Is this worth doing? Will I see any real world performance improvement?
Main use is playing games, creating crafting stuff – photos, vinyl cutting, photoshop, general computing stuff …. vm’s etc. Help daughter record choir solo's. Maybe make it a dual boot linux/win10
Im seriously considering buying a 50" 4k tv to use as another display.
It looks like I can do this for right around $500
Suggestions?
or should i just be happy with my current setup and save for a VEGA/Ryzen7 system upgrade?
CPU: AMD Ryzen 5 1600 3.2GHz 6-Core Processor (overclocking it ) $230 ish
Motherboard: ASRock X370 KILLER SLI/ac ATX AM4 Motherboard $150 ish
Memory: G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory $135 ish
Parts on hand
2 ea – Samsung SSD 256GB 850 Pro ( I got stuck with these after a “friend” backed out of a build he wanted me to do .)
case – DIY-BG01 - https://www.newegg.com/Product/Product.aspx?Item=N82E16811353121 - Actually a very nice case on the cheap
I know I have a 650w power supply at home , just cant rmember what it is.
Then I would move video cards around for the other systems. maybe could move other parts too.
I would put the 2 RX480’s in the Ryzen build, Transfer the R9-290 to the Xeon build, Put my old GTX-650 Ti in the 8300 build.
I would then make the 8300 into a home server by adding a couple of large mech spinner drives.
The xeon system would then go to work with me to do bland work stuff.
Work pc
CPU: AMD FX-8300 3.3GHz 8-Core OEM
CPU Cooler: Cooler Master Hyper TX3 54.8 CFM Sleeve Bearing CPU Cooler
Motherboard: Gigabyte GA-78LMT-USB3 Micro ATX AM3+ Motherboard
Memory: Mushkin ECO2 16GB (2 x 8GB) DDR3-1600 Memory
Storage: PNY CS1311 240GB 2.5" Solid State Drive
Video Card: XFX Radeon R9 290 4GB Black Edition Double Dissipation Video Card
Case: Corsair 200R ATX Mid Tower Case
Power Supply: EVGA 500W 80+ Bronze Certified ATX Power Supply
Home pc – my gamer
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor
CPU Cooler: ARCTIC Freezer 13 36.4 CFM CPU Cooler
Motherboard: ASRock Fatal1ty Z97 Killer ATX LGA1150 Motherboard
Memory: Kingston HyperX Fury Black 16GB (2 x 8GB) DDR3-1866 Memory
Storage: Kingston SSDNow V300 Series 240GB 2.5" Solid State Drive
Storage: PNY CS1311 480GB 2.5" Solid State Drive
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive
Storage: Samsung Spinpoint F3 1TB 3.5" 7200RPM Internal Hard Drive
Video Card: XFX Radeon RX 480 8GB XXX OC Video Card (2-Way CrossFire)
Case: Phanteks ECLIPSE P400S ATX Mid Tower Case
Power Supply: Raidmax 735W 80+ Bronze Certified Semi-Modular ATX Power Supply
