lots of packages/repos arent proactive in making sure they have a new version available for the new release.
The best way, IMO, to upgrade (version to version) is to wait out the hiccups.
Well, yeah, I would expect that of third-party software and packages, but one that is part of the Distribution? Only thing I can think of is that KDE dropped the project (last release was 5 years ago was well), but I donāt see anything about that.
32 was released in the last couple days, yeah?
I always gave it at least 14 days before doing a fedora release upgrade.
Seems like thereās a lot of small packages there. They may have consolidated them in to one, and just not set up proper replacement paths in the repo tree.
Just switched to pop os 20.04 from Kubuntu 20.04ā¦wow I really, really donāt like it. Any other distros to try before I go back to Kubuntu?
why distrohop?
Iām not NEW new to Linux, but I think itās time I learnt the ways of open source computing. My uni semester is ending soon so I wanted to try something new for the Summer semester. I liked Kubuntu very much and wanted to see what the others had to offer. Think Iāll settle for KDE Neon to replace Kubuntu as my daily driver on the laptop.
I dont see the point
Tldr
Previous installation was ādirtyā, wanted to start afresh
sounds like some windows level excuses
If you want to stick to KDE you can also try out Fedora KDE.
Begin small linux problem (Kubuntu 20.04):
I like the Cantata music player, and I want to use it to listen to my library. Cantata uses mpd (media player daemon) to actually run the audio stream, Cantataās actually just a frontend for picking media files.
By default, mpd runs as its own user (mpd) and reads a system-wide config file at /etc/mpd.conf
. This is a single-user machine, so thatās fine with me, except that it canāt send audio to PulseAudio this way, since itās not running under my user account. The user
configuration key has no effect here.
Next, I set up a per-user config at ~/.config/mpd/mpd.conf
. This fixes the audio, and I can start the daemon by typing mpd
in a terminal once Iām logged in. Great so far, now I just need it to auto-start on login.
This is the problem. mpd comes with systemd targets, and if I run them as root, they only read the system-wide config (as expected), producing no audio output (as expected). However, when I throw in the --user
flag, mpd doesnāt start at login and I get new errors. Edited for brevity:
systemctl --user status mpd.service
Active: failed (Result: exit-code) since Sat 2020-05-02 21:53:55 EDT; 9min ago
TriggeredBy: ā mpd.socket
May 02 21:53:55 Black-Cherry mpd[1405]: May 02 21:53 : exception: Failed to bind to '127.0.0.1:6600'
May 02 21:53:55 Black-Cherry mpd[1405]: May 02 21:53 : exception: nested: Failed to bind socket: Address already in use
systemctl --user status mpd.socket
Active: failed (Result: resources)
Triggers: ā mpd.service
May 02 21:53:55 Black-Cherry systemd[1398]: mpd.socket: Failed to create listening socket ([::]:6600): Address already in use
May 02 21:53:55 Black-Cherry systemd[1398]: mpd.socket: Failed to listen on sockets: Address already in use
May 02 21:53:55 Black-Cherry systemd[1398]: mpd.socket: Failed with result 'resources'.
May 02 21:53:55 Black-Cherry systemd[1398]: Failed to listen on mpd.socket.
The problem seems to be related to binding the socket. Iām not doing anything network-related with mpd, but thereās no clear way to configure it to just not bind anything. Masking mpd.socket
has no effect on the errors returned by mpd.service
, and I canāt disable either user service for some reason.
Hereās the weird part: after logging in, running systemctl --user start mpd.service
works perfectly, as does simply running mpd
. Both of these methods do indeed bind 127.0.0.1:6600
according to lsof; the failed systemd targets donāt. Port 6600 is not used except by mpd.
So, why is binding a port on localhost such a pain point for non-root, but only in the midst of login? Do I need to add an additional After
target in the target configuration?
Also yes I realize I could just make a one-liner script file to run mpd and exit, and use my DEās autostart thing to run it at login, but I would prefer to be able to sleep at night with my chosen solution.
