Hi, any advice on where I should start on my system? I have a TR 1950X on the Aorus Gaming 7 X399 motherboard running 4 sticks of Micron DDR4-2400 16 GB ECC UDIMM Part number CT16G4WFD824A. Currently my timings are 17-17-17-39-56 at 2T. When I first built the system, I tried 1T (at 1.2V) and got errors under stress. As a result, I am running everything at stock right now, but reading about the benefit of faster memory for TR, I’d like to see if I can do better than stock. I tried googling the part number to see if others have had success, but did not find any results. Does that mean this part is not over-clockable? I’m not looking to reach 3200, just something that is better than stock. Any advice would be greatly appreciated. Thank you.
Start with 1.35v 1t and see if it’s stable? Same timings.
Hi, so I have been trying this for the past couple of weeks and I can’t seem to even reach 2666 at 1.35v at 20-20-20-40. By reach, I mean passing memtest86 in its entirety. Are there other settings I should adjust? I tried google, and it seems it should be very easy to reach 2666 so I must be doing something wrong? Thanks!
