I cannot tell if this is too good to be true or not, seems like an amazing deal but I feel like I am missing something. Anyone know anything about these or have a better suggestion in mind?
My only plan is hosting a couple web servers maybe a game server and a little Virtualization.
And this is not a hardware locked OS is it? Can find no info on the subject all Google yields is for sale things. I'd like to just throw Windows server on it with the option to move over to Unix at any point.
I wouldn't necessarily be too concerned about a storage limitation like that. Considering the speed that you'll get from directly attached disks on that would be pretty similar to just running iSCSI on a 1 gigabit connection, it would be possible to add more storage without too much of a compromise.
I would be on the fence if I had the extra cash (and room to spare) for one. If you definitely have the use for it, it's a decent enough box to get. Otherwise, I concur with @_adrian.
That is true I didnt consider external storage.. I have wanted an upgrade from an old Dell PC/"server" I have had for a while. Plus I'm moving to a house with Gigabit internet options and plenty of rooms.
Also, when I say gigabit, I mean the speed of your internal network. Long story short if you have a 2nd machine as an iSCSI target connected to that directly via a single ethernet cable, that would work.
just an old dell workstation, took out the old Quadro 3000 and put 4-5 HDDs in it. Its not bad but the CPU sucks, single Xeon 4 core 2.0 ghz and most RAM I can get to work on it is 8GB
I knew what you meant i'm just saying I could host for people reliably with 1G/1G fiber compared to 150/17 cable internet. So it makes it a little more worth it.
something newer. newer = less power, better performance. what you're looking at is 65nm and ddr2. if you have a use for it (i.e., will do what you need) and it's in your budget and you don't want to spend time looking for something else, it's fine.
i wouldn't buy something older than a G6. BUT,
i have access to similar (to G3-era) hardware for free from time to time
i don't mind looking for/ waiting for better deals
i don't have pressing needs for more hardware (of this type / age, anyway)
so, up to you. i'd encourage you to research what you're getting, but i wouldn't flat-out warn you away.
That G3 is a pair of non-hyperthreaded, lower clock quads with DDR2 ram and used hard drives. Your best off spending a bit more and getting something DDR3. Really any DDR3 quad core hyperthreaded old server is going to spank that thing.
