Ok, you installed pfSense and are wondering what else you can do with it.
Or, You have a VPN and want to have a few devices on a VPN but not everything on the network.
This is an easier way to manage this instead of a device by device basis. Also handy if setting up a device that would be too cumbersome to maintain.
if you haven’t installed it look here:
This will be based around using Private Internet Access because that is popular and what I pay for. An OpenVPN server in the cloud or another service will work the cert and server addresses will change though.
I am going to do a little something different this guide and do it with pictures.
I would add that you can make this guide universal quite easaly. All you need to do is open the .ovpn file from whatever service you’re using and match the configuration. Any options that don’t appear in the GUI can be added in the advanced section with a semi colon separating each one. For example:
Nice write up, I’m planning to setup my pfSense box as an OpenVPN client sometime this year when I get some time but I’ll likely wait until after 2.4 is released before I do it.
