231710.7777] sup-iface[0x55d5fa151670,wlp5s0]: connection disconnected (reason -3)
Oct 05 14:28:30 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-DISCONNECTED bssid=84:d4:7e:64:dc:11 reason=3 locally_generated=1
Oct 05 14:28:30 ThinkParch-E570 kernel: wlp5s0: deauthenticating from 84:d4:7e:64:dc:11 by local choice (Reason: 3=DEAUTH_LEAVING)
Oct 05 14:28:11 ThinkParch-E570 NetworkManager[317]: <info> [1507231691.3585] device (wlp5s0): supplicant interface state: associated -> completed
Oct 05 14:28:11 ThinkParch-E570 NetworkManager[317]: <info> [1507231691.3582] device (wlp5s0): supplicant interface state: associating -> associated
Oct 05 14:28:11 ThinkParch-E570 NetworkManager[317]: <info> [1507231691.3136] device (wlp5s0): supplicant interface state: authenticating -> associating
Oct 05 14:28:11 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-61 noise=9999 txrate=12000
Oct 05 14:28:11 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-CONNECTED - Connection to 84:d4:7e:64:dc:11 completed [id=0 id_str=]
Oct 05 14:28:11 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: WPA: Key negotiation completed with 84:d4:7e:64:dc:11 [PTK=CCMP GTK=CCMP]
Oct 05 14:28:11 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Oct 05 14:28:11 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: Associated with 84:d4:7e:64:dc:11
Oct 05 14:28:11 ThinkParch-E570 kernel: wlp5s0: associated
Oct 05 14:28:11 ThinkParch-E570 kernel: wlp5s0: RX AssocResp from 84:d4:7e:64:dc:11 (capab=0x411 status=0 aid=12)
Oct 05 14:28:11 ThinkParch-E570 kernel: wlp5s0: associate with 84:d4:7e:64:dc:11 (try 1/3)
Oct 05 14:28:11 ThinkParch-E570 kernel: wlp5s0: authenticated
Oct 05 14:28:11 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: Trying to associate with 84:d4:7e:64:dc:11 (SSID='UniNet' freq=5765 MHz)
Oct 05 14:28:11 ThinkParch-E570 NetworkManager[317]: <info> [1507231691.2613] device (wlp5s0): supplicant interface state: completed -> authenticating
Oct 05 14:28:11 ThinkParch-E570 kernel: wlp5s0: send auth to 84:d4:7e:64:dc:11 (try 1/3)
Oct 05 14:28:11 ThinkParch-E570 kernel: wlp5s0: authenticate with 84:d4:7e:64:dc:11
Oct 05 14:28:11 ThinkParch-E570 kernel: wlp5s0: disconnect from AP 84:d4:7e:64:e0:11 for new auth to 84:d4:7e:64:dc:11
Oct 05 14:28:11 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: SME: Trying to authenticate with 84:d4:7e:64:dc:11 (SSID='UniNet' freq=5765 MHz)
Oct 05 14:27:37 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-70 noise=9999 txrate=270000
Oct 05 14:27:37 ThinkParch-E570 NetworkManager[317]: <info> [1507231657.3283] device (wlp5s0): supplicant interface state: associating -> completed
Oct 05 14:27:37 ThinkParch-E570 NetworkManager[317]: <info> [1507231657.3280] device (wlp5s0): supplicant interface state: authenticating -> associating
Oct 05 14:27:37 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-CONNECTED - Connection to 84:d4:7e:64:e0:11 completed [id=0 id_str=]
Oct 05 14:27:37 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: WPA: Key negotiation completed with 84:d4:7e:64:e0:11 [PTK=CCMP GTK=CCMP]
Oct 05 14:27:37 ThinkParch-E570 kernel: wlp5s0: associated
Oct 05 14:27:37 ThinkParch-E570 kernel: wlp5s0: RX AssocResp from 84:d4:7e:64:e0:11 (capab=0x411 status=0 aid=3)
Oct 05 14:27:37 ThinkParch-E570 kernel: wlp5s0: associate with 84:d4:7e:64:e0:11 (try 1/3)
Oct 05 14:27:37 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Oct 05 14:27:37 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: Associated with 84:d4:7e:64:e0:11
Oct 05 14:27:37 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: Trying to associate with 84:d4:7e:64:e0:11 (SSID='UniNet' freq=5240 MHz)
Oct 05 14:27:37 ThinkParch-E570 kernel: wlp5s0: authenticated
Oct 05 14:27:37 ThinkParch-E570 NetworkManager[317]: <info> [1507231657.2974] device (wlp5s0): supplicant interface state: scanning -> authenticating
Oct 05 14:27:37 ThinkParch-E570 kernel: wlp5s0: send auth to 84:d4:7e:64:e0:11 (try 1/3)
Oct 05 14:27:37 ThinkParch-E570 kernel: wlp5s0: authenticate with 84:d4:7e:64:e0:11
Oct 05 14:27:37 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: SME: Trying to authenticate with 84:d4:7e:64:e0:11 (SSID='UniNet' freq=5240 MHz)
Oct 05 14:27:36 ThinkParch-E570 NetworkManager[317]: <info> [1507231656.8939] device (wlp5s0): supplicant interface state: disconnected -> scanning
Oct 05 14:27:36 ThinkParch-E570 NetworkManager[317]: <info> [1507231656.8135] device (wlp5s0): supplicant interface state: authenticating -> disconnected
Oct 05 14:27:36 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-AUTH-REJECT 84:d4:7e:65:96:d1 auth_type=0 auth_transaction=2 status_code=17 ie=(null)