Trying to compile OBS.Live from source (because thereās no official Linux release) on Fedora, and getting stuck compiling CEF first ('m trying to adapt the Mac compile process since Linux support is rather new in OBS-browser). I can build the CMake files, and make
gets halfway through after installing libX11-devel
, but Iām getting this error:
[ 54%] Linking CXX static library libcef_dll_wrapper.a
[ 54%] Built target libcef_dll_wrapper
Scanning dependencies of target cefsimple
[ 55%] Building CXX object tests/cefsimple/CMakeFiles/cefsimple.dir/simple_app.cc.o
[ 55%] Building CXX object tests/cefsimple/CMakeFiles/cefsimple.dir/simple_handler.cc.o
[ 55%] Building CXX object tests/cefsimple/CMakeFiles/cefsimple.dir/cefsimple_linux.cc.o
[ 55%] Building CXX object tests/cefsimple/CMakeFiles/cefsimple.dir/simple_handler_linux.cc.o
[ 56%] Linking CXX executable Release/cefsimple
/usr/bin/ld: ../../../Release/libcef.so: error adding symbols: file in wrong format
collect2: error: ld returned 1 exit status
make[2]: *** [tests/cefsimple/CMakeFiles/cefsimple.dir/build.make:151: tests/cefsimple/Release/cefsimple] Error 1
make[1]: *** [CMakeFiles/Makefile2:225: tests/cefsimple/CMakeFiles/cefsimple.dir/all] Error 2
make: *** [Makefile:104: all] Error 2
Not sure what Iām supposed to do with that information. Not sure what āfile in wrong formatā is even supposed to tell meā¦ format in what way? architecture? line endings? Either way how would I fix that?
edit: nevermindā¦ fixed it. The Spotify download page is really weird. When selecting Linux 64 the first file is still for 32
edit2:
Now running into this thoughā¦
[ 77%] Building CXX object tests/ceftests/CMakeFiles/ceftests.dir/__/shared/browser/main_message_loop_external_pump_linux.cc.o
/home/tarulia/Documents/dev/OBS.Live/build/cef_binary_81.3.1+gb2b49f1+chromium-81.0.4044.113_linux64/tests/shared/browser/main_message_loop_external_pump_linux.cc:11:10: fatal error: glib.h: No such file or directory
11 | #include <glib.h>
compilation terminated.
make[2]: *** [tests/ceftests/CMakeFiles/ceftests.dir/build.make:980: tests/ceftests/CMakeFiles/ceftests.dir/__/shared/browser/main_message_loop_external_pump_linux.cc.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:280: tests/ceftests/CMakeFiles/ceftests.dir/all] Error 2
tried installing glib-devel
, glib2-devel
with no success, glibc-devel
is already installedā¦ hints?
Could you not just make a target named mpd@<your_user>.service? Then you would include the normal requirements in your service file but make sure it has permissions to the right group to run unattended.
whats the diff b/t obs studio and obs live?
Thank you so much! You put me on the right track to solve my problem.
For some reason, Systemd put my --user
symlinks in /etc/systemd/user
, which made them read-only for my user account (root/root, 755). Thatās why I couldnāt disable the services. Deleted them as root, and the targets are disabled, finally. Manually re-enable them, and the symlink appears in ~/.config/systemd/user
. One problem solved!
As I was getting that sorted, I made an instantiated service file as suggested. Of course, running the service without --user
never worked to begin with, so that didnāt change. But after I fixed the symlink issue, I copied the user version of the unit file and enabled that service with --user
. It worked, which was weird, because I hadnāt changed the unit file at all. I disabled the unit file and gave the normal unit file a shot, and now it just worksā¢. So it must have been those bum symlinks from Canonical all along.
Thanks again!
OBS.Live is a plugin for OBS to integrate StreamElements, itās not a fork or anything. Wellā¦ itās a fork of obs-browser, but not OBS itself (unlike StreamLabs OBS)
So I asked on the OBS Discord, and they suggested using an older Chromium Version.
