We haven’t ‘spoken’ before (and this is my first Internet forum post after more than twenty years of being in the IT industry), but I wonder if you can help me out with a very specific issue that I’m facing?
My Broadcom 9500-8i can’t see my eight SanDisk 800GB TXA2D2 (SDLKOC6R-800G-5CA1) SAS SSDs via my SFF-8654 8i to SFF-8482 x8 forward ‘fanout/breakout’ cable (which is powered by a couple of 4-pin Molex connectors).
As you’d expect with a cable like this, it doesn’t appear to include the eight SAS dual-port gold connector pins (S8-S14) on the reverse side of the SFF-8482 connector, which my SSDs have).
I can see the disks when they’re plugged into other servers that feature a ‘proper’ backplane - but, unfortunately, this is something I probably can’t provision in the custom builds that I’m in the middle of, due to a lack of space with a small, short-depth 2U server case).
I suspect that my issue may stem from the fact that these disks’ firmware may expect to see an enterprise backplane (with dual port connectivity or possibly some kind of out-of-band signalling via an SGPIO sideband cable) and as a result, aren’t then exposing themselves properly to the HBA (and subsequently within Linux).
It’s also entirely possible that whatever issue I’m facing was resolved via a firmware update. The only reference to the firmware Release Notes that I can find, is here:
…which seems to suggest that the file I should use will likely be called:
optimus2_generic_F910_fw_plus_boot.dob
I appreciate you likely won’t have touched these for a while now, but I’m hoping you might still have the firmware for these ‘Optimus.2 Ascend 2.5” 800GB (10 DWPD)’ disks?
…and possibly some more formal means to flash it to them, than this shell script?
Kind regards,
John
Reference:*