Oct 05 14:27:36 ThinkParch-E570 kernel: wlp5s0: 84:d4:7e:65:96:d1 denied authentication (status 17)
Oct 05 14:27:36 ThinkParch-E570 NetworkManager[317]: <info> [1507231656.7479] device (wlp5s0): supplicant interface state: scanning -> authenticating
Oct 05 14:27:36 ThinkParch-E570 kernel: wlp5s0: send auth to 84:d4:7e:65:96:d1 (try 1/3)
Oct 05 14:27:36 ThinkParch-E570 kernel: wlp5s0: authenticate with 84:d4:7e:65:96:d1
Oct 05 14:27:36 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: SME: Trying to authenticate with 84:d4:7e:65:96:d1 (SSID='UniNet' freq=5180 MHz)
Oct 05 14:27:36 ThinkParch-E570 NetworkManager[317]: <info> [1507231656.0996] device (wlp5s0): supplicant interface state: disconnected -> scanning
Oct 05 14:27:35 ThinkParch-E570 NetworkManager[317]: <info> [1507231655.9985] device (wlp5s0): supplicant interface state: authenticating -> disconnected
Oct 05 14:27:35 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-AUTH-REJECT 84:d4:7e:65:96:81 auth_type=0 auth_transaction=2 status_code=17 ie=(null)
Oct 05 14:27:35 ThinkParch-E570 kernel: wlp5s0: 84:d4:7e:65:96:81 denied authentication (status 17)
Oct 05 14:27:35 ThinkParch-E570 NetworkManager[317]: <info> [1507231655.8511] device (wlp5s0): supplicant interface state: scanning -> authenticating
Oct 05 14:27:35 ThinkParch-E570 kernel: wlp5s0: send auth to 84:d4:7e:65:96:81 (try 1/3)
Oct 05 14:27:35 ThinkParch-E570 kernel: wlp5s0: authenticate with 84:d4:7e:65:96:81
Oct 05 14:27:35 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: SME: Trying to authenticate with 84:d4:7e:65:96:81 (SSID='UniNet' freq=2462 MHz)
Oct 05 14:27:35 ThinkParch-E570 NetworkManager[317]: <info> [1507231655.1974] device (wlp5s0): supplicant interface state: disconnected -> scanning
Oct 05 14:27:35 ThinkParch-E570 NetworkManager[317]: <info> [1507231655.0973] device (wlp5s0): supplicant interface state: authenticating -> disconnected
Oct 05 14:27:35 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-AUTH-REJECT 84:d4:7e:64:dc:11 auth_type=0 auth_transaction=2 status_code=17 ie=(null)
Oct 05 14:27:35 ThinkParch-E570 NetworkManager[317]: <info> [1507231655.0867] device (wlp5s0): supplicant interface state: scanning -> authenticating
Oct 05 14:27:35 ThinkParch-E570 kernel: wlp5s0: 84:d4:7e:64:dc:11 denied authentication (status 17)
Oct 05 14:27:35 ThinkParch-E570 kernel: wlp5s0: send auth to 84:d4:7e:64:dc:11 (try 1/3)
Oct 05 14:27:35 ThinkParch-E570 kernel: wlp5s0: authenticate with 84:d4:7e:64:dc:11
Oct 05 14:27:35 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: SME: Trying to authenticate with 84:d4:7e:64:dc:11 (SSID='UniNet' freq=5765 MHz)
Oct 05 14:27:34 ThinkParch-E570 NetworkManager[317]: <info> [1507231654.3896] device (wlp5s0): supplicant interface state: disconnected -> scanning
Oct 05 14:27:34 ThinkParch-E570 gnome-shell[832]: An active wireless connection, in infrastructure mode, involves no access point?
Oct 05 14:27:34 ThinkParch-E570 gnome-shell[534]: An active wireless connection, in infrastructure mode, involves no access point?
Oct 05 14:27:34 ThinkParch-E570 NetworkManager[317]: <info> [1507231654.3127] device (wlp5s0): supplicant interface state: completed -> disconnected
Oct 05 14:27:34 ThinkParch-E570 kernel: wlp5s0: failed to remove key (1, ff:ff:ff:ff:ff:ff) from hardware (-22)
Oct 05 14:27:34 ThinkParch-E570 NetworkManager[317]: <warn> [1507231654.2844] sup-iface[0x55d5fa151670,wlp5s0]: connection disconnected (reason 3)
Oct 05 14:27:34 ThinkParch-E570 wpa_supplicant[469]: wlp5s0: CTRL-EVENT-DISCONNECTED bssid=84:d4:7e:64:e0:01 reason=3
Oct 05 14:27:34 ThinkParch-E570 kernel: wlp5s0: deauthenticated from 84:d4:7e:64:e0:01 (Reason: 3=DEAUTH_LEAVING)
Oct 05 14:27:11 ThinkParch-E570 colord[749]: lib/colord/colord-sane: error while loading shared libraries: libsane.so.1: cannot open shared object file: No such file or directory
Oct 05 14:27:11 ThinkParch-E570 systemd[1]: Started Load/Save RF Kill Switch Status.
Oct 05 14:27:11 ThinkParch-E570 dbus[270]: [system] Rejected send message, 1 matched rules; type="error", sender=":1.42" (uid=120 pid=571 comm="/usr/bin/pulseaudio --daemonize=no ") interface="(unset)" member="(
still doesn’t shut down, disabled plugins, wifi. disabling wifi solved the wifi issues, but still didn’t solve the main issue of not shutting down properly.
got any recommendations? I tried GDM because someone else suggested it, I don’t have any issues on my desktop which has the same plugins and same window manager.
Is it possible for malware to be screwing with linux?
if so I am going to have clamTk do a scan
if I can’t figure out the issue, I might just nuke the system and reinstall antergos