Iām using CEF 76.1.13+gf19c584+chromium-76.0.3809.132
and it gets through that part, but is stuck now at some GTK dependency:
[ 82%] Building CXX object tests/cefclient/CMakeFiles/cefclient.dir/browser/browser_window.cc.o
In file included from /home/tarulia/Documents/dev/OBS.Live/build/cef_binary_76.1.13+gf19c584+chromium-76.0.3809.132_linux64/tests/cefclient/browser/client_handler.h:16,
from /home/tarulia/Documents/dev/OBS.Live/build/cef_binary_76.1.13+gf19c584+chromium-76.0.3809.132_linux64/tests/cefclient/browser/browser_window.h:11,
from /home/tarulia/Documents/dev/OBS.Live/build/cef_binary_76.1.13+gf19c584+chromium-76.0.3809.132_linux64/tests/cefclient/browser/browser_window.cc:5:
/home/tarulia/Documents/dev/OBS.Live/build/cef_binary_76.1.13+gf19c584+chromium-76.0.3809.132_linux64/tests/cefclient/browser/client_types.h:12:10: fatal error: gtk/gtk.h: No such file or directory
12 | #include <gtk/gtk.h>
make[2]: *** [tests/cefclient/CMakeFiles/cefclient.dir/build.make:96: tests/cefclient/CMakeFiles/cefclient.dir/browser/browser_window.cc.o] Error 1
make[1]: *** [CMakeFiles/Makefile2:307: tests/cefclient/CMakeFiles/cefclient.dir/all] Error 2
There is Fedora documentation regarding GTK development:
https://developer.fedoraproject.org/tech/languages/c/gtk.html
After installing the packages listed there I am still getting the same error though.
Iāve also tried installing gtk2-devel
and gtk+-devel
, with no luck either.
edit:
So, after a bit of talk they also suggested only building the wrapper since apparently the gtk stuff is only needed for the tests. If we assume that the compile runs clear, they arenāt needed so can be ignored. just running make libcef_dll_wrapper
finishes without issues.
Iām also able to compile OBS including the browser source (which is missing in the Fedora Repo for some reason).
I can not get OBS.Live (i.e. the StreamElements version of obs-browser) to compile however, due to unsatisfied dependencies. They include angelscript
(which is available in Fedora, Iād just need to tell it the path) and BugSplat, which is commercial and most likely requires their commercial license.
So itās been almost 2 weeks now and that package is still not available. Iām going to take a wild guess and say that package was abandoned by KDE (last release seems to have been over 5 years ago according to Wikipedia).
Itās just odd that they wouldnāt mark it for removal upon upgrade. Itās not the first package that was seemingly abandoned and removed during a release upgrade.
The KDE Multimedia manager (it was just called Multimedia, I donāt know what the actual package name is) where you could give certain audio categories specific priorities and such disappeared from 29 to 30 if I recall correctly (even though it seems to still be in use because on some audio players I still get its notifications, but the configuration panel is gone).
The one small issue I have with Fedora is that I just donāt know where I would even start reporting those things. The Redhat Bugtracker seems an obvious choice but I donāt know if itās correct.
Anyway, since Iām not using Telepathy anyway (as far as I can tell?), Iām just going to remove it and do the upgrade anyway. I think Telepathy is this in the System Settings:
Whichā¦ seems promising
edit: Was actually the last outstanding package:
Transaction Summary
Install 59 Packages
Upgrade 2603 Packages
Remove 35 Packages
Downgrade 2 Packages
Total download size: 3.0 G
Off we go I guess.
edit 2:
OK, that went smooth, except that now I donāt have any audio anymore on my headphone/speaker
Topic regarding that moved out of here.
Would anybody mind walking me through how to get radeon-profile working? Linux noob here. - https://github.com/marazmista/radeon-profile
When i do qmake
Terminal spits back Project MESSAGE: Building for release Project ERROR: Unknown module(s) in QT: charts
Did you install qt-charts?
