Hi there,
I bought a Minisforum NAB6 (Minisforum NAB6/NPB7) two weeks ago. In Europe, the performance per euro made really sense.
Initially I intended to use it as replacement for my aging laptop. Since it has two USB-C port able to carry DisplayPort, I thought I could simply use a dock at work and at home and just worry about bringing power since unfortunately it cannot be powered over the USB-C port. So only 2 cables to (un)plug when switching between home and office.
My monitors setup is a Dell 27" U2721DE 1440p and an Asustek Pro Art 27" PA278QV 1440p. The Dell has an integrated dock which is setup to act as a MST hub. It forwards DP signal to the Asustek. It works fine with my old laptop with its 8th gen CPU. The only thing to do is to downgrade the USB connectivity to USB 2.0 to recover enough lanes to be able to drive the two monitors at 1440p. (8th gen CPU is DP 1.2 and speaks HBR2).
With the NAB6, I have access to DP 1.4 HBR3 and could potentially keep USB 3.1 speed while driving the two screens at full resolution. Since I might still use my laptop, I will probably keep the priority on data resolution and leave the USB part set to 2.0.
The main issue with the minisforum is screen flickering. The screen would show a good image (ie. readable, expected resolution) for a few seconds, then the screen turns black and the monitor proceeds looking after signal. Usually it will find it back and display again the image for a few seconds. Both screens flickers independently at their own pace. The Asustek will usually go to sleep after a few attempt. The Dell monitor goes may or may not go to sleep complaining there is no signal on the USB-C.
I have been lucky a few times to have a stable image on both monitors for more than an half an hour. So it looks like it should work but I can’t reproduce that kind of stability reliably, which is annoying if I intend to have productive work done. But hey, testing is fun!
Turning off MST allows me to have a stable experience, but my second monitor is now a simple mirror of the first.
I tried Ubuntu 23.04 live cd, Ubuntu 22.04 LTS installed and up-to-date, and Win 11 installed. All the OSes exhibit the same instability, even when only the Dell screen is on (MST enabled) and the other one off.
Under linux, is there a place where I could look to understand what is going on and if I can have some hope of fixing this via software? Is there some diagnostics I could run to get a clear picture (no pun intended) of what is wrong in the chain? (display port link training, modelines, buggy MST hub, uncooperative Asus Pro Art, …)
Is there a way to downgrade to HBR2 just for testing? (Since my laptop can make this setup work with DP 1.2, I might very well settle for that)
Thank you in advance for any suggestion,
Laurent
